HONDA "Edix" means 'Edit' and 'Six'
a distinctive new minivan featuring six independent seats in two rows of three (‘3x2’ layout), equipped with one of two engines. One is a 2.0-liter DOHC i-VTEC the other is a 1.7-liter VTEC engine
Exterior Dimensions: 4285mm (L) x 1795mm (W) x 1610mm (H) (270mm shorter, 100mm wider, 20mm taller than Stream)
Interior Dimensions: 1875mm (L) x 1535mm (W) x 1230mm (H) (795mm shorter, 75mm wider than Stream)
Wheelbase / Track: 2680mm (40mm shorter than Stream) / 1520mm (F&R)
Engine Choice: 1668cc 16V SOHC VTEC & 1998cc 16V DOHC i-VTEC (same as on Stream)
Transmission: 4Speed Auto (1.7L) & 5Speed Auto (2.0L)
Weight: 1260Kg - 1360Kg (~200Kg lighter than Stream)
Turning Radius: 4.9m (1.7L) - 5.2m (2.0L) (vs 5.3m - 5.5m for Stream)
