New Hyundai SantaFe
conan
New Hyundai SantaFe
Post by conan »
New Hyundai SantaFe production first pics
observer
Post by observer »
WOW! The level of enthusiasm in this topic is evident of one thing: Indonesians don't buy korean cars, unless there is no other alternative. No curiosity, no discussion whatsoever. What more proof do u need???
Saya pikir styling depan cukup menjanjikan. Can't wait to see how the rear looks like. :wink:
conan
Post by conan »
observer wrote:Saya pikir styling depan cukup menjanjikan. Can't wait to see how the rear looks like. :wink:
Here you go. :)
conan
Post by conan »
Actually, this is quite a looker. Modern and distinctively Hyundai.
Three rows of seats, seven headrests. HID headlights, built-in cooler box, etc.
2.7L petrol and 2.2L diesel. If it's available with the 2.4L from the Sonata, it could be a hit in the local market (lower tax rate).
More detailed pics here :
http://www.bobaedream.com/board/data/da ... search_day
observer
Post by observer »
Belakangnya mirip VW Touareg, samping agak mirip X3. Dengan pilar-D agak menukik ke depan, saya agak meragukan ruang kepala di baris ke 3. Overall, Hyundai did quite a good job on the styling. :e-clap:
Naruto
Post by Naruto »
Belakang dan sampingnya keren juga ya.. saya kira jelek , gemuk gitu, hehehe... Nice nice.
Kalau lampu depannya sipit, jadi mirip infiniti fx-45 nih. hehehe..
O13
Post by O13 »
KEREN!!!! Kapan nih release-nya?
DigitALL
Post by DigitALL »
Hyundai mengalami kemajuan dalam hal design exteriornya akhir2 ini. Liat exterior Hyundai Sonata terbaru, sebetulnya cukup menarik dan indah dipandang ttp sayang harganya tinggi sekali bahkan hampir mendekati Camry.
Hyundai Getz, modelnya bisa diterima oleh semua orang. Baik di tanah air atau di luar negeri. Waktu gw ke GoldCoast, OZ cukup banyak Getz 2 pintu di sana.
And terbukti Hyundai sukses dalam design exteriornya !
observer
Post by observer »
Dibandingkan Fortuner, new Santa Fe ada beberapa keunggulan :
1 horsepower dari mesin 2.7l sebesar 189ps@6000rpm dan torsi [email protected]
2 Pengendalian dan suspensi yang lebih mirip sedan - Santa Fe's chassis was extensively revised to attain a more refined sedan-like ride, most immediately noticeable by rear seat passengers. The predecessor's double wishbone rear suspension was dropped in favor of a multi-link setup resulting in reduced noise and vibration. When the vehicle is fully loaded or pulling a trailer, an innovative self-leveling system automatically levels out the vehicle height without requiring external power. While carrying over the Macpherson strut front suspension, the caster angle was increased to improve stability while optimizing the overall strut geometry.
3 Bangku baris ke-3 bisa dilipat rata dengan lantai - In a novel touch, third-row seats can be easily stowed away and fold flat into the floor.
4 Tangki bensin 75L!!
Dimensi:
New Santa Fe (CM) Previous Santa Fe
Overall length (mm) 4675 4500
Overall width (mm) 1890 1845
Wheelbase (mm) 2700 2620
Front Track (mm) 1615 1540
Rear Track (mm) 1620 1540
Ground Clearance (mm) 200 207
Fuel Tank Capacity (l) 75 65
Tires 235/65R17, 235/60R18 225/70R16
hdrw
Post by hdrw »
Harganya kira2 berapa yah ?
ween
Post by ween »
DigitALL wrote:Hyundai mengalami kemajuan dalam hal design exteriornya akhir2 ini. Liat exterior Hyundai Sonata terbaru, sebetulnya cukup menarik dan indah dipandang ttp sayang harganya tinggi sekali bahkan hampir mendekati Camry.
iya, saya juga termasuk penggemar design getz, sonata baru dan santa fe baru ini......semua designnya bergaya eropa........
tapi sayang, koq facelift atoz 1,1 koq jelek bgt yah?pake headlamp mirip kaya punya escudo........dan saya lihat, setelah facelift, mobil versi facelift ini jarang ada di jalan tuh....
accent verna pun saya ga suka bentuknya.....menurut saya designnya mengalami kemunduran dari versi sebelumnya(gls)
juga tucson, saya kurang suka......&bener2 copy sama sportageII.....mirip seperti kasus grace/h100-pregio, atoz-visto & picanto-atoz1,1......bentuk kembarnya keliatan bgt....
neptunus
Post by neptunus »
Hyundai Santa Fe baru memukau
(29/11/2005) - Pekan lalu, Hyundai Motor Co. memperkenalkan all-new Santa Fe -lebih besar, lebih elegan dan lebih berkualitas dibandingkan pendahulunya. Santa Fe baru ini mempertajam daya saing di segmen paling padat berbekal layout tiga baris kursi plus aneka fitur comfort dan convenience.
Lewat foto-foto resmi yang dirilis Hyundai pekan lalu, banyak yang terkesan dengan tampilan Santa Fe. Style yang rapi, bersih dan elegan membuat banyak orang berdecak kagum dan mengangkat jempol. Dikembangkan dengan biaya 162 miliar Won ($155 juta) selama 26 bulan dalam proyek berkode CM, Santa Fe baru bertumpu pada wheelbase 2.7m, 8cm lebih panjang dari pendahulunya. Ini memungkinkan penambahan panjang keseluruhan (+15cm), lebar (+5.5cm) dan tinggi (+5cm). Hasilnya, kabin lebih lega, lebih lapang terutama ruang kaki penumpang depan dan belakang.
SUV yang rencananya akan world debut di Detroit Motor Show, Januari 2006 itu menawarkan mesin bensin dan diesel. Menurut Hyundai, mesin diesel D-2.2 mengalirkan 153hp pada 4000rpm dan 35kg.m torsi pada 2000rpm dengan bantuan Variable Geometry Turbocharger. Mesin diesel baru ini dipasangkan dengan all-new 5-speed transmission, baik matik maupun manual yang sama-sama efisien dalam penggunaan bahan bakar dan halus perpindahan giginya. Bahan bakar disemprotkan lewat injektor dari common rail generasi kedua bertekanan 1600bar yang dikendalikan microprocessor 32 bit (sebelumnya ECU 16 bit). Variable swirl control dan katup pengatur udara yang dikendalikan secara elektronik membantu menyempurnakan proses pembakaran dan menurunkan emisi berbahaya. Kepala silindernya menggunakan two-layer water jacket yang memungkinkan kepala silinder menerima tekanan pembakaran lebih besar. Exhaust Gas Recirculation (mengembalikan fuel yang terlempar ke saluran exhaust balik ke ruang bakar) berpendingin air dan dikontrol secara elektronis membantu meminimalkan emisi agar sesuai dengan standar Euro IV.
Peminat mesin bensin Santa Fe punya pilihan lebih fleksibel. Hyundai memasang dua mesin bensin yaitu 2.7 liter dan 3.3 liter (yang ini khusus pasar Amerika Utara). Keduanya berarsitektur V6 dengan konstruksi seluruhnya dari aluminium. Mesin 2.7 liter mengadopsi Variable Valve Timing dan Variable Intake System untuk memproduksi power maksimum 189hp pada 6000 rpm dan torsi 25.3kg.m@4200rpm. Mesin 3.3 liter dipasangkan dengan 5AT sedangkan 2.7 dengan 5MT sebagai fitur standar dan 4AT sebagai optional.
Sistem penggerak empat roda Santa Fe juga baru. Dikontrol secara elektronis, secara otomatis mengirim power ke roda yang memiliki traksi terbaik.4WD lock membagi torsi sama rata antara roda depan dan belakang disituasi off-road.
Sasis Santa Fe mengalami perbaikan besar-besaran untuk meningkatkan kenyamanann yang sekelas sedan itu. Suspensi belakang double wishbone pada generasi lama, diganti multi link guna meminimalisir noise dan vibration. Jika mobil mendongak karena terisi penuh, self-leveling system otomatis membuatnya datar kembali tanpa power dari luar. Boster ganda menemani cakram 16 inch (yang depan berventilasi). ABS menjadi piranti standar, disempurnakan dengan Electronic Stability Program.
Selain dual front aribags, Santa Fe ditanami juga dengan side airbgs depan plus curtain airbags yang meletup disepanjang mobil, menambah perlindungan kepala seluruh penumpang. Airbag penumpang kursi depan bisa di non-aktifkan dengan bila yang duduk disana anak kecil. Panel indikator dengan iluminasi, dan dual zone climate control (suhu interior bisa beda pada saat bersamaan) untuk pengemudi dan penumpang depan membawa sentuhan kemewahan dimana penumpang baris kedua dan ketiga menikmati kenyamanan ventilasi di pilar B, dan saluran pemanas yang memanjang hingga ke belakang.
Kursi baris ketiga bisa dilipat rata lantai dengan mudah dan jadilah ruang kargo yang luas. Sayangnya, Hyundai tidak menginformasikan berapa volume ruang kargonya. Fitur menarik lainnya adalah wiper otomatis bekerja bila hujan turun dan trip komputer yang mencatat informasi dan menyajikan data sepanjang perjalanan.
Santa Fe akan diproduksi di Ulsan dengan target penjualan 60,000 unit setahun dipasar domestik dan ekspor 150,000. Untuk pasar Amerika Utara, Santa Fe akan diproduksi di Montgomery, Alabama, USA mulai triwulan pertama tahun depan.
neptunus
Post by neptunus »
Ini gambar2 lainnya.moga2 membantu yah :)
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
neptunus
Post by neptunus »
'msm
Post by 'msm »
Kenapa kok desain tachometernya tidak menggunakan 3d illumination seperti di Odyssey ya?
Kalo dibikin seperti itu aku yakin lebih keren.
Desain dashboard dan eksterior keseluruhan oke.
Msm
ween
Post by ween »
yg masuk k indo versi apa aja?
yg dieselnya cuma versi4x2?
5 seater atau 7 seater y?
DigitALL
Post by DigitALL »
Kalo ngga salah yg masuk ada 2 versi, bensin dan diesel. Semua A/T dan 7 seater SUV.
