vario clone: Beijing Scootic
SPECIFICATION
Engine Type : Single-Cylinder, 4 stroke, with forced air cooled
Bore x Stroke : 52.4 x 57.8 mm
Piston Displacement : 125 cc
Maximum Power (kw/r/min) : 6.0 kw/7000r/min
Maximum Torque (N.m./rpm) : 7.65 N.m/6000r/min
Clutch : Dry-tape, automatic separate
Lubricant : preasure/Splash
Starter System : Electric - Kick Starter
L x W x H : 1897 x 680 x 1083 mm
Wheel Base : 1273 mm
Dry Weight (kg) : 108 kg
Min. Ground Clearance : 132,5 mm
Brake Front : Disk brake
Rear Front : Kick / Drum
Tyre Front : 80/90
Tyre Rear : 90/90
Ignition System : CDI
economical fuel consumsion : 2.8 L/100km
A.D.J.O.K.A.S.E.P
The Mocin Rider
http://sisteminformasiakademik.wordpress.com
http://sistem-informasi-akademik.blogspot.com
http://www.academic-portal.net
The Mocin Rider
Re: vario clone: Beijing Scootic
wow..
matic ada clone nya juga?
kira2 harga berapa nih ya??
