Hasil test lab PTT SUPER COMM RAIL ACEA C3
yg TBN baru nya sekitar 8 mg KOH
10.000 km
6 bulan
BBM BioSol B30 + HSS EDT
Setiap X Warming up hanya 20 detik aja
2KD ReMap by ACT
Iron masih masuk range Normal, karena odo udah 140 rb km.
Turboman wrote: Mon Jun 20, 2022 2:30 Hasil test lab PTT SUPER COMM RAIL ACEA C3
10.000 km
6 bulan
2KD ReMap by ACT
Screenshot_2022-06-20-09-26-13-170_com.google.android.apps.docs.jpgIMG_20220620_092601.jpg
Apik mbahh.
Ini 5w30 C3 yaa?
Yg seliter 160rb an klo sy lihat di tokped.
10.000 km
6 bulan
2KD ReMap by ACT
Apik mbahh.
Ini 5w30 C3 yaa?
Harganya itu yg bikin serem
wkwkwkw
Turboman wrote: Mon Jun 20, 2022 2:35
10.000 km
6 bulan
2KD ReMap by ACT
Apik mbahh.
Ini 5w30 C3 yaa?
wkwkwkw
Harganya Beti sm Q8 FT8800 :big_biglaugh:
Ndak heran hasilnya mantapp
Dam secara di thailand sono tuner diesel hasilnya monster.
Jd unique seling point si PTT oli dieselnya istimewa
Pernah UOA mbah si FT8800 ?
Suryaputra wrote: Apik mbahh.
Ini 5w30 C3 yaa?
wkwkwkw
FT 8800 dulu pake 11 rb km sekian
TBN akhir = masih 8 koma lebih
Full BioSol + additip solar
Turboman wrote: Mon Jun 20, 2022 2:44
Suryaputra wrote:
Turboman wrote: Mon Jun 20, 2022 2:35 Harganya itu yg bikin serem
wkwkwkw
Gak kuat ngebayangin klo gantol
8 botol buat sekelas 2GD :upss:
Best value buat duo gajah kayanya masih PTT 10w30 a3 b4 yaa :big_peace:
r1409
Post by r1409 »
btw kalau shell helix ultra 5w30 bisa buat diesel ga sih? di labelnya tertulis for gasoline tapi ada spek ACEA A5/B5.
r1409 wrote:btw kalau shell helix ultra 5w30 bisa buat diesel ga sih? di labelnya tertulis for gasoline tapi ada spek ACEA A5/B5.
kalo ada ACEA B5 = bisa utk Diesel yg minta std B5 / B1
coba teat lab aja brp kadar Ca & Mg nya
c_adhi_k
Post by c_adhi_k »
Eneos yang 0w-20 rekomen ga om
Diharga 80 ribuan per liter
Sonzz
Daily Vehicle: Veloz 3SZ-VE Brio L12
Post by Sonzz »
fajarrian wrote: Fri Jun 03, 2022 15:21
yanuarra wrote: Fri Jun 03, 2022 13:27
t105erd wrote: Fri Jun 03, 2022 13:08
Oli dari drum sama botol sama yah kualitasnya?
Ga bs bilang ane om.. :big_biglaugh:
Tp dimari masalah penyimpanan dll pasti disangsi..
Ya bebas aja..
Tp ane cuma ngasih opsi aja kalau mau cari yg murah tp cukup bagus bisa pertimbangin fastron gold drum..buat 1nz ada 5w30 ada 5w40.. jgn lupa belinya di agen resmi yah..
Soalnya di harga sekitar itu ane rasa cuma dpt 10w40 botolan..
Saya pake pfg curah tapi buat di vario sih, beli di autostore narogong, murah meriah ganti 2 bulan sekali
Next mo cobain ah buat di mobil, pake 3 bulan aja terus buang
2 atau 3 bulan terlalu cepet ga om?
Kalau di mobil, biasa saya pakai minimal 6 bulan. Maximal 12 bulan
*Kalau ga kena macet parah/jarang idle
Sonzz
Post by Sonzz »
Btw ada yang pernah coba oli API SN/CF kyk Fastro* gold 5w30 untuk mesin diesel modern ga? Yang notabene ada ACEA C3
Kayak mesin 2GD, 4N15, dll
Penasaran. Mau coba iseng2 ke Palisade 2.2 :big_biglaugh:
Sinclaire
Post by Sinclaire »
Sonzz wrote: Mon Jun 20, 2022 14:14 Btw ada yang pernah coba oli API SN/CF kyk Fastro* gold 5w30 untuk mesin diesel modern ga? Yang notabene ada ACEA C3
kok iseng2? itu kan memang sesuai peruntukannya pak, malah cocok itu fastron gold, dicoba aja om
Sonzz
Post by Sonzz »
Sinclaire wrote: Mon Jun 20, 2022 14:30
Bukannya itu oli lebih ke arah gasoline engine om?
Dulu katanya bisa untuk diesel engine juga. Tapi bingung, soalny cuma sampai API CF. Dan PDS nya juga sedikit spek/approval nya
Sonzz wrote: Mon Jun 20, 2022 14:50
Klo cek manual booknya Palisade dari,
https://www.hyundai.com/id/en/connect-t ... ers-manual
Range nya dari w30 sampai w40 :big_okay:
Creta lain lagi, CUMA boleh 0w20,
Sinclaire
Post by Sinclaire »
kalo ada spek acea c3 berarti masuk om, emang fastron gold acea c3 kan.. light duty diesel engine ini
Sonzz wrote:Btw ada yang pernah coba oli API SN/CF kyk Fastro* gold 5w30 untuk mesin diesel modern ga? Yang notabene ada ACEA C3
Test aja
pake 8000 km trus test lab
Pastikan asli aja mbah.
Fastron 5w30 itu C3?
, Dpt harga brp?
Spies
Post by Spies »
Suryaputra wrote: Tue Jun 21, 2022 1:02
, Dpt harga brp?
Chris001
Daily Vehicle: W204
Post by Chris001 »
Halo suhu2 ada yang pernah coba shell helix astra 5w30 punya shop n drive? Penasaran harga diskon 50% jadi 382 untuk 4 liter apa oke untuk mobil scr jangka panjang?
Chris001 wrote:Halo suhu2 ada yang pernah coba shell helix astra 5w30 punya shop n drive? Penasaran harga diskon 50% jadi 382 untuk 4 liter apa oke untuk mobil scr jangka panjang?
test aja
oli bukan pasangan hidup
dipake enak, pake terus.....dipake gak enak, buang
beres
Spies wrote: Tue Jun 21, 2022 2:14
, Dpt harga brp?
Ok menarik nih.
Klo tbn pds segitu (astm d2896)
Tbn test lab estimasi di angka 6 koma kecil.
Krn metode ukurnya beda.
Profith83
Post by Profith83 »
10.000 km
6 bulan
2KD ReMap by ACT
ada hasil test PTT yang 5w30 ACEA A5/B5 om?
kingpower
Post by kingpower »
Turboman wrote: Tue Jun 21, 2022 0:47
Test aja
Om turboman.
Kalo 5w30 yang spec acea a3/b4 apakah ada rekomendasi?
Untuk santafe 2.2 facelift, dia tanpa dpf kan? Minta a3/b4.
Sebenernya sih dibolehin 0w20, cuma sy masih skeptis mesin diesel pake oli terlalu encer.
Terimakasih.
DrivingPotato
Post by DrivingPotato »
kingpower wrote: Tue Jun 21, 2022 4:53
Om turboman.
Terimakasih.
Ternyata Diesel Oil yg 0W-20 udah mulai ada yang jual ya :mky_02:
https://www.tokopedia.com/sentrapelumas ... 20-1-quart
P5-VPS (SKYACTIV-G 1.5)
2GD-FTV
2ZR-FE
Test aja
Om turboman.
Terimakasih.
kalo dibolehin 0W20 & mau pake 5W30
pake aja 5W30 A5 / B5
