toyota yaris facelift??
thomasQ
Post by thomasQ »
misi tanya dong yaris katanya mw facelift ya??
kapan pastinya sama brapa harganya
klo ada gambarnya lebih sip lagi tuh~~
thx :frm_tumbleft:
QuantuM
TiongBahru_Ahbeng
Re: toyota yaris facelift??
Post by TiongBahru_Ahbeng »
Is that a carl's jr burger?
arisbudiarto
Post by arisbudiarto »
Munkin ini artikel yang terkait:
http://carscoop.blogspot.com/2008/12/20 ... ew-13.html
dan ini gambarnya
Lebih lengkap tanya 'mba Rini :mrgreen:
Regards,
a.budiarto
flexiblebil
Post by flexiblebil »
kayanya minor change nih.. tadinya kirain major change..
yang berubah bentuk lampu depan, bemper depan, warna lampu belakang juga berubah, & beberapa item di interior. lainnya kayanya masih sama ya..
GTR
Post by GTR »
very minor change, lampu belakang dari led kayanya kembali ke model bulbs.
DigitALL
Post by DigitALL »
Lampu belakang masih pake LED bro GTR. Saya liat dari webnya mba Rini.
Ini masih minor change tapi keliatan lebih bagus model bumpernya.
GTR
Post by GTR »
kalo T-sport trim memang LED.
hmm.. tapi ini kan model bumper USDM klo ga salah, harusnya udah lama yah...
thomasQ
Post by thomasQ »
ok thanks bwat gambar gambarnya!! :frm_salut: katanya ada yang brubah juga sama mesinnya ya??
klo masalah harganya ada yang tw ga ya??
harga dollar kan skarang 11300an tambah mahal lage!!
apa g ngaruh sama harga yarisnya ntar abis facelift??
QuantuM
GTR
Post by GTR »
kayanya mesin barunya ini:
Toyota has replaced the 1.4 liter VVT-i engine (4ZZ-FE) in the Toyota Auris with a new 1.33 liter Dual VVT-i engine (1NR-FE) that produces more power, more torque, more mileage, less CO2 emissions, yet has a smaller displacement and also weighs 13kg less despite having a more complicated Dual VVT-i drivetrain, thanks to pistons that are 36% lighter among other improvements. It’s also more compact, and Toyota claims it is the same size as the inline-3 1.0 liter VVT-i engine.
The new engine also has stop-start capability, which automatically stops the engine when the car is stationary, the transmission is in neutral and the driver’s foot is off the clutch pedal. When the driver presses the clutch, the engine is restarted, and Toyota claims a potential fuel savings and CO2 reduction of up to 15% thanks to this.
For a smoother restart, Toyota says this new engine is 9dB quieter and 0.3 seconds quicker to start compared to the outgoing 1.4 liter engine.
The following is a comparison table between the two engines.
_____________1.33L Dual VVT-i __1.4L VVT-i
Engine Code __1NR-FE __________4ZZ-FE
Displacement _1,329cc __________1,398cc
Power _______101hp@6,000rpm __97hp@6,000
Torque ______132Nm@3,800rpm __130Nm@4,400rpm
Bore ________72.5mm ___________79.0mm
Stroke ______80.5mm ___________71.3mm
Compression __11.5:1 ___________10.5:1
Combined economy 48.7mpg ______40.9mpg
CO2 emissions ____135g/km ______163g/km
With the new engine also comes a new 6-speed manual transmission with ratios to match the new torque curve. Both the 5th and 6th gear are overdrive gears for a reduced cruising engine RPM during highway driving. Toyota says this new transmission can handle more torque than the outgoing 5-speed unit and is 11% smaller and has 15% less components despite having one extra gear ratio.
DhanZ
Post by DhanZ »
jadi mesinya bagusan mana?
Seeing is believing[*][/size]
Fairoes
Post by Fairoes »
mesin kayaknya baru untuk eropa deh... untuk Indo kayaknya masih lama... kayaknya nunggu krismon reda dulu dan harga dolar turun... ntar kalau ganti mesin mungkin bisa kayak Jazz dah naiknya ampun-ampunan.... :off_no:
Fairoes
Post by Fairoes »
GTR
Post by GTR »
Yaris Facelift 2009 (Minor Change)
Perubahan Yaris facelift ini terletak pada desain headlamp dengan dimensi yang semakin membesar. Akibatnya desain kap mesin yaris yang menggunakan teknologi pedestrian safety mengalami perubahan juga. Sedangkan lampu belakang mengalami perubahan yaitu menggunakan warna oranye untuk lampu sein dari sebelumnya warna putih dan penggunaan lampu halogen untuk lampu stopnya.
Bumper depan mengalami perubahan desain, lubang udara yang lebih besar dan terlihat juga penambahan chrome list pada bagian fog lamp. Design vleg yaris juga mengalami perubahan dari 5 jeruji menjadi 8 jeruji sehingga menambah kesan lebih bergaya dan dinamis.
http://rinisumasdi.blogspot.com/2009/02 ... hange.html
penyubali
Post by penyubali »
Weleh2 kok facelift malah downgrade seh stop lightnya...dari sebelumnya LED balik ke Halogen konvensional... :off_no:
rambokampung
Post by rambokampung »
Wah nice info bro GTR, kapan yah perubahan mayor nya?
penyubali wrote:Weleh2 kok facelift malah downgrade seh stop lightnya...dari sebelumnya LED balik ke Halogen konvensional... :off_no:
pengaruh krisis kali om..... :mrgreen: :big_weee: :ngacir:
Fairoes
Post by Fairoes »
hehehehehe biar naiknya enggak terlalu gede kali ya.....
YellowRiver
Post by YellowRiver »
interiornya gmn yah? dah ada MIDnya blm yah?
aldy
Post by aldy »
Eh ane mau kasih info tapi entah bener apa ga tapi kyknya beneran.. Ada di TV one kapan itu Toyota mau gila2an naikin harga sebanyak 3 kali..CMIIW
RA167E V6 1,5 liter 1500 HP
datsu
Post by datsu »
Ayo kita jadikan ini info senjata makan tuan yang paling bagus.. ayo rame2 beli toyota sekarang.. hancurkan penjualan yang laen...
Kalo infonya bener, artinya kita dapet mobil murah.. kalo infonya salah, seenggak bisa mendongkrak penjualan toyota.. wakakakakaka.. :off_good:
I'm flying with my Siti
Powered by L15Z1 N/A
aldy
Post by aldy »
Bro datsu ini bisa aja.. :e-snooty:
Ayo biar seru sama2 memprediksi brapa sih harga jual yaris terbaru..kalo naik cuma 5 juta dari yaris yg dijual sekarang ane beli deh..he2.cz ane mulai tertarik nih ama yaris..udah 3 tahun ga punya mobil toyota.
