Piaggio MP3 - skuter roda tiga?
tersedia dalam rasa 125cc dan 250cc
tech spec dan lainnya ada di
http://www.mp3.piaggio.com/index_eng.html
http://www.vespaway.com/2006/05/leaning_toward_.html
The full extent of this three-wheeler's stability can be tested on wet asphalt or tough riding conditions that would sorely challenge a traditional two-wheeler.
In town and city traffic the PIAGGIO MP3 has no equal in terms of safety. It takes on cobblestone streets, patchy asphalt and tram tracks with the greatest of ease, remaining safe and stable all the while.
With its compact super-scooter size and exceptional manoeuvrability, the PIAGGIO MP3 is at home in town traffic. It's a cinch to park: an electro-hydraulic suspension locking system means there is no need to put the vehicle on its stand.
klik disini utk lihat infonya
Re: Piaggio MP3 - skuter roda tiga?
kok gambarnya pada ilang seeh....
padahal nampaknya asik juga loh ini motor.... kaki kita gak usah turun...
hayoo, siapa yg ingin naik motor tanpa perlu sibuk kakiknya ?.....
yang baru sekarang 250cc ama 400cc...
www.youtube.com/watch?v=bHorKJoG408
kalo versi gilera-nya fuoco 500cc...
www.youtube.com/watch?v=nMT_Yd7gJPM
www.youtube.com/watch?v=CRl8KQRs3sA
Harganya?
Bisa beli APV/Granmax/Karimun Estilo..
Hueleh.. 110 jt..
Hueleh.. 110 jt..
Bisnis? Sini donk..
Bisnis? Sini donk..
GILERA FUOCO 500ie - Technical specifications
Engine- Single cylinder Master 4 stroke with double ignition, four valves, and electronic fuel injection
Displacement- 492.7 cc
Bore- 94 mm
Stroke- 71 mm
Fuel- RON 95 unleaded petrol
Compression ratio- 10-11: 1
Max power at crankshaft- 40 HP (29.5 kW) at 7,250 rpm
Max torque- 42.23 Nm at 5,500 rpm
Exhaust- Closed loop system with lambda sensor and three-way catalytic converter in exhaust pipe
Valve train- (SOHC) 4 valve, electronic injection
Ignition- Electronic inductive discharge and variable spark advance in electronic unit with electronic immobilizer.
Fuel pump shutoff when bike tips over. Two spark plugs.
Starter- Electric
Cooling- Liquid with three-way thermostat
Gears- Twist-and-go CVT
Clutch- Dry centrifugal type with damping plugs
Frame- Double cradle trellis made of high strength steel tubes
Front suspension- Parallelogram composed of four aluminium arms supporting two steering tubes, cantilevered
suspension. Travel: 85 mm. Electro-hydraulic suspension locking system.
Rear suspension- Oscillating engine fixed to the frame with a swingarm and two dual effect hydraulic shock
absorbers with four-position spring preload. Travel: 110 mm
Braking system- Traditional: separate hydraulic brakes on front and rear wheel. Parking brake: mechanical; locks rear wheel.
Front brakes- Stainless steel double disk, Ø 240 mm, two-piston caliper
Rear brake- Stainless steel disk, Ø 280 mm, floating two-piston caliper
Front wheel rims- Die-cast aluminium alloy, 3.00x12â€Â
Rear wheel rim- Die-cast aluminium alloy, 4.50x14â€Â
Front tyres- Tubeless 120/70-12†51S
Rear tyre- Tubeless 140/70-14†68S
Length- 2,160 mm
Width- 775 mm
Wheelbase- 1,550 mm
Seat height- 785 mm
Dry weight- 244 kg
Fuel tank capacity- 12 litres (includes 1.8 litres reserve)
Max speed- Approx. 145 Km/h
Distance covered under ECE Euro 3 conditions- 21 km/l
Emissions- Euro 3
yaaaaach, anggap saja harganya 1/3 nya HD....tp udah dpt motor yg hampir sama gedenya.... matik, dan lbh praktis...r1210g wrote:Harganya?
Hueleh.. 110 jt..
huehehee
itu miringnya ikutin speed or gimana ya
*sotoy mode:
nampaknya mengikuti berat tubuh deh.... kayak MotoGP
yah ngapain pake 3 roda dong
kan kalau MotoGP brenti di prapatan, kaki kita harus turun.
kalau MP3... kaki bisa tetep ongkang2.....
klau diserang lagi: kenapa gak pake citycar aja ?.....
jawabnya: kan pakai mobil gak bisa selip2 ....
trus: tp kalau pakai mobil kan nggak kehujanan....
jawab: kan bisa pakai jas hujan....
kayaknya kalo ampe miring gitu, pas nikung kenceng om...GTR wrote:yah ngapain pake 3 roda dong
nah kalo 4 roda (mp4 kalo ada), tapi trus dibikin miring gitu 4rodanya, lebih stabil nikung kenceng... j/k
kalau perlu, dibikin jg yg AAC dan GP3, biar bisa diliat di handphone..... j/k
ada om, yamaha bikin motor kaya gitu, 4roda nikung bisa miring, tujuannya emang ngedapetin corner speed yg kenceng...GTR wrote:nah kalo 4 roda (mp4 kalo ada), tapi trus dibikin miring gitu 4rodanya, lebih stabil nikung kenceng... j/k
sayang masih concept bike
3gp kali om...andy1800 wrote:kalau perlu, dibikin jg yg AAC dan GP3, biar bisa diliat di handphone..... j/k
^ hahhaaa, ketauan kaaan, kalau gw nggak terbiasa liat file-file "video 3gp" yg begiitu rupa ....
lanjuuttt.....
lanjuuttt.....
spin022 wrote:ada om, yamaha bikin motor kaya gitu, 4roda nikung bisa miring, tujuannya emang ngedapetin corner speed yg kenceng...GTR wrote:nah kalo 4 roda (mp4 kalo ada), tapi trus dibikin miring gitu 4rodanya, lebih stabil nikung kenceng... j/k
spin022 wrote:spin022 wrote:ada om, yamaha bikin motor kaya gitu, 4roda nikung bisa miring, tujuannya emang ngedapetin corner speed yg kenceng...GTR wrote:nah kalo 4 roda (mp4 kalo ada), tapi trus dibikin miring gitu 4rodanya, lebih stabil nikung kenceng... j/k
waduh.. iya yah, cool...... verdict : yamaha "mp4"
@^ masih concept bike bro
argh..
bikin ngarep aja ni motor.
T__T
T__T
^ yg diarep yg MP3, atau yg "MP4", atau yg "motor" M500 itu ?
