bosen..
coba kita buat gosip baru motor ini!!
siap siap nabuuuuuuuuuuuuunggg!!!!
It’s time to get on the road, time to grab the maximum fun out of life with the Yamaha YZF-R125. This radical, high-revving, fuel-injected 125 is the work of the same engineers who created our YZF-R1 and YZF-R6 supersport legends and is packed with MotoGP tech. The YZF-R125 is here to deliver stunning R-Series styling and exhilarating sports performance because life is a sport, to be enjoyed to the max
YZF-R125YZF-R125
Features -
* Inspired by genius
* R-series engine and chassis technology
* 6-speed gearbox
* Aluminium swinging arm
* Midship muffler
Engine -
Engine type Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC
Displacement 124.66 cc
Bore x stroke 52.0 x 58.6 mm
Compression ratio 11.2:1
Maximum power 11.0 kW (15 PS) @ 9,000 rpm
Maximum torque 12.24 Nm (1,25 kg-m) @ 8,000 rpm
Lubrication system Wet sump
Fuel System Fuel injection
Clutch type Wet, multiple-disc coil spring
Ignition system TCI
Starter system Electric
Transmission system Constant mesh, 6-speed
Final transmission Chain
Fuel tank capacity 13.8 L
Oil tank capacity 1.15 L
Chassis: Steel Deltabox
Front suspension system Telescopic forks
Front travel 130 mm
Rear suspension system Swingarm (monocross)
Rear travel 125 mm
Front brake Single disc, Ø 292 mm
Rear brake Single disc, Ø 230 mm
Front tyre 100/80-17 M/C
Rear tyre 130/70-17 M/C
Dimensions -
Length 2,015 mm
Width 660 mm
Height 970 mm
Seat height 818 mm
Wheel base 1,355 mm
Minimum ground clearance 155 mm
Dry weight 126.5 kg
