Serbuan Dinamik
ivanov
Serbuan Dinamik
Post by ivanov »
Wah motor malaysia dah masuk ke Indonesia.Ini salah satunya.Bentuknya keren.Bisa jadi pesaing Suzuki Satria,basisnya mesin dari kawasaki leo
Code AS120C-A1MY
Overall Length 1935 mm
Overall Width 640 mm
Overall Height 965 mm
Wheel Base 1280 mm
Road Clearance 120 mm
Dry Weight 98 mm
Fuel Tank Capacity 4.6 L
Fuel Consumption n/a
Front Tyre 70/90-17 38P
Rear Tyre 80/90-17 44P
Max. Power 12.5 kW @ 9,000 rpm
Max. Torque 14.1 N-m @ 8,000 rpm
Engine
Type 2-stroke, single cylinder
Bore X Stroke 54.0 x 51.8 mm
Displacement 118 cc
Compression Ratio 7.3 : 1
Carburetor Mikuni VM22
Ignition System DC-CDI
Starting System Kick starter
Cooling System Air cooled
Lubrication Force feed lubrication
Transmission
Type 6-speed return
Clutch Wet, multi disc
Primary Reduction Ratio 3.043 (70/23)
Final Reduction Ratio 2.785 (39/14
Driving System Chain
Chassis
Type Pipe backbone
Front Suspension Telescopic
Rear Suspension Swing Arm, Mono-shock
Front Brake Disc
Rear Brake Disc
Electrical System
Battery 12V 3Ah
Speed is a game??!!
clurut
Post by clurut »
Btw merk nya apa tuh bang ?
ivanov
Post by ivanov »
Modenas mereknya.Kualitasnya gimana ya?Apa sudah setara dengan motor jepang?
Speed is a game??!!
indy
Post by indy »
Mesinnya basicnya diambil dari Kawasaki Leo, tapi motor kawasaki ini rangka teleskopik depannya panjang (ayam jago) bukan pendek seperti sok bebek. Denger-denger sih gabungan dari berbagai pabrikan motor.
atjep
Post by atjep »
Bisa lihat gambarnya di mana ya???
sori koneksi-nya lagi lelet jadi sya ikutan lelet tidak bisa gambar yg diattach hehehe :lol:
BTW kira2 berpa duit yak???
Equalizer
Post by Equalizer »
sayang hanya 118 cc ya, bukan 125 cc :wink:
deanz
Post by deanz »
2 tak lho ooom
Yongis_CD
Post by Yongis_CD »
hmm satu lagi biang polusi masuk............
menyedihkan.......................
maap subyektif...............
id
Post by id »
bukannya motor 2 tak uda mo stop produksi?perasaan kok masih banyak new model yah? mana yang bener nih? :?
ivanov
Post by ivanov »
Wah bebek ini kabarnya sdh lolos uji emisi EuroII.Tapi kynya kalo euro II sdh hrs pake injeksi.Gak tahu juga.
Speed is a game??!!
