BEBEK TVS Baru
BEBEK TVS Baru
dengan mesin 110 cc dan memakai speedo digital dan led tail..
http://www.hindu.com/2007/05/16/stories ... 842000.htm
belum tau harganya berapa
SPECS :
Engine: 109.7cc single cylinder four-stroke (horizontally mounted)
Max power: 8.5 bhp@8000
Max torque: 8.5 nm@4500
Ignition: Digital CDI
Fuel supply system: Carburettor
Transmission: Double automatic clutch, wet type
Gearbox: 4 speed constant mesh
Brakes: 220mm two-callier disc/110mm hydraulic drum (f), 110mm drum
Tyres: 2.50x17 (much, much stickier than our Indian goop, made by IRC, a local firm)
Length: 1940mm
Wheelbase: 1260mm
Ground clearance: 150mm
Weight: ~100 kg (± 1 kg between variants)
rencana riliss juga belum ada sihhh....
- Daily Vehicle: Ipin - Ipah
niey bebek ktnya canggih loh, ane baca di okezone.com, doi pake sistem i-drive, trus bisa manual dan otomatis, trus ada buat charge hp, trus ktnya klo di kegelapan kuncinya bisa nyala, trus untuk harga on the road untuk tvs yang paling lengkap 11,5jt-an boo, tp niey motor kuat ngga yah?
