Daihatsu new Terios
Daihatsu new Terios
A new Taruna will be somewhat similar to this new Terios..
Specifications  D-Compact 4X4
Dimensions Overall length mm 4075
and weight Overall width mm 1745
Overall height mm 1760
Wheelbase mm 2580
Track (front) mm 1445
Track (rear) mm 1480
Min. road mm 200
clearance
Kerb weight kg 1230
Seating capacity 5
Turning circle m 10
(wall-to-wall)
Engine Type Petrol, inline 4-cylinder,
DOHC, 16-valve, DVVT
Displacement cc 1495
Bore x stroke mm 72 x 91.8
Max. output kW/rpm 77/6000
Max. torque N·m/rpm 140/4400
Compression ratio 10.0
Fuel system EFI
Wheelbase mm 2580
Min. road mm 200
clearance
Kerb weight kg 1230
Seating capacity 5
Turning circle m 10
(wall-to-wall)
Fuel system EFI
