Kuda Diesel Grandia babe gw aja sampe tuh 150kpj... Diesel coy.. AC dobel nyala semua..!maskopat wrote:mungkin harga partnya yang relatif mahal.. tapi ini terbayar dengan daya tahan yang lebih lama...
kelemahan yang sering terjadi di mobil2 ini adalah, driver pengennya bejeg gas mulu.... maklum, biasanya driver mobil2 mitsu paling sebel lihat "kapsul" di depan dan di jalur kanan... berasa kenceng tapi tak mampu lebih dari 120kpj..
LANCER EVO-IV SEi - PART 01
Re: LANCER EVO-IV SEi
satu lagi testimoni dari anak pengguna mikugra...VanzMatic wrote:Kuda Diesel Grandia babe gw aja sampe tuh 150kpj... Diesel coy.. AC dobel nyala semua..!maskopat wrote:mungkin harga partnya yang relatif mahal.. tapi ini terbayar dengan daya tahan yang lebih lama...
masih ragu dengan mikugra?????
- Daily Vehicle: Unimog
?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????aburaza wrote:ngasepin boil mahal2 = pengawal pawai (bnyk merk)ak4ng wrote:ente kaya yg ga tau aja,,, yg biasa ngasepin boil mahal2, raja jalanan,, ''sakti'' lagi,,
Raja jalanan = yamaha rx king (bukan boil tuh)
Yg sakti = 9 benua
Narsis ..maskopat wrote:yang tua aja kenceng....
Yg sakti = 9 benua
- Daily Vehicle: BRIO black elegant
CK 4 is still d BEST
@Bram : Ada rencana mau balik lagi ke CK4 ga, Kang? Gw pengen euy balik lagi.....
CK4 tu ap?????
CK4 itu Lancer model Evo IV, mas Ak4ng.....ak4ng wrote:CK4 tu ap?????
Orang banyak menyebutnya Evo, padahal Evi......
@HIKOZA...maksud hati buyback my Blue Saphire Metalic CK4..
Apadaya...bonus c'ma cukup bli Vario...'ntu-pun sebagian buat bayar utangs Hiks
CK4 taun brpan??? outputnya brp??? seri mesin ???
CMIIW....CK4 itu kode untuk model mitsubishi lancer kang. kalo gak salah lahir tahun 1997. ada 2 varian : GLXi dan SEi
pake mesin 4 silinder berkode 4G92 dengan kapasitas 1.600 cc SOHC 16 katup dan berpenggerak roda depan.
segitu aja yg ane tau kang. kalo lebih detailny biar para master mitsu yg jelasin.
eh iya, ada disini nih tret mitsu lancer : http://www.serayamotor.com/diskusi/view ... f=5&t=6321
Gue tetap kangen sama CB5 ku, untungnya yg beli masih adek sendiri jadi kalo kangen masih bisa pinjemBram wrote:CK 4 is still d BEST
@Andrian Membangkitkan thread lama dari liang kubur
@Dennif....gw masih pemasaran 'ma CB5 KONON..bejek Gaz..srasa ditendang JIN ...
Apa Marksungkar..PEMASARAN gw..Herman sayah
@Bram : It's ok, Kang. Yang penting ente tetap dengan prinsip jujur kyk dulu, it's more than everything lahh...
Gw juga udah 2 thn pake si Sipik, pengen ganti sebetulnya, tapi skrg mahh ada cicilan rumah euy..., jauh lebih penting...
@Akang : Nahh..., itu udah dijelasin sama om Andrian. CK4 alias Lancer "model" Evo IV ada 2 varian, GLXi dan SEi.
Bedanya di aksesoris, SEi itu : airbag, retrac mirror, bodykit sporty.
Produksi CK4 ini dari 1997 s.d 2001 klo ga salah, karena Lancer 2002 udah model Evo V lampu belakangnya, CMIIW...
Outputnya 115 HP, seri mesin 4G92 (1600 cc SOHC)
Untuk ak4ng cukup diterangkan bahwa CK4 itu bukan apanja dan bukan toyota
Pernah googling , Ck4 standart kalau soal adu top speed kalah ama livina 1.5 ya . kec diatas 180 udah ngos ngosan...
bener nggak sih???
Kalau logikanya mesin sohc konvensional vs dohc variable valve , bisa jadi ck4 kalah ya??
Bener nggak sih????
bener nggak sih???
Bener nggak sih????
sy mah kalo mau kebut2an pake 6g72tt awd 550 hp,,, tp g ad di indo euy (baik mobil maupun jalan utk menikmatinya)
@gmx: ntar ada,, gw yg bkin,,
@om Dino : Bisa iya bisa engga, om. Klo pengalaman saya pribadi dulu pake CK4 justru enak saat high speed, tarikannya yg agak loyo menurut saya.
@ak4ng : Wuiiihhhhh mantaapppp..., difoto dong mas Ak4ng mobilnya, biar kita2 yg di Indo ini bisa ikut at least menikmati fotonya dulu.....
@hikoza: itu impian sy yg ngawur abis,,, blm nemu sy di indonesia ada 6g72tt awd,, sehingga sy mah menikmati k3-ve atw ga 1nz-fe,,,
'Nie pke TURBO....Ngeeeng....Cessssss...as u can c below!
cuma knalpotnya yg kliatan,,,,
@ak4ng....wah 'klo situ liat Engine-nye...Blow Off CoY...Ngueng..Cesss..2 bad 'dach ke Jokul..
kenceng mana sama apanja,,,?????
@ak4ng.....apanja based on my experienced..160kph..engine dach meraung ngeri
G type 1.3.......CK4 TuRBo....my ex.CK4 blue saphire metalic aze tewas Gan... ........
so...apanja sech bisa di predict laaa.....bukan lawannya CK4 TurBo......
Apanja lumanyan sech buat kelas2 niaga..kga tau tuch yg perform yg 1.5....180kph mentok bisa kalee
pokoke apanja...ama CK4 standard...aze TEWAS-Laaaaa....apalagi pke Turunan BONDON (TURBO)
No offense....do not tke it personally..but it's Fact
FYI/FYA
Data Spec CK4 sbb :
1600cc
115hp
Front WD
Data aklerasi 'n Top Speed My ex CK4 as u can c below
Pas gw Jajal 'ma ex CK4 gw ...mke me impress...tarikan bawah...
karena gw merasa koq uenteng yak...
1st gear 60kph...rpm 6500 batas red line
2nd gear 100kph..rpm 6500 batas red line
3rd gear 140Kph..rpm 6500 batas red line
4th gear 165Kph...rpm 5000-an
5th gear 205kph..rpm 5000-6000-an
FYI/FYA
Data Spec CK4 sbb :
1600cc
115hp
Front WD
