Ranking Dan Pemilihan Oli Mesin - PART 20
Re: Ranking Dan Pemilihan Oli Mesin - PART 20
ctopher7 wrote: Sun Feb 23, 2025 17:35
Suryaputra wrote: Sun Feb 23, 2025 8:22
sintoni wrote: Sun Feb 23, 2025 7:53
Boleh aja mau campur gimana jg.
Cuma nurunin kualitas oli sintetisnya, jadi ga sebagus full sintetis.
Mineral campur sintetis kan jadi semi sintetis.
"There is no danger mixing synthetic and conventional motor oil"
"In fact, synthetic-blend motor oil is simply conventional and synthetic oil already mixed for you"
Sumber: https://blog.amsoil.com/can-i-mix-synth ... ional-oil/
Idemitsu 0w16
Prima XP 20w50
Jadi 10w30 yaa
skalian lah campur migor tropical + pro capacitor di selang bensin + cementitit di kamar
+BRQ
+Magnet Oli
+Ester
vanosz
Post by vanosz »
sintoni wrote: Sat Feb 22, 2025 23:06 Ga ada masalah itu beda visko atau mineral sintetis.
Ga osa terlalu parno.
Gak apa,
Ini kan trit bikin parno,
Lanjutkennnnnnn
vanosz
Post by vanosz »
Buset,
Ngpn cementitit dikamar,
Bidadari syurgah masih banyak,
Apa perlu ane kenalin panlok muda bohai,
Tp ini buat agans aja ya,
Jangan kasi tau yg lain,
well
Daily Vehicle: Sepeda Ontel
Post by well »
suketcell wrote: Sat Feb 22, 2025 1:59
sahabatq8 wrote: Fri Feb 21, 2025 6:25
sahabatq8 wrote: Fri Feb 21, 2025 4:52
permisi om, mau tanya, panda auto yang di tokoijo itu rekomen ga?
Mo ambil advance plus, per pcs selisih 30k euy sama yg official... :big_blushing:
Oiya, bonus jaketnya itu harus di atas lima liter / lima liter aja boleh?
Bisa nggak beli sendiri gituh? Nyaman dipakeknya :big_okay:
Punya ane diambil orang... :big_cry:
Nuhun....
[/quote]
secara keaslian barang ckp rekomen, cuma sy pernah pny pengalaman buruk mengenai pelayanannya di panda auto
pesan 2 coolant dikirim cuma 1, kebetulan sy kirimnya ke kantor dan brgnya nyampe di kntr jumat malam, sy br bs cek senin pagi (orderan sudah dr marketplace sudah nutup otomatis), toko panda auto tdk mau di komplain, pdhl sy bilang sy ada video pada waktu unboxing.
kayukayuthe5th
Post by kayukayuthe5th »
sintoni wrote: Sun Feb 23, 2025 5:14 Engine oils from different manufacturers can certainly be combined. If you want to mix oils from different manufacturers, pay attention to the following key points to rule out major problems:
Both oils must be approved by the vehicle manufacturer
Both oils should be either mineral or synthetic.
If the engine has approvals for different SAE classes, different viscosities can also be mixed, e.g. 5W30 and 5W40.
Sumber: https://addinol.de/en/products/lubrican ... il%20label.
apalagi ternyata baru nyadar atas ane bilang "darurat" yah gaspol aja.
kayukayuthe5th
bocoran new cover bwat fastron gold......."ultra performance" :mky_03:
azu
Post by azu »
well wrote: Mon Feb 24, 2025 3:15
Nuhun....
[/quote]
saya malah pernahnya pesen Honda Engine Cleaner 1 botol, datangnya 2 botol :big_biglaugh:
baru ngehnya beberapa hari kemudian pas buka bungkusan paketnya
Past
2007 Toyota NCP93R-BEMGKD
Current
2013 Toyota ZRR70R-APXEPD
Disclaimer:
AbdulHakim
Post by AbdulHakim »
kayukayuthe5th wrote: Mon Feb 24, 2025 5:30 Image
Wuih logo kebo nyodok balik lagi
Auto wajib cobain nih
Udah ada di marketplace blum nih?
well
Post by well »
azu wrote: Mon Feb 24, 2025 5:35
Nuhun....
[/quote]
anda beruntung, sy buntung :big_cry:
alvin23
Post by alvin23 »
AbdulHakim wrote: Mon Feb 24, 2025 5:59
calon oli langganan ni API SP muraaah :big_biglaugh:
Rocky R ADS CVT 2021
t105erd
Post by t105erd »
Ga masalah sih kalo saya yg penting oli campur oli, bukan oli di campur bensin, minyak goreng, margarin dll...
Dalam prakteknya saya biasa top up oli di motor Yamaha yg terkenal boros oli, 10W40 saya top up pakai rimula 15W40 atau enduro 20W40 wkwk...
Atau pas ganti oli kemarin 3 liter Enoc saya tambah 500 - 650ml GM Tech :big_biglaugh:
Di yutub juga ada deh yg paman2 yg eksperimen nyampur2 oli buat dipakai setahun.
Jadi yaa apa ada orang nyampur 0W16 sama 20W50?
t105erd wrote: Mon Feb 24, 2025 9:00
another komen mantep :big_exellent: :big_exellent:
campur2 slama oli nya jenis sama, gapapa, ini mesin, bukan ruang OK di ruma sakit yg harus serba steril
kbanyakan takut2 , di ketawain ntar ama sales2 oli , mangsa empuk buat d kibulin katanya :mky_03: :mky_03:
saturday
Post by saturday »
DOHC wrote: Mon Feb 24, 2025 9:11
Alphard 2020 saya oplos oli sisaan PTT 5W30, Fastron 0W20, Q8 0W20, sisanya PTT 0W30 2 literan kayaknya sampai mencukupi, aman aja.
saturday wrote: Mon Feb 24, 2025 10:36
1TR vvti dua biji kita orang jg skrg pakenya oli sisa smua, scara cuman jadi garage queen doank
trakir kl ga sala cocktail PTT botol item 5-30, repsol gxr 5-30, sdikit castrol edge LL 5-30, ama prima xp 15-40
ud ampir 3 taon cocktail campur2 gini, aman jaya seh, ga ad sludge macem2 , mesin masi kinclong warna aluminium
saturday
Post by saturday »
DOHC wrote: Tue Feb 25, 2025 2:02
Segala jenis sisaan (baru) oli mesin buntut 20 dan 30 biasa saya tuang buat ganti oli Alphard atau dulu ke HRV.
Kalau sisaan (baru) oli mesin buntut 30 dan 40 mau diesel atau bensin oplos saja untuk motor saya dan pompa Honda GX160.
Sejauh ini sih semua masih beroperasional dengan baik. Sejauh ini....
saturday wrote: Tue Feb 25, 2025 2:13
pecayalah
sejauh ini beroperasi baik, dan selamanya akan begitu ...
kl mesin bagus ya bagus aj, ga bakal rewel dikasi oli cocktail gt
kcuali emg bawaan nya mesin ampas, ini mo dikasi oli tetesan termurni dari kilang jg tetep aj bakal jd mesin ampas
sh00t
SM Moderator
SM Moderator
Post by sh00t »
DOHC wrote: Tue Feb 25, 2025 5:04
pecayalah
mesin ampas ini maksudnya mesin yang baru atau sudah lama pak? kalau baru, ntar yang disalahin mesinnya lagi, bukan olinya. :upss: :ngacir: :ngacir: :ngacir:
DLM
Daily Vehicle: Vios G
Post by DLM »
Selamat siang, jadi kebetulan saya akhirnya ganti oli di Vios yang biasa dipakai buat mobil harian pakai oli CTX Rev GT 5W-30. Kebetulan di B-Quik dekat rumah sedang ada promo ganti oli + filter (filter sakura sih) untuk tipe oli tersebut hanya 909 ribu rupiah. Pertanyaan saya, kira-kira, oli ini tahan berapa ribu km ya? Kemarin karyawan front desknya bilang ke saya bahwa sebetulnya oli ini bisa 15 ribu km, tapi oleh B-Quik disarankan untuk diganti per 10 ribu km. Nah, orang bengkelnya sendiri bilang karena mesin mobil yang saya pakai sudah berkerak, saya disarankan untuk lebih merutinkan ganti oli dibanding sebelumnya. Apakah memang harus diganti lebih cepat? Pemakaian sehari-hari bisa sampai 160 km lebih dari Senin sampai Jum'at, rute campuran tol+dalam kota, beberapa kali genset. Kilometer sudah menyentuh 215 ribu kilometer, akhir tahun 2024 baru saja ganti satu set radiator karena yang lama bermasalah (bocor). Terimakasih.
azu
Post by azu »
DLM wrote: Tue Feb 25, 2025 6:34 Selamat siang, jadi kebetulan saya akhirnya ganti oli di Vios yang biasa dipakai buat mobil harian pakai oli CTX Rev GT 5W-30. Kebetulan di B-Quik dekat rumah sedang ada promo ganti oli + filter (filter sakura sih) untuk tipe oli tersebut hanya 909 ribu rupiah. Pertanyaan saya, kira-kira, oli ini tahan berapa ribu km ya? Kemarin karyawan front desknya bilang ke saya bahwa sebetulnya oli ini bisa 15 ribu km, tapi oleh B-Quik disarankan untuk diganti per 10 ribu km. Nah, orang bengkelnya sendiri bilang karena mesin mobil yang saya pakai sudah berkerak, saya disarankan untuk lebih merutinkan ganti oli dibanding sebelumnya. Apakah memang harus diganti lebih cepat? Pemakaian sehari-hari bisa sampai 160 km lebih dari Senin sampai Jum'at, rute campuran tol+dalam kota, beberapa kali genset. Kilometer sudah menyentuh 215 ribu kilometer, akhir tahun 2024 baru saja ganti satu set radiator karena yang lama bermasalah (bocor). Terimakasih.
Vios yg engine 1NZ-FE om? emang ini cukup banyak kasus berkerak seperti punya saya dulu juga om :mky_01:
kalau saya akhirnya beli oli biasa aja gausah yg terlalu mahal atau oli apapun yg lagi diskon. Pakai maks 7.500km, seringnya 5.000Km juga ganti om. terakhir saya sebelum dijual ke ipar itu mobil saya ganti oli pakai Petronas diskonan cuma 310rb per galon :big_biglaugh:
Past
Current
Disclaimer:
DLM
Post by DLM »
azu wrote: Tue Feb 25, 2025 6:54
Iya om yang 1NZ. Sebelumnya selalu dicekokin TMO. Akhirnya nyoba nyari bengkel lain. Awalnya dari rumah mau pakai Shell (kebetulan mobilnya punya bapak saya dan beliau minta Shell), sampai di B-Quik saya tanya ke front desk nya, mana yang setara TMO. Ditawarin CTX sama Motul, akhirnya ambil CTX karena lagi diskon.
azu
Post by azu »
DLM wrote: Tue Feb 25, 2025 6:56
sama kasusnya, dulu juga mobil saya dicekokin pakai TMO terus servisnya setiap 10rb Km :big_biglaugh:
pas di saya, saya sempet beberapa kali ganti oli pakai merk negara teluk sana terus rasanya tp ya penguapan tetep ada dan keraknya juga seperti nambah dengan OCI setiap 7.000Km.
akhirnya saya coba Kixx aja yg lebih murah dipakai sampai 5.000Km, rasanya penguapan malah lebih minim :big_biglaugh:
terakhir ganti Petronas 3000XS, rasanya sih masih lebih enak pas pakai Kixx ya tapi lumayan dapet harganya murah :mky_01:
Past
Current
Disclaimer:
sh00t wrote: Tue Feb 25, 2025 5:33
pecayalah
neruga :big_think: :big_think:
tp parameter baru atau lama gt susah jg,
mikrolet pake mesin jadul jaman ali sadikin kuat
inofa jaman mulyono jd gubernur jg kuat
serba salah jadi gini :big_dunno: :big_dunno:
kayukayuthe5th
di s4d1kun masih pake lama sih terakhir cek. bentar lagi kalo kaianya kasus ecogreen dulu bocor, ternyata emang ganti cover (dimiripin ala2 techno yang baru semua plus skrg cman bilangnya synthetic oil)
ini yang dari tokped *bukan ajakan membeli, tidak terafiliasi maupun dibayar oleh pihak tertulis
https://www.tokopedia.com/kawanlamaoli/ ... c%3Dsearch
alvin23 wrote: Mon Feb 24, 2025 8:09
ada techno :big_grin: lebih murah
vanosz
Post by vanosz »
Mknya ini trit isinya sugesti,
Pake a sbentar pindah ke b pindah ke c,
Gak ada yg pake merk a sampe diatas 100 ribu km,200,300,
Selalu amsiol luar biasa,sebangsanya,
Kata forum betog bla bla bla,percaya aja karena itu forum suhu mbah,
Mknya trit susgesti ky begini selalu diatas,sampe kiamat kynya,
Bus toyota ane pake tmo dr baru sampe jual hampir 150 ribu km,
Masih segar nyenderin jarum sepet ke pojok kanan bawah lewat dikit angka,
Lintas sumatera utara gaspolllll trs top sepet 160,
Uber uberan sama inova KD dan LC 200,
kalahnya cuma ketemu jalan rusak dan perlintasan kereta,
Truk ane modifan harian ngaspollllll tangerang jakarta,sampe loncat geser bodi,
Ada yang 65 ribuan km pake tmo dr baru,pake solar busuk tanpa aditif,filter solar beli online gocap ceng,mesin 2.8 nih yang katanya rawan,
Ada yang 159ribuan gado gado oli skarang pake tmo,
Sekarang coba jalan yang benar,pake a lanjut terus sampe ratusan ribu km,baru nanti ke b,
Ane pernah tambahin oli 0-16 pake fastron 10-40 stok dari taun 2008 ada di rak,udah kebuka,kepake dikit karena buat lumasin roda gerbang,
Daripada gak kepake,kbetulan liat aja,
Drpd penuhin rak,
Mobil ane walo bgtu di dyno tenaga masih jossss pake gandos bingiiiitttt
Klo mau bayarin boleh tuh,buat riset,klo ada duit,
Antara jual niat separo cocok harga,karena mobilnya enak banget,
Buat kurangin garasi,karena mau beli mobil baru,
Btw,
Lanjuttttkennn sugestinya,
Sampe bumi gonjang ganjing,
Ngassssssssssss
Oli itu yg penting:
- Cooling system mesin kudu prima
- Asli
- Gak nguap berlebihan
Klo test lab bagus dsb, ya itu jadi bonus
Yg penting bensin berkualitas dan gak dikorupsi :ngacir:
