Tip setel kaca untuk menghindari blindspot...
http://www.easysurf.cc/mirror1.htm
Tapi ini buat left-hand drive, jadi puter aja instructions nya.
George Platzer, a member of the Society of Automotive Engineers and a consultant who holds several patents on mirror design, has developed a simple rearview mirror-adjustment system that eliminates blind spots and gives drivers 20-20 hindsight.
Rotate your mirrors about seven degrees outward to cover the field of view normally missed, i.e., your blind spot. "Most people's side mirrors are aimed back along the flanks of their cars," Platzer says, "but much of the area seen in the outside mirror is already covered by your inside rearview mirror. You might as well point those side mirrors out where they can do some good."
Platzer's process:
* Sitting in the driver's seat, lean to your left until your head just touches the side window.
* With your head at this point, adjust your left side mirror so the edge of your fender is barely visible on the inside edge of the mirror.
* Now move or lean right with your head at the car's centerline and make the same adjustment to the right mirror. Your three mirrors will now offer a panoramic view of the area behind and to the sides of your car.
Here's how the system works in traffic. The inside mirror is your primary mirror. It shows you everything except the blind zone. The outside mirrors show you only the blind zones. When changing lanes, first look in the inside mirror to observe traffic to the rear. Then look in the outside mirror to see if there's a car in the blind zone.
A car passing from behind will first appear in your center rearview mirror. Before it leaves that mirror, it will appear in the side mirror, and as it passes from the side mirror's view, it will appear in your peripheral vision.
The only downside to Platzer's method is a loss of visual reference to your own vehicle: the fender edge you were used to seeing is now gone. But you'll soon adapt to the new position, as traffic behind you flows from your center mirror to your side mirrors (or vice versa if you're doing the passing).
The end result of Platzer's mirror-adjustment method is almost unbroken visibility behind and to the sides of your car.
Continually scanning what's ahead and behind will keep you visually and mentally on top of the situation.
gioprivatemove
Re: Tip setel kaca untuk menghindari blindspot...
Post by gioprivatemove »
Setuju Om,
setelan spion samping memang harus maksimal, jgn setelannya malah banyakan liat body samping mobil kita sendiri.
trus biasakan sebelum pindah jalur juga untuk melihat spion tengah. karena kita juga harus waspada jika ada mobil yang sedang zigzag ingin mengambil jalur yang ingin kita tuju.
mandala1
Post by mandala1 »
Nice info gan.... :frm_tumbright:
buatandi
Post by buatandi »
pake kaca kecil yang cembung membantu bgt tu kalo kaca spion ny kecil model kotak :D
buatandi wrote:pake kaca kecil yang cembung membantu bgt tu kalo kaca spion ny kecil model kotak :D
pengalaman ane sih malah gak terlalu bantu kalo mobil lagi berjalan dengan kecepatan sedang. soalnya spion kecil yang cembung itu objeknya malah kecil.
ane malah lebih suka kaca spion dalam yang lebar tapi cembung.. lumayan ngebantu mengurangi blindspot... :frm_tumbright:
thanks untuk sharingnya.. :e-clap:
m4rio
Post by m4rio »
kalo menurut ane spion kecil itu emang membantu bgt, dan ane kalo liat spion kecil itu selalu hanya patokan apakah ada mobil di samping atau tidak, dan bukan buat ngeliat jarak.
ane juga selalu posisikan kaca spion sampai posisi mobil kita terlihat hanya sedikit saja.
avansa
Post by avansa »
Tanks inponya bro....good banget :frm_tumbright:
iwang
Post by iwang »
apalagi kalo 300E/w124..kaca spion kanan blindspotnya banyak..mending nengok deh biar pasti...
kalo di 300TE spion tengah ada dua susun, jadi bisa disusun liat pojok kanan dan kiri belakang :D :D
DigitALL
Post by DigitALL »
Kalo kaca spion mobil Eropa kaya Mercy dan BMW dibagi 2 bagian, yg terluar lebih cembung jadi blind spotnya kecil bgt.
Thanks bro buat infonya :)
Post by y_anjasrana »
Mmmm... berarti settingan mirror gw selama ini kurang maksimal ya. Selama ini kalu mau ganti jalur, sering tengok kiri/kanan untung memastikan jalur kosong. Kalu cara yg ini berarti ga begitu perlu sering2 tengok2 kiri/kanan dulu ya...
Info bagus... Thx...
mandala1
Post by mandala1 »
Tapi setelan begitu (ga keliatan bodi samping mobil) kadang ngerepotin kalo pas lagi parkir di tempat yg pas2an.....kalo ane lebih demen masih keliatan bodi samping dikit..... :)
mandala1
Post by mandala1 »
Hmmm.....baru nyadar ternyata parking camera helpfull juga yah....padahal selama ini ane lebih percaya sama kaca spion n nengok ke belakang kalo lagi parkir..... :)
imsus2c
Post by imsus2c »
mandala1 wrote:Hmmm.....baru nyadar ternyata parking camera helpfull juga yah....padahal selama ini ane lebih percaya sama kaca spion n nengok ke belakang kalo lagi parkir..... :)
meneer, gambar yg dikiri itu penampakan dari atas secara vertikal ya? gimana cara pengambilan gambarnya tuh? :e-think:
btw...tulisannya pake huruf pagar ya :mrgreen: ? ga bingung bacanya tuh? :upss:
mandala1
Post by mandala1 »
Yg sebelah kiri meneer? Itu gambar aktif dari 4 kamera, depan, samping kiri kanan n blk....jadinya keliatannya seperti kayak dari atas gitu....hehehe.....
Kalo yg sebelah kanan bisa dipilih optionnya mau belakang atau samping kiri saja.......
Ho'oh tulisannya hurup jawa semua....cuma dingerti2in sendiri aja deh..... :upss:
Ini gambar dari deketnya :
imsus2c
Post by imsus2c »
mandala1 wrote:Yg sebelah kiri meneer? Itu gambar aktif dari 4 kamera, depan, samping kiri kanan n blk....jadinya keliatannya seperti kayak dari atas gitu....hehehe.....
wah...keren :frm_tumbright: :frm_tumbleft:
jadi semacam proyeksi virtual gitu yah.. :ungg:
Abu2
Daily Vehicle: just a bike
Post by Abu2 »
bisa di zoom gak itu Dal??, mana tau pas lagi di berenti di perempatan, di samping ato belakang mobil ada boncengan yg lagi pake rok mini.... :mrgreen: :ngacir:
mandala1
Post by mandala1 »
wekekeke.......di zoom sih kaga bisa wan :mrgreen: tapi kalo buat motret bisa,, lagian kalo di lamer ngidupin kamera begitu jadi parno sendiri....risih bener keliatannya motor pada memet2 banget semua..... :e-doh:
sjamsul
Post by sjamsul »
mandala1 wrote:wekekeke.......di zoom sih kaga bisa wan :mrgreen: tapi kalo buat motret bisa,, lagian kalo di lamer ngidupin kamera begitu jadi parno sendiri....risih bener keliatannya motor pada memet2 banget semua..... :e-doh:
memet2 itu artinye apa dal......... mungkin maksudnya mepet2 ya.................... ato klo dlm bhs jermannya itu bearti 'deket2'.... tul ga....... :e-think: ...........
:ngacir: :ngacir: :ngacir: :ngacir: :ngacir: ..........
mandala1
Post by mandala1 »
^^ pinter om! sebetulnya ane sengaja disalahin begitu nulisnya, pengen tau ajah tingkat ketelitian member2 disini.....huehehehe.....jempol deh buat nt :frm_tumbright:
Abu2
Post by Abu2 »
mepet mepet yah?...lamer itu apa dar?
buatandi
Post by buatandi »
akh sala pencet aj tuh :D
buatandi
Post by buatandi »
lamer lampu merah wan abu" :D
mandala1
Post by mandala1 »
Abu2 wrote:mepet mepet yah?...lamer itu apa dar?
dal....bukannya dar :2gunfire:
kalo ngga ngerti mepet, dempet gitu..... :big_weee:
mandala1
Post by mandala1 »
buatandi wrote:akh sala pencet aj tuh :D
huuh!!! :e-snooty:
buatandi wrote:lamer lampu merah wan abu :D
hahahaha......nt percaya ndi? wan abu ga tau lamer? ..... :ngacir: :ngacir:
