Tanya Chrysler PT Cruiser
Chrysler PT Cruiser
Performance & Efficiency
2,429 cc 2.4 liters 4 in-line engine with 87.5 mm bore, 101 mm stroke, 9.5 compression ratio, double overhead cam and four valves per cylinder
Unleaded fuel
Fuel economy EPA highway (l/100km): 9.4
Multi-point injection fuel system
Main 57 liter unleaded fuel tank
Power: SAE and 112 kW , 150 HP @ 5,200 rpm; 164 ft lb , 222 Nm @ 4,000 rpm
Handling, Ride & Braking
Two disc brakes including two ventilated discs
Spacesaver steel rim internal spare wheel
Strut front suspension with stabilizer bar independent with coil springs , beam rear suspension rigid with coil springs
Exterior & Aerodynamics
Body side molding
Front and rear black bumpers
Driver and passenger internally adjustable black door mirrors
External dimensions: overall length (mm): 4,288, overall width (mm): 1,704, overall height (mm): 1,600, wheelbase (mm): 2,616, front track (mm): 1,481, rear track (mm): 1,478 and curb to curb turning circle (mm): 11,125
Complex surface lens halogen bulb headlights
Heat reflective glass
Metallic paint , black paint , gloss paint , pearl paint
Fixed rear window
Tinted glass on cabin, rear and side
Weights: curb weight (kg) 1,417, gross trailer weight braked (kg) 454 and max legal load (kg) 392
Windshield wipers with variable intermittent wipe
Interior
Air conditioning
Fixed mast antenna
Audio system
Cargo area cover/rear parcel shelf
Cargo capacity: all seats in place (liters): 538 and all seats removed (liters): 1,812
Clock
Dashboard and floor full console with open storage box
Delayed/fade courtesy lights
Front seats and rear seats cup holders
Door ajar warning
Door pockets/bins for driver seat, passenger seat and rear seats
Floor covering: carpet in load area
Driver and passenger front airbag
Bucket seat
3-point reel height adjustable front seat belts on driver seat and passenger seat
Front seat center armrest
Lockable glove compartment
Height adjustable two head restraints on front seats
Internal dimensions: front headroom (mm): 1,026, rear headroom (mm): 1,006, front hip room (mm): 1,372, rear hip room (mm): 1,372, front leg room (mm): 1,041, rear leg room (mm): 1,031, front shoulder room (mm): 1,387 and rear shoulder room (mm): 1,369
Low fuel level warning
Power steering
Front power windows with two one-touch , rear power windows
3-point reel rear seat belts on driver side, passenger side and center side
Split bench asymmetrical three rear seats
Rear view mirror
Front seat back storage
Cloth seat upholstery
Seating: five seats
Six speakers
Plastic steering wheel
Tachometer
Driver and passenger vanity mirror
Ventilation system with recirculation setting
http://www.automobilemag.com/am/2001/ch ... tions.html
Pertanyaannya : Berapa pasarannya sekarang? di mana bengkel yang bisa pegang mesin chrysler (katanya sama mesinnya dengan dodge neon).
Re: Tanya Chrysler PT Cruiser
Gw pernah liat iklan usednya bbrapa waktu yg lalu di kompas, utk yg th.2002 di kisaran Rp.180 jt.
Btw, msh menyangkut PT Cruiser ini, di luar kan udah keluar versi faceliftnya kan? Di Indo gimana tuh? Udah diluncurin yg versi faceliftnya? Ada yg ngikutin ga model model yg diluncurin oleh dealer Chrysler Indo? Kok kayaknya ga jelas ya model baru apa aja yg mrk luncurin utk taon ini? Kesannya mrk (ATPM Chrysler) di Indo kurang menpublikasikan produk mrk, bandingkan dgn ford yg lbh gencar.
Chrysler...hati2 bro...bentar lagi bisa bangkrut tuh merek.
emangnya ATPM Chrysler masih ada ya bro? Kalo dulu kan PT Daimler Chrysler Indonesia kan?TiongBahru_Ahbeng wrote:Gw pernah liat iklan usednya bbrapa waktu yg lalu di kompas, utk yg th.2002 di kisaran Rp.180 jt.
Tapi semenjak Benz pisah dengan Chrysler apa masih ada tu ATPM nya?
2002 180jt? Wah, kalo liat dari valuenya sih harganya overpriced banget. Harga segitu sih cuma beli eksklusifitasnya doang.
Thanks bro.TiongBahru_Ahbeng wrote:Gw pernah liat iklan usednya bbrapa waktu yg lalu di kompas, utk yg th.2002 di kisaran Rp.180 jt.
Iya kayaknya, sebab pas lagi searching foto2 di flickr, ada yg lampunya beda dgn yg gue posting.
Kalau soal ATPM, gue malah ga tau kalau di Indo ada, sebab setau gue yg PT Cruiser ini didatangkan oleh importir umum kan?
Thanks bro atas infonya.FortunerMan wrote:Chrysler...hati2 bro...bentar lagi bisa bangkrut tuh merek.
Sebenarnya kalau emang bener2 mau bangkrut, makin enak tuh beli mobilnya, harganya tinggal kesepakatan aja hihihihi....kalau soal pemeliharaan itu bisa diatasilah.
Gw jg krg tau deh mengenai keberadaan ATPM Chrysler di Indo, gw ga pernah ngikutin mrk sih.Risol1 wrote: emangnya ATPM Chrysler masih ada ya bro? Kalo dulu kan PT Daimler Chrysler Indonesia kan?
Tp bentuk PT Cruiser itu unique loh, waktu dulu pertama kali diluncurin, gw suka jg modelnya, cm ga sanggup beli aja.
Gw br liat iklan PT Cruiser ini lg di Kompas, kalo ga salah yg edisi terbitan kemaren, disana tercantum PT Cruiser th.2002 mo dijual seharga Rp.120 jt.
Perbedaan harga jual yg cukup tinggi kalo dibanding dgn harga jual yg di iklankan sebelumnya (yg di kisaran Rp.180 jt), sptnya penjualnya adalah org yg sama, meliat perbedaan harga jual yg cukup jauh (sebelumnya Rp.180 jt, en skrg Rp.120 jt utk taon yg sama), gw jd curiga nih mobil ada masalah, mungkin udah pernah kecelup banjir, sehingga membutuhkan biaya besar utk membetulkannya.
