2016 Sienta Q CVT, the Freed Killer?
ternakblog
Re: 2016 Sienta Q CVT, the Freed Killer?
Post by ternakblog »
liep wrote:
artoodetoo wrote:
ternakblog wrote:Bro,tau bocoran launching freednew ini?
liep wrote: Nambahim komen 1 baris tp scrollnya sampe habis...lumayan biar cpt ganti page
Bro Ternakblog dan Bro Liep,
Harap quote seperlunya saja, jangan full post di-quote, udah gitu komentarnya sebaris pula.
Ganti page bukan berdasarkan jumlah baris pada posting tapi jumlah post. Per page 25 post kalau saya tidak salah
bisa dicek posting ane sbelum2nya selalu ane cut sperlunya krn menghindari yg bginian krn klo pas buka sm pake android, minta ampun scrollnya
klo gini khan lumayan jadi ad mod yg perhatiin, thx
Mueheehe,sori2 om2,gak nengok aku soalnya maen quote aja :ungg:
ricz wrote:Nice review...
Anyway, sekedar koreksi nih, sienta pake mesin 2NR-FE, bukan 2NR-VE... Karena AFAIK mesin Sienta itu buatan Toyota, bukan buatan Daihatsu (VE)... Meskipun serupa tapi bukan berarti sama.... :mky_04:
Barusan buka mbah gugel... mmg bener 2NR-FE... Tapi .....
A 1.5 (1496 cc) variant of the NR series engine. First introduced in Q4 of 2010 for the Toyota Etios. It is the first new engine Toyota developed for over 8 years without VVT-i. Done to reduce cost for the low-cost Toyota Etios. A new innovation that made its introduction on this engine is the integration of the exhaust manifold into the cylinder head[4] to reduce emissions. A Dual VVT-i equipped version was used in Toyota Avanza.[5]
Technical specifications of the engine:
Displacement: 1496 cc
Bore x Stroke: 72.5 mm × 90.6 mm (2.85 in × 3.57 in)
Max. Output:
66 kW (90 PS) at 5600 rpm (w/o Dual VVT-i)
76 kW (104 PS) at 6000 rpm (with Dual VVT-i)
Max. Torque:
132 N·m (97 lbf·ft) at 3000 rpm (w/o Dual VVT-i)
139 N·m (103 lbf·ft) at 4200 rpm (with Dual VVT-i)
Compression Ratio: 10.5:1
Idling speed: 500 rpm
Redline: 5,850 rpm
Applications:
Toyota Avanza (w/Dual VVT-i)
Toyota Etios
Toyota Etios Cross
Toyota Sienta (w/Dual VVT-i)
Toyota Vios (w/Dual VVT-i)
Toyota Yaris (w/Dual VVT-i)
Jadi intinya... yo podo wae :ngacir:
NR = Mesin Avanza = Mesin Xenia
Xenia = Daihatsu
armann wrote: Ohhh ya mungkin pintunya freed gk panjang2 amet & otomatis openingnya kalah lebar dibanding sienta, tp well thought desain nya, gk kyk sienta jg, yg desain nya pengen standout di kelasnya (gk ada saingannya jg sih di indo).... ya pastinya ada, di pasar jepang
Ya gitu deh... hahaha... nama nya mengedepankan style oom. Maka nya saya bilang Freed keliatan jauh lebih matang secara konsep.
Wong berapa kali saya buka bagasi Sienta bibir hampir kejedot.... :mky_05: handel pintu bagasi sama bibir bagasinya jauh bener.
liep
Post by liep »
ChZ wrote: Wong berapa kali saya buka bagasi Sienta bibir hampir kejedot.... :mky_05: handel pintu bagasi sama bibir bagasinya jauh bener.
klo di prit, bgitu ampe mall trus satpam buak pintu bagasi, yg tjd kamera parkir lgs copot krn posisinya pas di tengah ditekan ga kebuka pintunya, ama satpam dg tenaga machonya lgs tekan lbih keras, patah deh kameranya hehe, bukaanya di sampingnya kamera, salah posisi terus, termasuk kmrn pas mau jual prit, ad pembeli dg PD nya main buka bagasi, patah lagi deh kameranya
nyotnyet
Post by nyotnyet »
Nah, kejadian di freed adik saya...juga gitu kalo orang ga paham tombol buka pintunya dimana, rusak deh itu kamera mundur...
Flaw by design juga?
Soul Red zoom zoom
aratha
Post by aratha »
liep wrote: klo di prit, bgitu ampe mall trus satpam buak pintu bagasi, yg tjd kamera parkir lgs copot krn posisinya pas di tengah ditekan ga kebuka pintunya, ama satpam dg tenaga machonya lgs tekan lbih keras, patah deh kameranya hehe, bukaanya di sampingnya kamera, salah posisi terus, termasuk kmrn pas mau jual prit, ad pembeli dg PD nya main buka bagasi, patah lagi deh kameranya
kalo Freed saya lampu platnya yang patah, sekarang tiap lewat pemeriksaan saya bukain kaca tengah aja. kalo saya masang kamera di sebelah paling kanan.
nyotnyet wrote: Nah, kejadian di freed adik saya...juga gitu kalo orang ga paham tombol buka pintunya dimana, rusak deh itu kamera mundur...
Sebenernya di trunk lid ada tanda strip gitu yang menunjukan dimana lever bagasi. cuma ya gitu deh, mungkin karena kebanyakan lever bagasi di tengah main hajar aja jadinya.
2007 RE1 2.4 A/T
2010 GE8 RS 1.5 A/T
2012 GB3 1.5 A/T
2003 E46 318i 2.0 A/T
aratha
Post by aratha »
Max. Output:
Max. Torque:
Redline: 5,850 rpm
Applications:
Toyota Etios
Toyota Etios Cross
Xenia = Daihatsu
ini kata pejabatnya http://otomotif.kompas.com/read/2016/04 ... gan.Avanza
mungkin maksudnya om Ricz perbedaan di material and a little bit of extra piece here and there, nah kalau maksudnya om ChZ cama itu secara mekanisme kerja mesin. :big_okay:
2007 RE1 2.4 A/T
2010 GE8 RS 1.5 A/T
2012 GB3 1.5 A/T
    Kamera mundur Prit setau saya itu memang pasang-pasangan dari HPM sendiri kan yah? Berarti HPM yang dudul ... tapi ya gak bisa nyalahin HPM since memang udah ada tandanya wkwkwkwkw
    Satpam di mall biasanya memang kadang asal main buka aja gak nanya yang punya... Saya klw pake Harrier selalu kasi tau satpam atau tukang cuci mobil "bisa dibuka dari dalem pak" ... since Harrier saya type yang ada power back door... Kalo prit korban kamera mundur, ini korban motor elektrik :mky_05:
    Haaa? Bru tau material engine block 2NR-FE dan 2NR-VE beda.
    Soalnya dari segi konstruksi saya liat kok mirip.... Letak airbox nya pun sama maka nya punya Sienta bisa sembunyi di belakang wiper gitu.
    coklatMetalik
    Daily Vehicle: LGX
    Post by coklatMetalik »
    Sbnernya Cuma beda posisi blok mesin aja kan?
    1979 Datsun GN620
    1992 Toyota KF40
    2000 Toyota KF82
    coklatMetalik wrote: Sbnernya Cuma beda posisi blok mesin aja kan?
    basically, si iya, satunya buat RWD satu lagi buat FWD. paling yg sama hanya jeroan dan blok atas, sisanya beda karena untuk FWD dan RWD.
    armann
    Post by armann »
    aratha wrote:
    imansyx wrote:
    lah iya ya bener juga kok sampe keluar gitu psd nya sienta, di freed mah masih jauh banget pas dibuka
    *ga pernah meratiin juga sebenernya*
    kalo saingan di pasar JDM sendiri banyak banget om, daihatsu concept carnya keren dan unyu2 (noriori, hinata, tempo).
    back to PSD,
    kalo di gambar ini gak keliatan ngelebihin body sih
    tapi kalo yang ini keliatan lebih banget
    apa beda ya bukan kanan dan kiri? atau foto angle nya aja ya :big_think:
    Itu fotonya diambil dr samping belakang, klo dr samping pas mah keliatannya panjang bner, msh oke sih kalo diperkotaan
    stevenanthony
    Post by stevenanthony »
    ChZ wrote:Wkwkwkwkwk kebiasaan panggil sembarang orang oom... biar awet muda :big_weee:
    Iya kalau ibu ibu atau nonik nonik yang bawa kan.... Biasanya kalo berenti gak dioper ke N. Ditahan rem aja walau berentinya 2 menit. Tuas transmisi kalo mobil matic dipegang ibu - ibu atau nonik fungsinya cuma D sama R aja.
    Ngomong nonik... lagi ngebayangin nonik2 pake Sienta warna orange atau kuning lucu juga yah... Lebih keliatan unyu dibanding pake Yasir. Terus pakaian dan tasnya warnanya sama gitu.... gemezzzzhhhh :big_love:
    betul banget :big_biglaugh: dibiarin aja di d kalau ijo langsung gasssss
    sayang disini gaada kuning ya kalau ga salah :mky_01:
    tapi jelas pasti akan keliatan lucu sekali... :big_love:
    nyumbang poto sienta entry level:
    slidingnya lagi kebuka, cuma tadi ga poto dan perhatiin sejauh apa lewatin bodinya...
    an again, ibu2. :big_weee:
    2015 Honda HR-V E CVT
    nyotnyet
    Post by nyotnyet »
    Nah entry level buka pintu ala espass tuh...manual...
    Tapi imho, sienta tanpa bodykit dan lampu led nya berkesan jdm banget...hehehehe
    Soul Red zoom zoom
    stevenanthony
    nyotnyet wrote: Nah entry level buka pintu ala espass tuh...manual...
    betul om, apalagi kalau putih, ditambah peleknya pakai dop begitu, kesannya kayak di japan... :big_exellent:
    ane ga sempet liat interiornya tadi, buru2 soalnyaa :mky_01:
    tapi di website tam ada nih fotonya.
    aratha
    Post by aratha »
    nah ini yang bikin saya deg2an, kata IBU-IBU ... kalo sampe pas TD istri saya suka bisa gatot minang FD2, kalo yang dilepas Freed ... saya tidak relaaaa :big_cry: . semoga aja tangannya gak nyampe ke shifter plus complain armrest :big_childish:
    IMHO sih, dari luar memang JDM banget ... tapi kalo di dalem malah Freed lebih JDM (open cafe dashboard). Kira-kira Sienta ini bakal keluar versi captain seat gak ya? dan jika memang keluar, kira2 bagus gak ya? kemarin pas di dalem kabin coba ngebayangin kalo pake captain seat. tapi kok kabin kayaknya kurang panjang ya.
    2007 RE1 2.4 A/T
    2010 GE8 RS 1.5 A/T
    2012 GB3 1.5 A/T
    Awalnya saya juga mikir gitu.... tapi....
    Perbedaan paling mendasar mesin itu dengan Sienta yaitu punya Avanza dikembangkan dan diproduksi Daihatsu. Sedangkan Sienta, seperti sudah diketahui, dibuat Toyota Indonesia. Mesin Avanza juga masih memanfaatkan besi baja biasa, bukan aluminimum seperti milik Sienta.
    Entah deh kebenarannya yang mana :big_biglaugh:
    stevenanthony
    aratha wrote: nah ini yang bikin saya deg2an, kata IBU-IBU ... kalo sampe pas TD istri saya suka bisa gatot minang FD2 plus gak enak banget juga sama kawan. semoga aja tangannya gak nyampe ke shifter plus complain armrest :big_childish:
    jangan td om, suruh baca review sm aja :mky_03: daripada nanti batal fd2, sayang lho...
    sienta dalemnya ga jadi jdm karena yang tau dashboardnya dirubah, fokus ke ac dan shifternya, jadi ordinary aja... kalo yang jdm ditaro dasbor nah baru deh keliatan jdmnya :mky_01:
    coklatMetalik
    Daily Vehicle: LGX
    Waduh beda bahan....
    Padahal konon Cylinder Head yang menggunakan bahan besi akan memerlukan Oktan yang lebih tinggi ketimbang menggunakan Bahan aluminium....
    CMIIW
    1979 Datsun GN620
    1992 Toyota KF40
    2000 Toyota KF82
    aratha
    Post by aratha »
    ChZ wrote:
    kunaskun wrote: basically, si iya, satunya buat RWD satu lagi buat FWD. paling yg sama hanya jeroan dan blok atas, sisanya beda karena untuk FWD dan RWD.
    CMIIW
    kayaknya kalo cylinder head saja gak pengaruh sama oktan, yang pengaruh banget di combustion chamber karena kompresi mesin kan disitu. makin tinggi kompresi makin panas combustion chamber. Makanya butuh oktan tinggi biar gas nya gak kebakar oleh suhu tapi tetap oleh busi. CMIIW juga ya
    2007 RE1 2.4 A/T
    2010 GE8 RS 1.5 A/T
    2012 GB3 1.5 A/T
    Nice review bro chz
    Wah kalo lemot........ bakal ane suruh pertahanin yasir ayah ane..... soalnya ayah ane tiba2 seneng ama sientong ini.... :e-think:
    jalananDOHC
    Post by jalananDOHC »
    aratha
    Post by aratha »
    stevenanthony wrote: jangan td om, suruh baca review sm aja :mky_03: daripada nanti batal fd2, sayang lho...
    kalo baca review di SM kan tetep aja ada pro n con ... pasti jatuhnya ya TD juga :big_childish:
    lagian istri saya ini agak2 pembalap, dulu waktu masih SMU aja dah bawa Feroza padahal saya malah cuma bawa Wonder HB. Jadi pastinya tetep 100% harus TD :big_dunno:
    2007 RE1 2.4 A/T
    2010 GE8 RS 1.5 A/T
    2012 GB3 1.5 A/T
    aratha
    Post by aratha »
    wah wah wah ... nice info om :big_exellent:
    open cafe nya bubar jalan ya berarti, dah gak ada JDM nya sama sekali nie. shifter masih di dash (good news) berarti aisle dari 1st row ke tengah tetap ada (semoga) yang kemungkinan juga captain seat tetap mengisi kabin ANF.
    2007 RE1 2.4 A/T
    2010 GE8 RS 1.5 A/T
    2012 GB3 1.5 A/T
    stevenanthony
    mirip2 sekarang om... temen2 cewe ada naik pajero x trail, ane cowo sama temen2 bawanya jazz yaris mazda 2... :mky_01:
    btw bentuk lobang acnya ga mirip ahond2 sekarang.. ada start stop engine dan abudant storage dibawah tempat gear lever... modelnya mirip2 crv re CMIIW
    tapi kalo mau masuk dari pintu penumpang ke driver masih ga kehalangan :mky_01:
    aratha
    Post by aratha »
    stevenanthony wrote: mirip2 sekarang om... temen2 cewe ada naik pajero x trail, ane cowo sama temen2 bawanya jazz yaris mazda 2... :mky_01:
    iya, kenapa kayak gitu ya? kalo Freed lagi dibawa ke bengkel juga dia lebih milih bawa Escape daripada GE8 (bikin budget bensin naik ajah) :big_slap:
    bukannya malah mirip ya? GK5 desainnya bukannya seperti itu ya? CMIIW sih, mata dan memori saya sudah makin termakan waktu (baca RENTA)
    pikiran kita sih gitu, gak taunya malah ada console tengah jangan2 nanti dan captain seat hilang :frm_bang_head:
    2007 RE1 2.4 A/T
    2010 GE8 RS 1.5 A/T
    2012 GB3 1.5 A/T
    nyotnyet
    Post by nyotnyet »
    Kok kayanya sienta ga captain seat karna sistem pelipatan jok ketiganya ya? Masuk ke bawah jok kedua gitu, kalo captain seat apa ga aneh jadinya...hehehe...
    Tapi harus diakui, sistem pelipatan bangku nya smart
    Kebetulan kmrn di showroom sempet lihat type Q, V dan G
    Yg G bener2 trondol, non start stop, ac manual, sliding sebelah kiri aja
    V saya malah suka tampilannya...clean gitu, tp lihat harganya yg terpaut 'cuma' 20juta, kok nanggung juga
    Terlihat di foto type V, krom grill cuma sedikit, lampu non 'alis', projie non led, dan no aerokit...saya lihatnya kok clean ala ala JDM...hahaha
    Dan berkebalikan dari pendapat bro Chz, item ya keren kok IMHO
    Soul Red zoom zoom
