Percaya ngga mobil spt ini harga 2,6M ?
ruthndul
Post by ruthndul »
Bristol Blenheim 3 (ini yang paling murah)
lengkapnya :
http://www.bristolcars.co.uk/index2.htm
harganya :
http://www.bristolcars.co.uk/Blenheim3/ ... cation.htm
chapruk
Post by chapruk »
GENERAL SPECIFICATION OF THE BRISTOL BLENHEIM 3
CHASSIS - Closed box section welded steel construction with three cross members plus stiff floor pans forming a very robust structure affording great protective strength. Many Bristol owners have owed their lives to this structure. Few, if any, other cars have any chassis at all.
ENGINE - The engine is eight cylinder 90 Vee. Capacity is 5900 cc (360 cu. in) Bore 101.6mm (4.00 in). Stroke 90.93mm (3.58ins).
Equipped with sequential Multi-Port fuel injection which provides precise air to fuel ratios for all driving conditions.
The engine control module is a pre-programmed dual microprocessor digital computer. It regulates ignition timing, air fuel ratio, emission control devices, charging system, speed control, air conditioning compressor clutch engagement and idle speed. The control module can adapt its programming to meet changing operating conditions. Manufactured to Bristol requirements by CHRYSLER with whom we have had excellent relations since 1959.
TRANSMISSION - Automatic with torque converter, four forward gears and reverse. The fourth gear is controlled by a switch whereby it may be selected automatically or put out of operation. When de-activated a warning light indicates this. Speed per 1,000 R.P.M. 40.72 M.P.H. (65.15 Km/h)
SUSPENSION - Front: Independent by wishbones of unequal length with coil springs, telescopic dampers, torsional anti-roll bar. Rear: Torsion bar springs with Bristol 8 - link location telescopic dampers. Front & rear dampers are adjustable. Sealed Balljoints. Bonded rubber sleeves in mounting bushes for noise insulation.
STEERING - Power assisted recirculating ball type, 15.7:1 ratio. Sealed ball-joints. Energy absorbing steering column designed to collapse progressively as a safety measure. 14ins. steering wheel with hand stitched leather covering. Anti-theft steering column lock operated by ignition key.
BRAKES - Separate front and rear hydraulic systems operated by tandem master cylinder. Self adjusting servo-assisted disc brakes on all wheels. Failure warning device connected to lamp on instrument panel. Mechanical handbrake linkage operating on rear discs. Warning lamp indicates "handbrake on" position and also checks failure of warning circuit function. Mechanical parking lock incorporated into transmission is operated by gear lever.
ELECTRICAL SYSTEMS - 12 volt negative earth system. 71 amp/hr. battery. High performance alternator charging system with electronic voltage control. The ignition system is electronic thus reducing maintenance and improving efficiency and reliability. Engine Management System with built in diagnostic facility. Remote control locking and alarm system. Radio cassette and CD sound systems.
INSTRUMENTS, WARNING LIGHTS - Comprehensive range of instruments includes speedometer (in mph and kph), tachometer, battery voltmeter, clock, gauges for fuel, water temperature, and oil pressure. Warning lights for headlamp beam, cooling fans on manual operation, low fuel level, turn indicators, hazards lights, handbrake/fluid level, rearguard foglamps, and fourth gear inhibit light. Low oil, service reminder, fan hold, lights.
HEATING, VENTILATING, AIR CONDITIONING - Through flow ventilating system provides fresh air at variable volume and temperature without necessity of opening windows. Air enters the car at the base of the windscreen and passes through the heater to footwells or demist slots above fascia. Ventilation is supplemented by swivel outlets on fascia and side panels of footwells. A comprehensive air conditioning system entirely independent of the heating and ventilation is included in the specification.
FUEL SYSTEM - Tank mounted behind rear seat, protected from impact by strong steel structure. Metal bulkheads separate tank from boot and car interior. Capacity 18imp. gallons (82 litres) Low fuel warning light on fascia. Remote filler release.
BODY - Full four-seater saloon with welded steel structure of great strength, and aluminium alloy panelling. Two wide doors hinged on front pillars have burst proof locks and a self locking system and are fitted with armrests, which have red lights built into the end to serve as a warning to oncoming traffic when the door is open, as well as illuminating the access area to the car with white light, ashtrays, window lift switches and electrically operated windows. Individual front seats, adjustable electrically. Seats tip forward to allow easy access to rear. Removable head rests on front seats. Box forming centre armrest fully padded. Individual rear seats (with belts) accommodate two persons in comfort and have folding centre armrest, and have individual headrests removable when not required. On each wheel arch is a deep usable cubby hole. Protective padding above and below fascia panel. Walnut veneered fascia panel and instrument panel. Pile carpet with soundproof underlays, lockable glove box, pockets on rear of front seats, full width rear parcel shelf. Courtesy roof lights operated either by the doors or independent switches, four ashtrays, cigarette lighter, windscreen and rear screen in laminated plate glass. Door lights and quarter lights in toughened plate glass. Hinged rear quarter lights. Electrically heated rear screen. Spare wheel housed in unique compartment in left hand front wing. Similar compartment on right hand side houses battery, twin brake servos and fuse panel, giving large luggage boot, unencumbered by having no spare wheel in it and opened electrically. Underside of body undersealed. Inside of body selectively treated with anti-drumming material.
LIGHTING - Blenheim has four large circular headlamps employing latest technology.
ya klo ngeliat spec kaya gini si..emang harganya segituan lahh..
full tech bgt..
tp apakah ga ada perangkat safety seperti airbags dkk ya...
^^^^ChapRuK*S^^^^
ahbeng
Post by ahbeng »
dasar org british.... :P
ruthndul
Post by ruthndul »
modelnya itu lho....
80-s banget !
2.6M pula !
unbelievable... (especially one who bought it.... :-) )
DigitALL
Post by DigitALL »
Kalo liat modelnya sih 100 jt juga gw ogah beli !
teckteck
Post by teckteck »
Busyet tuh harga :shock: sama harganya dengan S500 2006 cbu.
dado
Post by dado »
kaya civic excelent, jelek banget, apanya yg bikin mahal?
uch
Post by uch »
Mungkin asli buatan tangan kali ya... Pake gergaji, amplas, ama las. Orang bilang "it's very very exclusive". Gw bilang, kayak bengkel body repair di depan gang komplek gw. he..he.. Beda persepsi sih..
Tapi yg ini keren ya...
http://www.bristolcars.co.uk/BristolFighter.htm
frontier
Post by frontier »
Kalo Bristol di gambar pertama itu ya lucu.. lebih lucu lagi yang mau beli..
frontier
Post by frontier »
Kalo Bristol Fighter lumayan lah.. tapi masih kurang keren juga.. masih kalah keren dibanding Corvette Z06
WP
Post by WP »
Kalo gw sih percaya lah..... mank Bristol dari dulu begitu kok jual mobil mahal.....
malah bentuk Blenheim yg udah bertahun-tahun belum ganti...masih begitu2 aja....
Tapiiii, FYI, Bristol adalah satu2nya produsen mobil sedan mewah asal Inggris yg masih asli milik Inggris. Rolls-Royce sekarang ada di BMW Group, Bentley punya Volkswagen, Aston Martin di bawah naungan Ford...
