ni ada lagi alternatif buat "musuh" ninja 250
lebih masuk akal dari yamaha r125
di US dikasi merk United Motors V2S 250R, sebenernya ni produk namanya Hyosung GT250R
secara hyosung udah ada di endonesa, kira2 mungkin gak yah ni motor masuk sini dengan harga "masuk akal"?
speknya deket2 CBR 150 tuh!!
ini dia gambarnya...
dan speknya :
General information
Model: Hyosung GT250R
Year: 2007
Category: Sport
Engine and transmission
Displacement: 249.00 ccm (15.19 cubic inches)
Engine type: V2
Stroke: 4
Compression: 10.2:1
Bore x stroke: 57.0 x 48.8 mm (2.2 x 1.9 inches)
Fuel system: Carburettor
Fuel control: DOHC
Starter: Electric
Cooling system: Oil & air
Gearbox: 5-speed
Transmission type
final drive: Chain
Clutch: Wet Multi-Plate Type
Physical measures
Dry weight: 126.0 kg (277.8 pounds)
Seat height: 795 mm (31.3 inches) If adjustable, lowest setting.
Overall length: 2,080 mm (81.9 inches)
Overall width: 760 mm (29.9 inches)
Chassis and dimensions
Frame type: Double cradle
Rear suspension: Gas shock absorber, Pre-Load Adjustable
Front tyre dimensions: 110/70-H17
Rear tyre dimensions: 150/70-H17
Front brakes: Double disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 140.0 km/h (87.0 mph)
Other specifications
Fuel capacity: 13.70 litres (3.62 gallons)
