ASKing = TVS apache 160 RTR
kudeta
Post by kudeta »
:upss:
@all bikers
ada yg punya tvs apache RTR 160 ga or perna make ni motor...
plz di review di sini dnk,..(interest mode = on) :e-think: plus minusnya...
( n gw ada tny2 ma salesny) mang skrng ada promo cash back y, ada yg tau?
:thanks: :thanks:
lon3lyboyx
Re: ASKing = TVS apache 160 RTR
Post by lon3lyboyx »
Sorry bro.. Ane bantu technical specification nya aja yah..
TVS Apache RTR 160 technical specifications :
Engine
Type : 4 Stroke, 159,7cc, single
Maximum Power : 11.19kw (15.2bhp) @ 8500rpm
Maximum Torque : 13.1Nm @ 6000rpm
Bore x Stroke : 62mm x 52.9mm
Compression Ration : 9.5:1
Carburetor : Mikuni BS-26
Valve Train : 2 valves, single cam (SOHC)
Valves per Cylinder : 2 valves
Power to Weight Ratio : 111.76bhp / ton
Starting : Electric & Kick Start
Ignition : IDI-Dual Mode Digital Ignition
Transmission
Clutch : Wet, Multi-plate
Gear : 5 speed
Chassis
Type : Double Cradle
Suspension
Front : Telescopic Fork, 105mm Stroke
Rear : Monotube Inverted Gas Filled Shoc (MIG) with Spring Aid
Brakes
Front : 270mm Petal Disc
Rear : 130mm Drum
Wheels & Tyres
Rim Size - Front : 1.85 x 17"
Rim Size - Rear : 2.15 x 18"
Tyre Size - Front : 90/90-17"
Tyre Size - Rear : 100/80-18"
Fuel Tank Capacity : 16.0 L
Reserve : 2.5 L
Usable Reserve : 1.7 L
Dimensions
Length : 2020 mm
Width : 730 mm
Height : 1050 mm
Wheelbase : 1300 mm
Saddle Height : 790 mm
Ground Clearance : 180 mm
Weights
Kerb Weight : 136 kg
Courtesy of : http://tvsapache.com/thebike.aspx
hellcats
Post by hellcats »
1. Akselerasi Ok
2. Tenaga terbesar dikelasnya
3. Suara mesin & knalpot ngga nyangka halussss banget.
4. built quality termasuk rapih dibandingkan dgn pulsar.
5. Harga dibawah pulsar 180. Cash dapet potongan kalo gak salah 300rb
jadi 16,2 jt
6. spedo digital.
7. shockbreaker belakang empuk
8. cukup isi premium :D
1. itu batok lampu ato helem
2. lampu depan cuma 1 (sekarang rata2 2 buah lampu)
3. di india dapet engine guard disini kaga dapet tuh.
dari test ride baru nemu + / - itu.
ada yg bisa tambahin???
Overall mo beli ni motor buat sehari2 gak salah jadi pertimbangan.
Nyaman, stabil, akselerasi kenceng kurang apa lagi
spin022
Post by spin022 »
hellcats wrote:+ :
1. Akselerasi Ok
jadi 16,2 jt
6. spedo digital.
iya bro, temen gw yg udah test minggu kemaren di PRJ juga bilang kaya gini, sayang diler-nya dikit banget, bahkan dibanding ama bajaj....
kudeta
Post by kudeta »
iya,bro gw interest bgt ma built qualitynya =superb..bodynya jg kokoh n berotot sana sini (kaya megi habis fitnes)..soal mileage, katanya skitar 55kmpl..gw rasa si paling 45 lbh....
mmm...diler emang tg jd kendala..dikit bgt, but g ada cek d situs tvsnya,dia ternyata gandeng bengkel2 lain..worted gak ya??di jakarta si ada sekitar 7bengkel gt (ga trmasuk diler)...
engine guard yg di bawah itu kan maksudny?? dapet koq n gw ditawarin cash back 600rb...
gmana guys, worth for money gak ni motor?
batok lampu = helm ,hehehe gw awal liat jg kaget.gede bgt..perasaan di gambar ok2 aj proporsiny..
hellcats
Post by hellcats »
Maksud bro engine scoop ya?? yg dibagian bawah mesin itu?
kalo engine guard maksud ane yg kayak pagar tanaman itu
biar kalo jatoh lebih aman
soalnya g tanya kok ga ada engine guard, kata orang tvs emang ga dapet yg disini
kudeta
Post by kudeta »
oh iy, bener yg kayak pipa besi itu,..iya ga dapet.
biasanya yg pake di india sana include besi pelindung deket rante, buat kain saree gt klo ga salah...rata2 motor sono kudu pake ni 2 item besi..
but buat gw pribadi emang klo emang dapet ,mungkin ga dpake jg..
di jkrt ampe sekarang cuma perna ketemu sekali yg make Apache ini..warna kuning terang..jd dr jauh seberang uda keliatan.
ada 1 problem ni yg katanya lumayan menggangu..yaitu vibration klo dibawa di atas 60kmph..ada yg perna coba bawa ampe di atas itu ga??
spin022
Post by spin022 »
kudeta wrote:iya,bro gw interest bgt ma built qualitynya =superb..bodynya jg kokoh n berotot sana sini (kaya megi habis fitnes)..soal mileage, katanya skitar 55kmpl..gw rasa si paling 45 lbh....
yg disini ya bro...
http://www.tvsmotor.co.id/ind/icarenetwork.php
diler sejabodetabek cuma 4
kudeta
Post by kudeta »
[/quote]
yg disini ya bro...
diler sejabodetabek cuma 4[/quote]
iy bner,diler mang cm 4 ...jauh2 lg.
but tabel dibawahny kan ada 10 bengkel servis buat jabotabek..CMIIW... cuman gada yg di jak ut.
kudeta
Post by kudeta »
ini fotony,tp yg versi Fuel Injection....
hanx13
Post by hanx13 »
nice bike...:beer:
it's rumoured that TVS has a deal with Suzuki...
bener gak yah?
hellcats
Post by hellcats »
dengar2 di india tvs memang menjalin kerjasama dengan suzuki bro
TUFF Stough
Daily Vehicle: Ipin - Ipah
Post by TUFF Stough »
Bajaj juga dulunya dengan Suzuki, sebelum terakhirnya dengan Kawasaki.
Makanya lampu belakang Pulsar bisa mirip dengan SV650-nya Suzuki.
wisedog
Post by wisedog »
gw coba di prj, handling zig zag lebih berat dari cbr alias kurang lincah alias lbh berat. ga tau dibanding yg lain sih. tapi tarikan oke(cm gigi 2) trek ga mendukung. worth de money.
Mixer
Post by Mixer »
semua masih pada test drive ya..belum ada yg beli neh? pdh modelnya ok lho (dibanding sodaranya si bajaj) ..menurut ge emang berotot neh motor, dr PRJ thn lalu juga udah nampang, cm belom ada harganya. saingannya Mega pro dunk secara sama2 160cc.
spin022
Post by spin022 »
hellcats wrote:+ :
1. Akselerasi Ok
jadi 16,2 jt
6. spedo digital.
tambah lagi karburator mikuni bs26 sama kaya FU, thunder125, spin&skywave....
:D :D :D
darkwolf
Post by darkwolf »
hellcats wrote:+ :
1. Akselerasi Ok
jadi 16,2 jt
6. spedo digital.
Kurang dibeli aja bro :ngacir: :ngacir: :ngacir:
nurjambul
Post by nurjambul »
newbi di seraya .....
udah beli sebulan yang lalu .....
mantap bro, better dari minerva cbr atao Swift 2000 ....
better dari megapro, thunder, dan pulsi
karena g udah coba meraka semua
suara halus, tenaga besar amat dan body gahar ...
bukan kaya pulsi yang elegant, tapi emang ini motor dibuat gahar banget ....
ibarat kalo terbang, pulsi elegant kaya bango, apache gahar kaya elang .... mantaf lah bro
cuman emang gak imbang saya kedok kepalanya yang keliat besar, dan tangki kalo diisi penuh, kaya berat didepan ..... mungkin maksudnya tvs biar arodinamis sama ngak sering2 mampir ke spbu ...tapi better lah ....
irit bro ..... 1 : 54 km pake biasa di jakarta yang stop-go mulu
masalah purna jual .... lagi ditingkatkan bro .... katanya tahun ini bakalan bikin seratus dealer dan service seluruh Indonesia ..... jangan samain ama honda yang udah 45 tahun di sini bro ...
agustus ini di jabotabek yang mau opening ada yang di serang sama yang di kalimalang tanggal 26 agustus nanti.
nih motor punya harapan cerah bro .... apalagi dah ada pabrik besar di kerawang .... icon artisnya juga iwan fals, udah diresmiin ama presiden sby .... dan teknologi ama kualitas ngak kalah ama motor jepang .... tahun depan yang model sport irit ada ro ... namanya TVS flame 125 cc 3 katup 2 ignition .... mantap bro ..... terus bakalan mau dibuat bebek sport nya juga bro .... kata orang dalem tvs, lagi R & D lah bro ....
nah ... daripada jadi orang yang kesekian juta yang punya motor ini .... mendingan sekarang bro ....
orang tuh lagi pada nunggu kesan dan pesan yang udah make motor ini .... ada kehati-hatian untuk beli motor ini ..... jadi mending pada ngeliatin forum ini soal pendapat orang laen yang udah pake ..
so langsung aja beli bro .... ngak nyesel dengan duit 16,5 jt loe dapet segalanya bro .... ntar kalo dah naek kaya pulsi .... nyesel bro .... untuk kredit .... dah dipegang ama adira finance ... so aman lah bro ..
kekurangannya nih motor ...
suka diliatin orang ...... :e-snooty:
azizdth
Post by azizdth »
Serius bro flame mo masuk, keren tuh, walo sempet tersandung masalaha hakcipta (penggunaan dua busi yg di klaim milik bajaj, tp menurut sumber terbaru, sekarang flame satu busi). kira2 taun depannya kapan yah, awal, tengah apa akhir?
nurjambul
Post by nurjambul »
lah ... tvs apache juga dah 2 ignition ....
coba aja buka busi-nya ... ada 2 jarum di kepala businya .... aneh ....
tvs flame dah memperbaiki diri biar ngak dikira jiplak bajay punya ....
dia sama pake teknologi apache ....
katanya tahun besok, pertengahan 2009
baca dari forum sebelah ad cerita nih ...
katanya:
ada bengkel yang punya tugas ngebelah mesin motor untuk pameran prj kemaren, diantaranya TVS Apache sama Y*M*H* Vixion, nah bengkel itu bilang kalo ngebelah mesin Apache lebih keras dibandingkan sama Vixion yang rada empuk .... dia bilang, " kalo orang ngak ngelihat brand dan tau kualitas mesin motor apache ... pasti orang pilih nih motor !!!
yah gitu lah ....
tunggulah lah existensinya si TVS .... semoga awet
azizdth
Post by azizdth »
good inpoh boss :beer:
TVS pake dua busi atau pake satu busi dgn dua kepala? bingung, maklum ga ngarti tehnik, tp whatever lah, mo dua busi, mo satu busi dua kepala, yg penting gampang sparepart, tarikan yahud, dan irit. waktu pertama liat flame, udah naksir, motor TVS dgn disain paling bagus kata ane mah.
kabar2i kalo ada info terbaru ttg TVS ya bos, lg mo komparasi nih ama bajaj, bwt pertimbangan tunggangan taon depan.
p4nd4
Post by p4nd4 »
azizdth wrote:good inpoh boss :beer:
TVS Apache 1 busi bro...pasti...yang tvs flame pake 2 busi juga udah ditarik dari marketnya di India..soalnya diaduin Bajaj menciplak teknologi dan terakhirnya kayanya tvs kalah makanya tvs flame yang sudah keluar dengan 2 busi di tarik dari pasaran dan diganti dengan yang 1 busi lagi
spin022
Post by spin022 »
1 busi 2 kepala??? gak bisa ganti busi merk lain dong...?
bayker
Post by bayker »
nurjambul wrote:lah ... tvs apache juga dah 2 ignition ....
katanya:
yah gitu lah ....
kata temen saya nih bro, katanya lho :
Lebih empuk belah "duren". :upss:
azizdth
Post by azizdth »
Mungkin maksutnye, bukan busi dua kepala ya, gimana coba bentuknya? Tp kali ada dua jack (kalo istilah brg elektro) yg bertemu di satu busi :e-think: ...ah tau lah, ga ngerti ane ttg busi :e-doh:
tadi pas baca ada dua jarum di kepala busi, sekilas yg terlintas pertama dalam pikiran ane tuh, busi dgn dua kepala, hehehe, norak yah ... :e-snooty:
kaya attachment nih yg dalam pikiran gw...hihihi dasar nyubi.... :2gunfire:
jgn di hina yah, maklum ane kan ga ngarti motor, hehehe... :oops:
