woooooyy skuteris....pada kemana neeehhh???
indonesia mau dibanjirin MALAGUTI nooohhh...
salah satunya neh :
MALAGUTI Panthom Max250... bukan yang "cat" hitam loh...
scooterist....pada kemane loe????!!!
(ngelihat kepala & dashboardnya jadi inget ZX130? )
info masuknya Malaguti dari link yg bro wedewe kasih ya?
http://ilmea.dprin.go.id/otomotif/pub/status.php
kemudian gw lihat di
http://ilmea.dprin.go.id/otomotif/pub/l ... perush=645
kayaknya PT. Euro Auto Sport yg di:
Wisma Benhil, Lt. 7, Ruang B-1B, Jl. Jend. Sudirman Kav. 36
Jakarta Pusat 10210
Telp. (021) 5743044
tergolong IU.
Berarti harga-harga bakal standar CBU, wedeww..
Anywa, ini spec PHANTOM MAX 250
Horizontal single cylinder 4-stroke engine - 244cc - Catalyst exhaust system - EURO 2 (Directive 97/24/EC - chapter 5 - 2002/51/EC)
Distribution by 4 valve overhead single camshaft
Liquid cooling system
Computerized instrument panel - LCD display
Bore x stroke: 72.0 x 60.0 mm
Compression ratio: 11.0:1
Digital electronic ignition (CDI)
Electric start, automatic choke
Automatic primary transmission by V-belt speed change gear
Final transmission by gears
Automatic centrifugal dry clutch
Max Power: 16 kW at 8500 rpm - 21.5 HP at 8.500 rpm
Max Torque: 20.0 Nm at 6750 rpm
High resistance braced tubular steel frame
Front brake: 220 mm Ø disc , 2 piston hydraulic calliper
Rear brake: 220 mm Ø disc, hydraulic calliper
Tubeless tires: 130/70-13", front; 140/60-13", rear
Front suspension by hydraulic fork,
33 mm. Ø stanchions with 90 mm stroke
Rear suspension by swinging engine and 2 hydraulic shock absorbers with 80 mm stroke
Petrol tank capacity: 9,4 litres
Dry weight 138 kg
wah, skuter dahsyat nih! saatnya skuter di indo upgrade model macam gini, jgn model piaggio mlulu, bosen modelnya dah ga up to date, haha...keren bro! mesinnya juga ok banget. Kalo gw gak salah perkiraan, dr modelnya nih motor bisa lebih mahal dr cbr 150 nih, bisa 40 jutaan kali yak!
Just Call Me Nichol !!!
