Kenapa Daihatsu gak memasarkan Truk Delta ?
solar_kerosen
Post by solar_kerosen »
lihat body dan spek mesinnya kayaknya bersaing dengan Mitsubishi canter maupun Hino padahal malaysia jual nih truk sangat disayangkan padahal brand image lebih bagus Daihatsu dibandingkan Hyundai yg berani memasarkan truknya
Gak kebayang kalau nih mesin dimasukin ke Taft GT gue :wkkk:
And45
Re: Kenapa Daihatsu gak memasarkan Truk Delta ?
Post by And45 »
bukanya dulu daihatsu delta dimasukon yak?
cman skarang ud nga kan...
(cmiiw)
toyota mungkin ud nga masukin daihatsu delta lagi karena ud ad dyna dan hino dutro yg kalau tidak salah juga milik toyota kan?
jd, sepertinya hanya agar tidak merebut pasar dyna dan dutro
cmiiw
solar_kerosen
TECHINICAL SPECIFICATIONS
Specifications V116HA V116HU
Overall length mm 6022 6022
Overall width mm 2241 2241
Overall height mm 2120 2120
Wheelbase mm 3275 3275
Track front mm 1630 1630
Track rear mm 1470 1470
Min. road clearance mm 200 200
Seating capacity 3 3
Kerb weight (chasis) kg 1950 2360
Gross vehicle weight kg 5000 7000
Min. turning radius m 6.5 6.5
Engine Water-cooled, 4-cylinder, 4-cycle,
O.H.V., direct injection 14B diesel engine
Total displacement cc 3660
Bore X stroke mm 102 x 112
Max. output (SAE net) 70kW (93.9HP) / 3400rpm
Max. torque (SAE net) 240Nm (24.4kg-m) / 2000rpm
Gear ratio 1st
2nd
3rd
4th
5th
Rev
Final 5.339
2.793
1.593
1.000
0.789
5.339
5.857
Compression ratio 18.0
Fuel tank capacity litre 100
Clutch Dry single plate, hydraulic diaphragm
Steering type Power steering recirculating ball
Main brakes Hydraulic Dual Circuit System with Hydraulic Tandem Master Cylinder and Booster
Parking brake Internal expansion type (propeller shaft control)
Suspension Rigid axle with semi oval spring and telescopic double acting shock absorbers
Tyres front 7.00-16-10PR (single) 7.5-16-12PR (single)
Seating capacity 7.00-16-10PR (dual) 7.5-16-12PR (dual)
