Kegunaan Scangauge......?
kutkuy
Post by kutkuy »
Halo SMers, ada yg pakai product ini? Tolong si share donk keluh kesahnya bagaimana... apakah worthed install barang ginian?
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used
* Trip Fuel Economy
* Distance to Empty
* Time to Empty
* Fuel to Empty
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
* Fuel Economy
* Fuel Rate
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off the "Check Engine" light
* Tells you when vehicle is "Ready" to pass OBDII testing
* Make and store up to 10 rewritable special codes
to send to the vehicle computer
SALE SALE SALE!! BROQUET cuma 70rb!!! BARU! SEGEL!!
broquet.bandung et yahoo dot com
kutkuy
Re: Kegunaan Scangauge......?
Post by kutkuy »
calvin99
Post by calvin99 »
wuih canggih juga tuh..
pasangnya nyambung kemana yah?
emang ada yg jual bro disini?
HyundaiTucson
Post by HyundaiTucson »
Saya juga mau beli ini produk. Agen nya di Jakarta di Tanjung Duren. Cuma sayang nya reading untuk fuel consumption tetap MPG.
Cheers,
HT
kutkuy
Post by kutkuy »
waaa.. males banget kalo MPG harus di convert...
tapi liat2 di google udah ada yg diganti ke matric tuh yg versi baru
kutkuy
Post by kutkuy »
calvin99 wrote:wuih canggih juga tuh..
nyambung ke ECU, jualnya di daerah tanjung duren, harga lupa sekitar 1,8jt - 2jt lah
HyundaiTucson
Plug and play dengan hanya meng-konek socket yg tersedia ke OBDII port. Kalau Tucson OBDII port nya ada di bawah setir.
Cheers,
HT
kutkuy
Post by kutkuy »
kata manualnya sih bener plug and play tuh... emang cuma dikasih unit ini sama kabel udah, bisa nge reset ECU lagi (kalau ada yg nyala gitu) diagnose, gituan bisa deh....
justru ini mau tau bagaimana bagus ga, seimbang dengan harganya? butuh input dari yg udah pakai... :)
mansetha
Post by mansetha »
Apa bisa untuk segala jenis/merk kendaraan yang telah dilengkapi dg ECU...
kutkuy
Post by kutkuy »
menurut websitenya bisa, diatas taun 1996, ga semua untuk mobil keluaran dibawah 1996
poeticmind
Post by poeticmind »
pasang di L300? :D
kutkuy
Post by kutkuy »
poeticmind wrote:pasang di L300? :D
hahahaa ga kali, mungkin mau di GL tar, tapi ga tau nih blom berani beli abis 2jt gitu lho.... tunggu ada yg udah tau ini bener2 barang bagus, comment di amazon.com kan diluar negeri, mau cari pendapat yg di dalam negeri / di asia gitu
poeticmind
2jt kan mending buat budget nyaman-in GL? hehehehehehe
kutkuy
Post by kutkuy »
poeticmind wrote:2jt kan mending buat budget nyaman-in GL? hehehehehehe
setujuuuu.....
poeticmind
setujuuuu.....
jadi gunanya scangauge , apa kuy? :D
j/k.
kutkuy
Post by kutkuy »
buat keren kerenan hahahahhaa..... terus terang nih kalo di GL mungkin buat ngerest ECU yg katanya error walau dipakai electric mirror
poeticmind
kutkuy wrote:buat keren kerenan hahahahhaa..... terus terang nih kalo di GL mungkin buat ngerest ECU yg katanya error walau dipakai electric mirror
oooh buat di GL, nggg... beli kulkas kecil aja, lebih kepake... :P
kutkuy
Post by kutkuy »
hahaahhaa ya scangauge mah iseng aja ga akan beli koq.... nanti ini kalo udah gatel ga tau apa lagi yg dipasangin
poeticmind
rasanya nambah dikit bisa kebeli GPS, kuy... hehehehe!
elo gatelan beli barang aneh sih ya... :)
tonie
Post by tonie »
kutkuy wrote:hahaahhaa ya scangauge mah iseng aja ga akan beli koq.... nanti ini kalo udah gatel ga tau apa lagi yg dipasangin
:upss: beli..... yg spt di foto keguaan peredam di kap mesin..... :mrgreen:
wait ajah deh... klo sempet seh.. see :mrgreen:
isuzudiesel
Post by isuzudiesel »
HyundaiTucson wrote:Saya juga mau beli ini produk. Agen nya di Jakarta di Tanjung Duren. Cuma sayang nya reading untuk fuel consumption tetap MPG.
buat yg berminat utk ambil ScanGaugeII,
reading fuel consumption-nya bisa di-set ke L/100KM kok. klo KM/L keliatannya masih belum bisa.
1 customer kita dah pake di Peugeot 806-nya (sy set-in ke metric unit-nya).
harga persisnya di Jkt: US$ 169.99 + PPN 10% (klo pembayaran dlm Rp, tinggal dikaliin kurs hari itu aja).
boleh kontak2 sy klo ada pertanyaan lebih lanjut ttg ScanGaugeII.
terima kasih untuk interest-nya. :D
poeticmind
isuzudiesel wrote: buat yg berminat utk ambil ScanGaugeII,
wah ada vendor nih... wekekeke
kuy... beli kuy...! dapet diskon dari bro isuzu...! cepetan... paket awal taon! :P
welcome bro isuzu... !
HyundaiTucson
isuzudiesel wrote:buat yg berminat utk ambil ScanGaugeII,
Wah bro isuzu, thanks ya. Berarti harganya 1,5juta-an ya. pasang aaaah...
Cheers,
HT
poeticmind
weits! bro hyundai.. mohon direview dong setelah pasang... hahahahaha!
penasaran juga nih ama maenan gini... :)
kaya mesin ATM ajah tuh...tombolnya di samping2nya... :lol:
kalo ada ATMnya mau donk...tinggal pencet trus keluar duit... :lol:
oops...kaboooeerrr dolo... :ngacir:
