Rotary control switch 1:
Power improvement
With this rotary control switch you can increase or reduce the power stepwise.
Example: The factory setting of the left rotary is on position "B". If you want to increase the performance, adjust to positon "C". The result is a performance increase of 1.5%. Each clockwise rotation to the next position increases the performance by 1.5%.
Rotary switch 2:
Cut-off speed
The right rotary control switch is responsible for the duration of the performance increase, thus how long the performance increase shall be available for the rpm-range. Normally, you dont need to adjust it.
Cue: The lowest performance of the rotary control switch is position "8", the highest performance is position "7". You achieve the performance by turning the switch clockwise.
