Car Detailing Lounge - Part 01
Re: Produk apa yang anda gunakan untuk merawat mobil?
gw nambahin pertanyaannya, krn blm terjawab juga pertanyaan-newbie gw didepan:
- wax itu apa sih ?...apakah bhs inggrisnya poles=wax? ... apakah semua bahan pemoles itu disebut wax ?
- cara kerja wax...bagaimana dia bisa nggak mengikis clear coat, dsb...
- ada beberapa jenis wax kah ?.... kl kata bro abu2, wax yg dibikin dr bahan carnauba adalah yg plg mantap... kenapa bisa begitu ?
ane coba jawab:andy1800 wrote:gw nambahin pertanyaannya, krn blm terjawab juga pertanyaan-newbie gw didepan:
1. kalau di kamus wax = lilin kalau diterjemahkan, menurut gw wax itu adalah sebuah pelapis. contoh, seorang surfer melapisi papan surfingnya dengan wax agar tetap licin, nah kalau di kendaraan wax berguna untuk melindungi permukaan cat mobil agar tetap prima dan tak terpengaruh oleh sinar UV (sinar matahari) jd wax cm istilah saja..
mungkin bro andy bsa baca artikel ini:
The Differences Between Wax and Polish
People who are about to clean their cars often use these two termsâ€â€wax and
polishâ€â€interchangeably. But that does not mean that wax and polish are the
same. In fact, they are completely different. And using one, when you should use
the other, could result in expensive damage to your car’s paint, according to
Chuck Bennett of Zymöl Enterprises. Zymöl is the world’s leading producer of
premium car cleaners and waxes.
“Over the last decade, there have been major changes in the way manufacturers
paint their cars and trucks,†Bennett said. “And those changes in paint processes
make it very important that people use the right products to clean their cars,
enhance their vehicle’s appearance and, of greatest importance, protect the paint
from the sun and other environmental hazards.â€Â
A good place to start is to review the differences between wax and polish. “They
serve entirely different purposes,†Bennett notes. “Traditionally, most polishes
have contained abrasives that are suspended in a paste or liquid. They actually
grind away dirt and oxidationâ€â€or unsightly dead paint. Unfortunately, polish also
lifts good paint right off the car.â€Â
On a car with a standard finish, polish will grind away some of the paint and
transfer the color of the vehicle to the applicator. Use too much polish, or too
much pressure, and it is possible to go right through the paint. You will end up
exposing the primer or, worst of all, bare metal or fiberglass.
However, many people who use excessively abrasive polishes on new cars and
trucks may not realize the damage they are doing because the applicator does
not take on the color of the car, according to Bennett. “Most newer vehicles
today, and many older cars that have been restored, have a clear coat applied
over the color coat. This is a layer of paint without pigment that is designed to
give the finish greater depth and gloss.†Tackle the job of cleaning a clear-coated
car with an abrasive polish and you will not see the car’s color transfer to the
applicator. That, however, does not mean that you have not removed an
excessive amount of paint, or clear coat. It only means that you cannot see the
paint you have removed, since it is devoid of color pigments.
“An abrasive polish applied to a clear coat will do a tremendous amount of
damage,†Bennett said. “It’s really like scratching a mirror. You not only see the
scratch in the glass, you also see it reflected in the mirror coating. You actually
end up seeing two scratches despite the fact that only one scratch is present.
Use a polish on a vehicle with a clear coat finish and you will have thousands
and thousands of fine scratches reflected right back at you. It severely clouds the
finish.â€Â
In short, most car owners do not want to use a traditional polish. But if they think
“polish equals wax†when they go to the store, they could end up in real trouble.
Fortunately, there are high quality cleaners that can remove the dirt and oxidized
paint without causing all the damage now associated with traditional polishes.
Zymöl makes several products that clean beautifully without damaging the
surface including a new polish due out in 2009. And it is necessary to clean the
surface of the paint thoroughly before adding wax.
Once the vehicle is clean, it is the job of the wax to enhance the appearance of
the finish and protect the paint from the sun and other environmental hazards.
“Wax keeps airborne contaminants from reaching the paint,†noted Bennett. “If
these airborne agents get to the paint, they can start a chemical reaction. In
addition, wax refracts, or diffuses, ultraviolet and infrared radiation from the sun.
Without a coat of wax, the paint absorbs too much of the sun’s energy,
overheats, dries out and oxidizes. A waxed car will actually have a lower
temperature at the surface of the paint than a car that has not been waxed.â€Â
For people who are serious about protecting their automotive investment while
deriving maximum pleasure from their vehicle’s appearance, Zymöl makes a full
line of exceptional products designed to keep cars, trucks and motorcycles
looking new.
In lieu of polish, Zymöl Cleaner Wax or HD-Cleanse will clean without scratching
the finish. It will remove dirt, road grime and oxidized paint, allowing the natural
gloss of the paint to show through.
Zymöl’s waxes then add to the depth of this shine while providing unparalleled
protection for the paint. Since it contains exceptionally high concentrations of
Carnauba, nature’s hardest wax, Zymöl wax can be buffed to a brilliant shine.
And, unlike many other waxes, Zymöl does not employ harsh petrochemical or
petroleum-based solvents to make the Carnauba, which in its natural state is
literally as hard as a rock, usable. Instead, Zymöl softens it by using natural
montan oil. While petrochemicals may be less expensive, they can also soften
some paints. As a result, Zymöl provides exceptional protection and an
unequalled shine, without risking long-term damage to the finish.
To get more technical information or to have your car professionally detailed
contact your local Zymöl Licensed Detailer today!
Permisii
wah.. kalo paint protection saya kurang ngerti, coba tanya pada bro datsu di D2 salon mobil..esh wrote:Rekan2 SMers, saya permisi tanya nih, untuk perawatan cat body mobil, untuk mobil baru apa wajib pakai paint protection? Paint protection yang bagus merk apa ya sekarang? Kalau sudah pakai paint protection masih perlu diwax rutin? Mohon pencerahannya nih. Thanks
soalnya saya sendiri jg ga pake bro.. hehehe..
Permisii
nah.. ini gw liatin hasil koleksi gw selama ini
nah kalo yg ini MFnya..
sebetulnya jumlah MFnya kurang, jd kyanya gw mo nambah lg..
Permisii
- Daily Vehicle: just a bike
@ Hansen : Itu semua jurus dah gw keluarkan...kalo Om hansen sepertinya masih ada jurus pamungkas nih..he.h.e.heh
@ Nescafe....: Buset, koleksi Elo lebih banyak ternyata..wekekkekkekk..tersusun rapi pula di rak,
Nes, Shamppo NXT gw dah hampir abis tuh, beliin dong buat gw......
iya ness, MF nya kurang banyak, jumlah nya harus sama dengan jumlah obat yg dipakai. Jangan campur2 MF nya...Kompor Mode = ON
buset.. shampo gw aja ga ampe galonan nya mas abu2.. hehehe..
iya, emang kurang, kalah jauh sama obatnya.. hehehe..
ntar ah, lg nabung, mo ngeborong sekalian.. hehehe..
Permisii
galonannya lebih murah Nes, dan sekarang Harga nxt shampo dah jauh lebih murah dibanding gw beli dulu...
ada yg mau bayarin TW platinum shampoo gw? baru 2 kali pakai nih...he..he.hehe.
klo gw pake zymol itu jg belom abis.. sama shampo KIT.. hehehe..
yawda, gw beliin NXT, mas abu2 beliin gw MF.. gmn?
coba buka thread di business corner.. ada ga yg beli..
Permisii
wekekekekekk
harga nya juga gak sampe cepek, masa buka thread...wekekkekekek
iseng2 aja....
ntar paling gw hibahkan ke kantor aja, buat nyuci mobil kantor...
iseng2 aja....
yahh.. jangan,,, ke gw aja.. msa nyuci mobil kantor pake TW mas?
yah.. yah.. yah.. plissss..
Permisii
nescafe wrote:yahh.. jangan,,, ke gw aja.. msa nyuci mobil kantor pake TW mas?
hmmmm.....mobil kantor khan kadang gw jg yang pakai Nes..biar bersih gitu....
atao, ntar kalo ke jkt, gw bawain TW, trus elo traktir gw ngupi2 aja di CB at SB ya...gimana....
yah..yah...yahh..pliss juga
wakakak! yawda boleh ajah, tp mas abu2 ga malu ditraktir anak muda kya saya?Abu2 wrote:nescafe wrote:yahh.. jangan,,, ke gw aja.. msa nyuci mobil kantor pake TW mas?
Permisii
iya, gw juga mas.. malah kadang2 mobil kantor tak grooming jg.. sekalian ujicoba produk..
Permisii
@ nes, kalo namanya di traktir, gak perlu malu...wekekkekeek
kabur...............
Permisii
Hasil uji tes produk Amway SILICONE GLAZE
pada baretan ringan di cover spion gara2 di srempet motor
ternyata manjur banget, hasilnya mulus lussss seperti baru
gw polesnya pake alat sih
makainya gw tekan agak keras...
gara2 saking manjur nya... kok gw jadi ragu yah
jangan2 silicone glaze itu mengupas cat yah??
ada SM'ers laen yg dah uji tes ni produk??
gw udah boz.. waktu itu udah 2 botol ngabisin, n gapapa koq, fine2 aje.. hehehe..
tp nyarinya susah, harus ke aldiron dulu (tempat distributor amway) soalnya deket rumah ane uadah ga ada yg jual..
Permisii
benarkah...?nescafe wrote:gw udah boz.. waktu itu udah 2 botol ngabisin, n gapapa koq, fine2 aje.. hehehe..
jadi tenang dah gw... hehehe
hasilnya emang cihuy bro, tp klo pakai mesin ya hati2 lah.. u know lah..lucky_strike_21 wrote:benarkah...?nescafe wrote:gw udah boz.. waktu itu udah 2 botol ngabisin, n gapapa koq, fine2 aje.. hehehe..
Permisii
Thanks om nescafe, hari ini saya sdh kontak teman saya yg punya salon mobil, dia recommend pakai paint protection Ziebart, lalu tunggu satu bulan supaya benar2 mengeras lapisannya baru dia wax jadi lebih glossy. Saya biasanya tidak terlalu heboh dengan paint protection, tapi karena warna dark mocca mau tidak mau butuh perhatian ekstra.
Ok bro!
ntar kalau sudah di paint protection, upload fotonya ya..
Permisii
hah...nescafe wrote:hasilnya emang cihuy bro, tp klo pakai mesin ya hati2 lah.. u know lah..
emang kenapa kalo pake mesin bro?
gw gak ngerti akibatnya.....
mohon petunjuk dan nasehatnya bro...
nescafe wrote:wakz! ga mau nyerah dye..
awaas Nes, kalo gw ke jkarta, gw cari elo , sambil nenteng2 TW shampoo...huahauhahahahaha
menurut testi temen2 yg dah pake amway SG, produk in bagus, mengkilat, licin..kelemahannya cuma 1 mnrt gw, karena berbahan dasar silicon, produk ini jadi narik debu..istilahnya, debu cepat hinggap di body, tp ya tinggal dusting pake kemoceng(cari kemuceng yg aman ya) atau dusting pake shaq towel aja..lucky_strike_21 wrote:Hasil uji tes produk Amway SILICONE GLAZE
pada baretan ringan di cover spion gara2 di srempet motor![]()
nih dah jurus terakhir gw...
kaga ada lagi dah...
tapi yg tiga ini semuanya masi disegel alias blom pernah dibuka sama skali...
wekekkekekekek...
ampun deh ama nes & Abu2...
wekekkekekekek...
