akan Launching=Fazer250CC|CBX250CC|GSF250Bandit|Pulsar220CC
1. Yamaha YZ 250F 249CC, uji type nomor: 386
FAZER 250•Engine = 4 stroke SOHC
•Transmission = 5 speed
•Engine Capacity = 249.0 cc
•Max Power: 21bhp @ 7500 rpm
•Max Torque: 20.5926 NM / 2.10 kgm @ 6500 rpm
•Compression: 9.80:1
•Bore x Stroke: 74.0 x 58.0
•Dry Weight: 134 kg
2.CBX 250 Twister [masuk CBU]
CBX 250 Twister
Engine: Single Cylinder - Air-cooled 4-stroke 4-valve DOHC
Capacity: 249cc
Max Power: 24 bhp @ 8000rpm
Max Torque: 2.48 Kgm @ 6000rpm
Power to weight ratio: 131.5bhp / tonne
Max Speed claim 134 kmh
3. GSF250 Bandit
GSF 250 Bandit ini yg bikin kaget! liat Diameter x Stroke? 4Silinder??
siap-siap kudu nabung nih...... keren abis rasanya nanti
Engine Type: 248 cc, 4 Stroke - Air Cooled - Inline Four
Engine Bore and Stroke: 49 mm x 33 mm
Valves 4 valves/cylinder
Claimed Horsepower: 38 hp (28.3 kW) @ 14000 rpm
Maximum Torque: 25 Nm (18.4 ft. lbs) @ 10000 rpm Transmission type: 6 speed
4. Pulsar 220
Engine: 220 cc
Maximum Power: 20.06ps@8500rpm
Maximum Torque: 19.12nm@6000rpm
Gears: 5 Speed
Clutch: 177
Bore: 67
Stroke: 62.4
denger khabar yg akan duluan adalah Yamaha YZ-250F sesuai Slogan? Yamaha Selalu yang Terdepan?
CBX-250CC khabarnya ini yang dikatakan Tiger 250CC? modelnya tdk spt CBX tp ke arah Tiger?
Yang Lain belum jelas, malah desas desus Ninja 250R??
who knows?? lihat aja kelahirannya.....
CMiiW
tolong dipindah bila salah posisi Om Moderator
•Dry Weight: 134 kg
CBX 250 Twister
Capacity: 249cc
3. GSF250 Bandit
4. Pulsar 220
Engine: 220 cc
Gears: 5 Speed
Clutch: 177
Bore: 67
Stroke: 62.4
CMiiW
Re: akan Launching=Fazer250CC|CBX250CC|GSF250Bandit|Pulsar220CC
Wah.. Smuanya kudu minum PERTAMAX pastinya.. Hehe..
Keren tuh cbx 250, kalo fazer 250 kepalanye kekecilan..
Kisaran harganya gmn bro? Jadi scopie, tigy, stop produksi ya? Huhu..
nah klo fazer ini katanya sih v-ixion 250 cc yak, dgn sedikit face lift
itu bandit tenaga nya 38 dk, mantap bro
"Those friends thou hast, and their adoption tried,
Grapple them to thy soul with hoops of steel;
But do not dull thy palm with entertainment
Of each new-hatch'd, unfledg'd comrade."
- William Shakespeare
kalau Fazer dilihat dari kompresinya sih premium bisa deh rasanya??endy wrote:Wah.. Smuanya kudu minum PERTAMAX pastinya.. Hehe..
CBX-250 <= modelnya sama banget sama New Tiger, beda mesin aja
gak tau deh produksi lagi apa kagak??
masa Fazer kekecilan?? itu karena foto ngadep belakang sih??
nih aye upload yang dari samping.... (dapet dari temen yg kerja diperakitan Yamaha)
rasanya Yamaha ingin membuktikan MOTOnya:
Yamaha Semakin di depan!
CMiiW
just me
Pilihan yg sulit antara CBX and Frazer.....
Tapi dr penampakan visual,si Frazer lbh gagah ...
Ada yg tau bocoran harganya kira2?
Avanza@2006>>>
Innova@2010>>>
EcoSport@2014 >>>
Black VRZ@2016
Kalo menurut ane sih so far fazer yg plg ganteng, tapi kok lampu nya masih bulet gt la.. Ga skalian aja pake tudung, mirip headlamp b-king nya suzuki.. Kan cakep tuh bos.. Hehe.. Emg dah diproduksi ymki ya? Kok udah ada brosurnya bos?
Kalo bisa sih scopie kaga distop. Jadi lengkap vixion, scopie, ama fazer.. Tapi scopie kalo mo survive, kudu major change.. Hehe..
soal harga belum tahu, karena Fazer sedang dalam proses Uji type, wong SUZUKI Indomobil yang jelas-jelas sudah start launching JUALAN MOGE diem-diem aja gak dibeberkan secara pasti berapa harga OTR nya...
harga yang diberikan semua Off TR.
lihat nih pameran produk MOGE SUZUKI INdonesia, Intruder LC250CC aja yang dipasarkan lagi ternyata koq di webnya tidak dicantumkan? tapi sempet liat ada di showroomnya.
Mungkin lagi itung-itungan harga, soalnya kritikan harga Intruder LC250CC (cc kecil/bukan masuk klasifikasi moge menurut SAMSAT/POLRI) yang 68jt-an sampe juga ke Om Subronto rasanya, and harusnya cuma kena BEA Masuk 50% tanpa kena PPnBM yang 75% dan BBN juga harusnya cuman 3,5%.
(dulu Intruder LC250CC kena Bea Masuk+PPnBM+BBN = 50%+75%+10%)
semoga Intruder LC250CC gak kena Pajak Barang Mewah yg 75%, jadi perkiraan harga cuman saya pribadi cuman sekisaran harga Phantom saja. semoga
http://www.suzuki.co.id/suzuki_motorcyc ... tccode=MC1
bantuin doa dunks
just me
[/quote]
bantuin doa dunks
just me
[/quote]
waduh...
makin penasaran nih...
kapan yah kira2 si fazer atau banditnya muncul..?
CBX 250 Twister
Capacity: 249cc
mimpi kali yeeeee........
hmmm, Fazer positif neh?
awas ye kalo gak.... he3x.
bukan vixion kali om, vixion basis mesin-nya udah water cooled, fazer masih air-cooled,vLo wrote:nah klo fazer ini katanya sih v-ixion 250 cc yak, dgn sedikit face lift
mesin ampir sama kaya scorpio cuma di bore-up
fazer250 = YBR250 tinggal pilih buatan china ato brazil
http://www.yamaha-motor.com.cn/mc/ybr250/index.html
http://www.yamaha-motor.com.br/Cmi/Pagina.aspx?983#
beneran mo masukin suzuki GSF250
terakhir diproduksi th 1995 bukan
ternyata ada juga GSX250FX produksi terakhir 2003
mesinnya setipe, akankan ini yg masuk?
2002-2003 Suzuki GSX250FX (BA-ZR250C) specifications (Japan)
Engine Type: Water-cooled inline-4 DOHC 4-stroke, 16 valves
Cylinder Volume: 249 cc
Bore x Stroke: 49,0 x 33,1 mm (1.929 x 1.303 in.)
Compression Ratio: 12,2 :1
Power output: 40 ps (29 kW)/ 14.000 rpm
Torque: 20 Nm (2.1 kg-m)/ 13.000 rpm
Fuel tank capacity: 15,0 liter
Fuel consumption: 39,0 km/l (60km/h)
Carburetor: CVKD30
Lubrication system: Wet sump
Engine oil capacity: 2,6 liter
Starting System: Electric start
Ignition type: Full transistor
Transmission type: 6-speed constant mesh
Gearshift pattern: 1-down, 5-up
Secondary drive type: Chain
Primary reduction: 3.291
Final reduction: 3.428
Gear ratios: 2.600/1.789/1.409/1.160/1.000/0.892
Clutch type: Wet multi-plate type
Frame type: Steel pipe double craddle
Front suspension: Telescopic (39 mm)
Rear suspension: Swingarm
Overall Length: 2 070 mm (81.5 in.)
Overall Width: 735 mm (28.9 in.)
Overall Height: 1 055 mm (41.5 in.)
Wheelbase: 1 400 mm (55.1 in.)
Seat Height: 745 mm (29.3 in.)
Ground Clearance: 150 mm (5.9 in.)
Dry Weight: 151 kg (332 lbs)
Caster: 25°
Trail: 93 mm (3.66 in.)
Front tire size: 110/70-17 54h
Rear tire size: 140/70-17 66h
Front brake: Single disc, diameter 300 mm
Rear brake: Single disc, , diameter 230 mm
Turning radius: 2,7 meter
Steering angle from left to right: 35°
Seating capacity: 2 persons
Recommended retail price: 520,000 Yen (2003, Japan)
Carburetor: CVKD30
Caster: 25°
beeuuu,.. gaya Thunder abis. he3x.
btw, tuh Fazer mirip Tiger revo...
beda monoshock ama buntut aja dari segi tampilan...
29 ps??spin022 wrote:ternyata ada juga GSX250FX produksi terakhir 2003
Carburetor: CVKD30
Caster: 25°
Wow mirip2 ama ninja 250r dong???
Mantaaaaafff.....!!!!!!
wah bentuknya gak ada yang sporty, karena bentuknya kayak biasa saja. kayak ninja.
Tiger revo yg mirip fazer...123stu wrote:beeuuu,.. gaya Thunder abis. he3x.
Kapan dipasarkan di Indonesia?
Ah, gosipnya udah dari kapan tau, ga masuk-masuk ke Indo..
1+1 = ?
- Daily Vehicle: Ipin - Ipah
Bukti bahwa AHM gak ada inovasi. Design-nya aja niru merek lain.azizdth wrote:Tiger revo yg mirip fazer...123stu wrote:beeuuu,.. gaya Thunder abis. he3x.
ga jelas masuk nya ke indo...
Yang jelas cuma Nija 250 doang .............
The Red
- Daily Vehicle: toyota fans boys
semoga semuanya keluar di sini
ha3x. gw udh nyangka bakal dikomen gini...TUFF Stough wrote:Bukti bahwa AHM gak ada inovasi. Design-nya aja niru merek lain.azizdth wrote:Tiger revo yg mirip fazer...123stu wrote:beeuuu,.. gaya Thunder abis. he3x.
ok, but who come first in Indo,bro?
so, who laugh the end?
hehehe... iya ya
fazer tuh jadi gak ya di indo
kok dari tahun lalu .. cuma beritanya aja
hehehe... iya ya
