Covini C6 Wheels
The original idea was conceived in '74 as an emulation of the Tyrrell F1 car and made provision for 10in front wheels because there where no low profile tyres at the time. The project was ditched in favour of the Soleado prototype, deemed more important, and lay dormant until the 80s when hydro-pneumatic suspension for the four front wheels where devised to optimise weight distribution under various loading conditions.
High evelopment costs and other contingencies forced the project to be delayed again. Its use of new ABS technologies and airbags in the 90s pointed in the direction of new research into active and passive safety. This aspect encouraged backing from companies for its development.
THE ADVANTAGES OF SIX WHEELS
Four steering front wheels are becoming increasingly interesting in high performance cars for active and passive safety (a blown tyre, aquaplaning, braking, road adhesion, comfort etc.).
The main advantages:
- less risk for front tyre deflating
- less risk of aquaplaning
- better braking
- better grip
- better comfort
- better absorbing of frontal impact
ENGINE*: rear, longitudinal, 8 cylinder in V formation, 4 valves per cylinder, naturally aspirated, petrol direct injection Bosch-motronic.
CAPACITY: 4200 cc
MAX POWER: 380 PS (260KW) at 6400 rpm
MAX TORQUE: circa 450 Nm (45.9 Kgm) at 2700 rpm
TRANSMISSION: rear wheel drive transaxle
GEARBOX: mechanical 6-speed + reverse. Manual and electro-hydraulic steeringwheel mounted servo
CHASSIS: steel tubular with carbon fibre reinforcements and structural parts
SUSPENSION: independent front and rear wishbones
WHEELS AND TYRES: front 15in wheels with 205/45-15 tyres; rear 20in with 345/25-20 tyres
BRAKES: front and rear vented Brembo discs. Bosch servo and electronic brake distribution
BODYWORK: glass fibre and carbon fibre
DIMENSIONS: length 4180mm; width 1990mm; height 1080mm; wheelbase 2230mm/2750mm (to foremost/middle front transaxle); front track 1540mm; rear track 1620mm
dry weight 1150Kg
TOP SPEED: 300Kph (185mph)
Text and photos courtesy of Covini Engineering
Covini C6 Wheels
Covini C6 Wheels
Re: Covini C6 Wheels
klu mobil kyk gini ga perlu ban cadangan lg ya... klu bocor tinggal pindahin ke baris tengah....
Sebenarnya keuntungan ban depan dua pasang kek gitu apa sih?
Good Q. Slh 1nya kata designer tyrrell P34 ini utk ningkatin traksi dan distribusi bobot saat cornering lbih bagus. Walau sejarah buktikan tyrrell P34 tdk sekompetitif itungan matematis walau diawaki driver hebat Jody Schekter skalipun.artoodetoo wrote:Sebenarnya keuntungan ban depan dua pasang kek gitu apa sih?
Ada 1 lagi:
Panther 6, pernah punya Tomica nya..
Itu rekannya Patrick Depailler ya?
knp ga roda belakang aja ya yg dibikin dobel?
Ya ndak bisa belok tho omy_anjasrana wrote:knp ga roda belakang aja ya yg dibikin dobel?
Takut ntar dikira truk tronton tractor head kali om..y_anjasrana wrote:knp ga roda belakang aja ya yg dibikin dobel?
Nightster Guy wrote:Takut ntar dikira truk tronton tractor head kali om..y_anjasrana wrote:knp ga roda belakang aja ya yg dibikin dobel?
itu dieee maksud ane om..... emang fungsi roda di belakang sampai 2 baris itu utk apaan sih klu bukan utk dpt penyaluran torsi yg bagus?
