mio soul clone: beijing exotic
SPECIFICATION
Engine Type : 4 stroke, single cylinder with forced air-cooled
Engine Model : 1P52QMI / 1P52YMI
Piston Displacement : 125 cc
Bore Stroke : 52.4 x 57.8 mm
Maximum Power (kw/r/min) : 6.2 kw/7000r/min
Maximum Torque (N.m./rpm) : 7.65 N.m/6000r/min
Clutch : Dry ttype, automatic separated
Lubricant : Pressure/splash
Starter System : Electric - Kick Starter
L x W x H : 1897 x 680 x 1083 mm
Wheel Base : 1273 m
Min.Ground Clearance : 132.5
Dry Weight (kg) : 108 kg
Brake Front : Disk Brake / Hand Control
Rear Front : Tromol
Tyre Front : 80/90
Tyre Rear : 90/90
Ignition System : CDI
Economical Fuel (1/100km) : 2.8 L/100 km
A.D.J.O.K.A.S.E.P
The Mocin Rider
http://sisteminformasiakademik.wordpress.com
http://sistem-informasi-akademik.blogspot.com
http://www.academic-portal.net
The Mocin Rider
