Koleksi hand tools [Part 09]
yanuarra wrote: Sat Dec 04, 2021 11:24
Serius mbah kaya boled? :big_think:
tu, buled kaya boled.
yanuarra
Post by yanuarra »
marmut wrote: Sat Dec 04, 2021 11:41
Waiya mbah mirip..nubi baru liat :big_grin:
yanuarra wrote: Sat Dec 04, 2021 11:56
mabok ngaudit kayanya nih. hilang orientasi
coba mbah jawab, apa bedanya kepala sama kelapa?
yanuarra
Post by yanuarra »
Omnibus wrote: Sat Dec 04, 2021 12:08
bedanya sama2 bunder :big_think:
yanuarra wrote: Sat Dec 04, 2021 12:10
bener
bener lieur nya :big_weee:
bedanya kl kepala dicukur jd botak, kl kelapa dicukur jd batok
blloewy
Post by blloewy »
Omnibus wrote: Sat Dec 04, 2021 11:34
yanuarra wrote: Sat Dec 04, 2021 11:26
Omnibus wrote: Sat Dec 04, 2021 10:19
:frm_salut:
sini 500rb nya, dp dulu. jangan sendal tok.
nah sy pakenya kapan ga tau. kan skrg belum ada radiator trouble, ga kaya mbah profith.
*dgn dp itu berarti cuma modal gope lagi buat tebus barang ke mbah profith nya. :mky_03:
Radiator pressure tester mah ga musti nunggu rusak kan mbah :big_think:
ga trouble ditest? kurang kerjaan
:frm_salut:
Bentar2 kayanya di garasi 58 ada ini alat...yg bentuknya tabung trs ada gagang u dorong khan ya?
Yg kaya semprotan baygon itu :big_think:
blloewy wrote: Sat Dec 04, 2021 12:28
:frm_salut:
betul. tp yg sy maksud kit ada adaptor tutup radiatornya
dari gugel
yanuarra
Post by yanuarra »
Omnibus wrote: Sat Dec 04, 2021 14:17
:frm_salut:
dari gugel
Wohh mbah masas keren pol punya begituan :emo-big_love:
yanuarra wrote: Sat Dec 04, 2021 14:29
dari gugel
nunggu lungsuran dr mbah profith :wkkk:
Profith83
Post by Profith83 »
Omnibus wrote: Sat Dec 04, 2021 10:01
marmut wrote: Sat Dec 04, 2021 8:55
Omnibus wrote: Sat Dec 04, 2021 6:16
. ada yg bocor entah dimana. bisa juga thermostat nya macet tp bukan artinya hrs dimodif.
head gasket?
nemu kasus coolant habis tak berjejak tak ada bocor keluar tak ada jejak dimanapun.
radiator baru, tutup radiator baru, waterpump baru, thermostat baru.
sudah diteliti dengan sangat, tak ada jejak.
satu-satunya tersangka ya head gasket toh? :big_grin:
konon yg nubie denger2 dr rumput yg bergoyang --> lepas busi atau kl di diesel lepas injector, dilihat kl bersih kaya baru berarti ada bocor coolant ke ruang bakar.
Bagus dong mbah ruang bakar jadi bersih 😁😁
Profith83
Post by Profith83 »
Omnibus wrote: Sat Dec 04, 2021 14:39
dari gugel
Kemarin pakai 1 jam gak ada muntah, macet2z an.
Curiga PCV ketahan karena selang ketutup air waktu hujan. Jalanan menurun. Jadi panas berlebih ....
warna merah? itu grease gun.
yang tabungnya kuning? itu oil pump, buat masukin oli transmisi sama oli gardan.
itu kalau yang bocor penyekat antara coolant passage dengan combustion chamber/cylinder dan si coolant terhisap masuk.
ini saya sudah pernah ngalamin sendiri. saat idle dan saat cruising terkadang mesin pincang. pincangnya kapan dan berapa lama nggak bisa ditentukan. bisa seharian aman ngga ada pincang, bisa juga berkali-kali.
tapi, kalau ternyata coolant malah terdorong sama kompresi, kan bisa saja... kalau crack cukup besar, langsung ketauan pas engine di crank dan tutup radiator dibuka, coolant langsung nyembur.
tapi kalau crack halus, bisa jadi nggak nyembur langsung.
punten mbah, nubi nggak maksud ngajarin.
:ngacir: dulu *takutkualatsamasuhu.
marmut wrote: Sun Dec 05, 2021 4:36
ga apa2 ngajarin kan sy nubi abadi, selalu perlu bimbingan dr subes2 di mari
:frm_salut:
Profith83
Post by Profith83 »
Siap mbah :frm_salut:
Profith83 wrote: Sun Dec 05, 2021 5:56
ini 2gd di vrz sy udah running di garasi 30 mnt lebih. pake ac. bleyer2 sampe 3000 rpm. ambient temp 26°C
hasilnya? coolant temp cuma di 83-86°C
bahkan kl dr idle digas malah turun, krn sirkulasi kan coolant nya ketika waterpump speed up.
jadi gimana? mau diganti thermostat lbh rendah? :big_smile]
blloewy
Post by blloewy »
Omnibus wrote: Sun Dec 05, 2021 7:46
Mbah shifu...tujuan termostat lebih rendah itu artinya khan spy lbh cepat buka jad coolant lbh cepet ngalir begitu kah?
Kl dr hasil data yg mbah shifu buat di atas artinya meskipun mobil idle dan ngga dpt pasokan angin dari depan yg cukup tp pas digas 3000 rpm dia langsung turun suhu nya.
Sementara idealnya itu turun krn di rpm 3000 khan mobil melaju kencang jd pasokan angin dari depan banyak makanya suhu turun...apakah ini akibat pengaruh oli juga mbah? Yg bantu dinginkan suhu engine meskipun jadi genset?
blloewy wrote: Sun Dec 05, 2021 8:37
oli sdh pasti jd media heat transfer, artinya panas dr komponen mesin ditransfer ke oli. cuma kebetulan 2gd ada oil coolernya juga jd dr oli di transfer lagi ke udara sekitar. digas ke 3000 rpm otomatis membuat sirkulasi oli lbh cepat jg krn oil pump speed up, makanya suhu turun. tp kan itu keliatan kl ada sensor oil temp, sementara stdnya ga ada. adanya cuma coolant temp sensor.
yanuarra
Post by yanuarra »
Omnibus wrote: Sun Dec 05, 2021 9:57
Waini ilmu baru...nubi izin nyimak mbah :big_peace:
yanuarra wrote: Sun Dec 05, 2021 10:17
ilmunya sih sudah lama mbah... jaaauuuuh sedari kita belum lahir.
yanuarra
Post by yanuarra »
marmut wrote: Sun Dec 05, 2021 11:58
Oh gitu ya mbah... Harap maklum kan nubi abadi :big_biglaugh:
yanuarra wrote: Sun Dec 05, 2021 12:52
rekstir priben mbah, wis waras ta?
blloewy
Post by blloewy »
marmut wrote: Sun Dec 05, 2021 14:27
Rekstir dari dulu waras mbah...tp....
*Kaburrrrr........ :ngacir:
yanuarra
Post by yanuarra »
Yg ga center itu mbah ? :wkkk:
Profith83
Post by Profith83 »
Wow mantap memang Boss ku ..... :big_exellent: :big_exellent:
Kalau jelas seperti ini gak mau ah ..... :big_smoking:
Makasih Om :big_smile]
