Yamaha Scorpio 250cc : kayak apa ya...
Mungkin ada yang sudah tau tentang bakal munculnya Scorpio 250cc ?? Pls di share infonya disini.. gambar dan specnya juga kalo sudah ada...
Norival Fuel Enhancer
FB (id : Torry Parantoro)
hp/WA : 081328516999
Re: Yamaha Scorpio 250cc : kayak apa ya...
kyknya klo dari isu ya emang gitu cmn mngkin basisnya dari yamaha fazer 250cc yang varian fazer dengan cc paling kecil...
Wah.. Perkembangan motor indonesia semakin oke ya.. Banyak pilihan yang buat kita sendiri bingung hehe.. Kalo isunya bener mungkinkah bentuk sama hanya rubah cc aja? Atau kah seperti kawa 250cc full fairing. Tp jangan kaya thundie 250 yg kurang gaungnya. Kapan ya pulsy 220 masuk indo hehe
bertindak sebelum berpikir itu kebodohan ... berpikir sebelum bertindak itu kebijaksanaan
- Daily Vehicle: Ipin - Ipah
co-pas dari milis:
Code: Select all
JYM250-2
L×W×H = 2025mm×760mm×1065mm
Seat height = 805mm
Wheelbase = 1360mm
Minimum ground clearance = 175mm
Weight (with oil and a full fuel tank) = 152kg
Maximum speed = 123km/h
Minimum turning radius = 2.4m
Engine type = Air cooled, 4-stroke
Cylinder arrangement = Single cylinder
Displacement = 249cm3
Bore &stroke = 74.0mm×58.0mm
Compression ratio = 9.80:1
Maximum horse power = 15.4kW(7500r/min)
Maximum torque = 19.7Nm(6500r/min)
Starting system type = Electric starter
Engine oil capacity = 1.5L
Fuel tank capacity = 19.2L
Carburetor Type/Fuel supply = FI [Fuel Injection]
Ignition system type = T.C.I
Battery voltage/capacity = 12V 6Ah
Clutch type = Wet, multiple-disc coil spring
Transmission type = Constant mesh 5-speed
Gear ratio = 2.571/1.684/1.273/1.040/0.852
Frame type = Double cradle
Tire size(Front/Rear) = 100/80-17M/C 52S / 130/70-17M/C 62S
Brake type(Front/Rear) = Single disc brake / Drum brake
Suspension type(Front/Rear) = Telescopic / Bottom link swing arm
·Headlight〠Auxiliary light = 12V〠35W/35w×1〠12V〠5w×1
Weks layak di tunggu nih...
Gw naksir berat punya motor 250 cc.
Setelah Tiger di jual,kayaknya belum punya minat dg motor2 laki,walaupun sebelumnya sempat naksir V-ixion.....
Ganteng bgt nih motor,,kalopun 'down grade' dari Fazer...
Avanza@2006>>>
Innova@2010>>>
EcoSport@2014 >>>
Black VRZ@2016
Kalo search di mbah google sih, katanya base-nya YBR-250.
wah ada YBR ada FAzer....?....tp klo diliat bentuknya sama bgt yah..cmn beda nama tuh?
Kira2 harganya brapa ya..
Kayanya sih dah pasti diatas 20 jeti..bisa sama ama tiger CW atau malah dibawahnya ...masalahnya lum ketauan teknologi apa yg diusungnya?...
JESKONENG wrote:Kira2 harganya brapa ya..
lagi2 no rear disk break.....
YAmaha ogah pake cakram belakang ya?
kayaknya kalo sudah diatas 200cc, disc brake itu suatu keharusan ya... P-220 aja udah pake...
ryanperdana wrote:kyknya klo dari isu ya emang gitu cmn mngkin basisnya dari yamaha fazer 250cc yang varian fazer dengan cc paling kecil...
sebentar lagi di India sudah ada varian fazer terkecil 150cc FZ15
150 cc ? Bentuk knalpotnya [cencored] banget ya... tampilan keseluruhan lebih kekar daripada V-ixion ?? Ban lebih gemuk....
Waduh.. kalo Scorpio 250 cc muncul, bakal nambah 1 lagi nih jenis motor yang gak bisa dilewatin oleh P-200 di jalan raya, selain Ninin 150 dan 250.. hehehehe..... kalo Scorpio yang 225 cc sih udah lewaaat... tapi yang 250 pasti lebih kenceng lagi neh....
yupee...150cc air cooled...nampaknya seperti injeksi tapi belum ada kejelasan...
spek belum ada...cuman katanya sih bakal diposisikan di bawah r15 yang notabene ada vixion di kasih fairing r1...
so kalo di Indonesia bakalan keluar ini ga yah ? atau bentuk begini dikasih mesin scorpy...atau fazer 250cc bakal ganti kostum...seperti ninja 250...yang secara keseluruhan ganti bentuk...
kalo ini keluar di Indonesia 150cc dengan harga di bawah vixion...mudah2an tidak injeksi...kayanya aku mau beli hehehe
Baru ngeh, ada om p4nd4.
kapan yah Scorpio 250 akan muncul ??? mudah2an misih ada waktu untuk up-grade P-200 ku, sehingga saat Scorpio 250 mulai berkeliaran di jalan, mereka gak bisa mengasapiku... setelah port n polish, CDI BRT Smart Click...PJ naik dari 17,5 menjadi 22,5...sbentar lagi perbandingan gir dari standarnya 14/38 mau kuganti jadi 15/38.... lalu apa lagi ya ??? Bore-up ?? jadi 250 cc juga ?? Pake piston apa yah ??
TUFF Stough wrote:Baru ngeh, ada om p4nd4.
ola bro... lama ga jumpa...hehehe gimana kabarnya ?
bro p4nd4, udah makin tinggi nih ilmunya, baru turun gunung, apalagi abis ngalahin siapa tuh? Tao Lung?
met gabung di rimba persilatan biker lagi bro, hehehe, ditunggu nih info2 dan ulasan2 gressnya....
piston suzuki carry....JESKONENG wrote:kapan yah Scorpio 250 akan muncul ??? mudah2an misih ada waktu untuk up-grade P-200 ku, sehingga saat Scorpio 250 mulai berkeliaran di jalan, mereka gak bisa mengasapiku... setelah port n polish, CDI BRT Smart Click...PJ naik dari 17,5 menjadi 22,5...sbentar lagi perbandingan gir dari standarnya 14/38 mau kuganti jadi 15/38.... lalu apa lagi ya ??? Bore-up ?? jadi 250 cc juga ?? Pake piston apa yah ??
wakakkkakkakka...
iyya, katanya AHM juga mau masukin CBU 250cc?
safe going safe coming
Kalo Yamaha, secara bisnis mungkin YMI belum akan mengeluarkan varian baru sport 4 tak di Indonesia deh dalam waktu dekat. Untuk jamah market di sini masih mumpuni pake Scorpio dan Vixion,
Honda ? AHM masih laku koq Tigi REVO dan Mega Pro, mungkin 5 - 10 taun kedepan kali deh ..
Kalo ngga mentok2 Tiger REVO II kali yaks ( Tiger lama cuman di tambahin Oil Cooler dan ganti Striping ) HE 3x.
Piss ah.
Piss ah.
Dulu Kesekolah naik Bajaj, Kemarin Kekampus naik Bajaj, Sekarang Kerja naik Bajaj..... Hidup Bajaj.
Namanya isu, tetap aja isu selama pihak ATPM-nya belum angkat bicara.
Betul bro,
Sayangnya knp perkembangan Varian Motor 3 merek Kawakan, Suzie-Hond-Ymh, terkesan tanggung dan di batas-batasin (teknologi dan partsnya)
Sekalinya ada harganya pun di patok gak kira2....
Pengen banget ngeliat Suzie keluarin Sport lagi CBU, (kayak FXR dulu )
Pengen juga liat AHM keluarin varian Sport yang baru dan keren gak cuman 160 - 200, di ulang-ulang dari 90 an.
Yang sekarang YMH lebih sedikit Agresif. Salut buat PIO tapi upgrade ke CW nya kenapa gak sekalian di usung Disc Brake Blkg. Vixion canggih, sayang... menurut gue sih harusnya ban bawaan pabriknya di besarin soalnya keliatan cingkrang banget .... (itu alesan gue juga beralih mo beli vixie jadi pilih pulsie). yah gitulah serba nanggung.
Salut juga bwt KAWASAKI .... bener2 250 nya idaman banget ... tapi weks harganya gak kuat...he3x
Tapi klo liat bentuk mesinnya, mirip scorpie yah.. Tapi gpp deh.. Yang 225cc aja kencengnya dah minta ampun, apalagi 250.. Hmm.. Kira-kira kalo jadi keluar, AHM punya senjata apa yaaa..
