Lagu2 rekaman sendiri (vocal & electric piano by Jeskoneng)
Re: Lagu2 rekaman sendiri (vocal & electric piano by Jeskone
om jes, kompi ane di kantor ndada spikernya..... jaddi nda bisa ngedenger.... :ungg: :ungg:
jack audio nya langsung colok ke kuping aja oom
:ngacir: :ngacir:
doq wrote:jack audio nya langsung colok ke kuping aja oom
:ngacir: :ngacir:
engga punya om qod... jack audio ane untuk Samsung windows ane... Engga sama lah...
:ungg: :ungg:
pinjemin donk spiker bekas ente, mod.... :ngacir: :ngacir:
wahhh spiker bekas saya udah ga layak pakai oom :ungg: :ungg:
malu atuh hibahin speaker butut ke master audiophile :ungg:
doq wrote:wahhh spiker bekas saya udah ga layak pakai oom :ungg: :ungg:
Master audiophile dari manee...? Mobil cuman modal radio tape doank, kan ente dh tau kalo ane cuman modal kaset.... :ungg: :ungg:
ngemeng2 kaset, oom VM tau ga cara nya nge-back up kaset jadi digital audio (mp3, aac, wma dll)?
doq wrote:ngemeng2 kaset, oom VM tau ga cara nya nge-back up kaset jadi digital audio (mp3, aac, wma dll)?
Kamsutna ngrekam dari kaset jadi format digital? Rasana pernah deh ane dolo, ngrekam dari kaset ke format digital (apa gitu lupak..) di hp Nokia 5510 dulu..
Things You'll Need
Tape with audio you wish to transfer
Tape player with a headphone jack
Stereo audio cable with a male 1/8-inch connector on each end
Computer with a microphone input
Audio recording software
Instructions
1
Download audio recording software if you do not have any. Audacity is a free audio recording program, and it allows you to export audio in MP3 format with another free download.
2
Connect your tape player to your computer. Plug the stereo audio cable into the headphone jack on the tape player and the other end into the microphone input on the computer. The microphone input may be on the front of your computer, or more likely on the back.
3
Insert the tape you want to transfer into the tape player and hit "Play." Check to see if you are getting a signal to the computer. If not, open the audio settings for your computer (found in the Control Panel on Windows or System Preferences on Macs) and make sure that the microphone line is activated and turned up.
4
Open the audio recording software on your computer and check the level of your tape playing. In Audacity, this can be done by clicking the input level meter in the upper-right corner. Be sure that the signal is not too soft because your recording will be very quiet, and you will have to turn your speakers up a lot for it to be audible. Also make sure it is not too loud, or it will distort.
5
Record your audio. Stop the tape if it is playing, press "Record" on the audio recording software and then start playing the tape. You will have to do this in real time, but most audio recording will let you edit unused parts of a file, so you do not necessarily have to stop it exactly on time.
Read more: How to Convert Audio Tape to MP3 | eHow.com http://www.ehow.com/how_2044867_convert ... z1j8zdtbw0
atau coba tengok disini om:
http://www.top-windows-tutorials.com/tape-to-mp3.html
klo cara nya seh ane ngerti oom, tapi masalah nya ga punya tape euy :ungg:
tadi nya saya kira oom VM bisa dan punya tape nya, soale saya ada se-dus itu kaset2 jadul peninggalan nyokap.........mo dibuang sayang tapi disimpen malah makan tempat, mo dibikin versi digital nya ga punya tape kaset :ungg:
doq wrote:klo cara nya seh ane ngerti oom, tapi masalah nya ga punya tape euy :ungg:
Sini, ta rawatnyaa... :cupss:
sayang nya sabtu entar pak VM ga bisa dateng sih ya?
yaudahlah......................................... :ngacir:
doq wrote:sayang nya sabtu entar pak VM ga bisa dateng sih ya?
HARRRRRRRRRRHHHAARRRHHH....
