Model Foggy Petronas FP1
Year 2004
Engine Four stroke, parallel three cylinder. DOHC, 4 valve per cylinder, Liquid cooled
Capacity 899.5
Bore x Stroke 88 x 49.3 mm
Compression Ratio 14:1
Induction Electronic injection Marelli
Ignition / Starting - / electric
Max Power 95 kW 129 hp @ 10000 rpm
Max Torque 92 Nm @ 9750 rpm
Transmission / Drive 6 Speed / chain
Frame ÂÂ
Front Suspension Öhlins upside-down fork - 43mm Low Inverted Design: Multi Adjustable: compression, rebound, spring. 120-125mm adjustable travel.
Rear Suspension Monoshock Low linkage, Aero Twin Spar Xylan coated Swingarm: Adjustable Ride Height: Öhlins Shock - adjustable compression and rebound damping, quick action spring preload adjuster, 120mm wheel travel
Front Brakes 2x 320mm discs
Rear Brakes Single 220mm disc
Front Tyre 120/70ZR17
Rear Tyre 190/50ZR17
Dry-Weight / Wet-weight 185 kg
Fuel Capacity 23.5 Litres
Kapan Indonesia nyusul bikin superbike sendiri dengan harga sesuai kantong orang Indonesia pada umumnya, ya?????
