di cocktail aja pake masing2 sebotol .... siapa tau jd resingdoko86 wrote: Mon Feb 15, 2021 1:54 Bentar lagi kuda ane, 1KR-DE mau ganti oli.... Kira2 mau pake yg mana dl ini y.....![]()
Ranking Dan Pemilihan Oli Mesin - PART 13
Re: Ranking Dan Pemilihan Oli Mesin - PART 13
doko86
- Daily Vehicle: 1KR-DE_Ayla-2014
benzz89
Shaken not stirred please... [emoji16]
Semenjak pecah kongsi
Uda jarang mbah, kira2 ad kl lebi dr stengah taon
Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
TBN akhir = 6,4 mg KOH
kekentalan V100 = 10,6 cSt (masih di zona SAE 30)
Jarak = 7500 km
Durasi = 3 bulan
sidarta94
- Daily Vehicle: Crv RE
Ini ptt yg performa syntec plus (botol hitam) atau yg syntetic plus (botol emas) soalnya yg di gambar kok yg syntetic plus ya?Turboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
Sonzz
- Daily Vehicle: Veloz 3SZ-VE Brio L12
Permisi suhu2, maaf kalau salah kamar.
Oli gardan merk Mobil Lube API GL-5 SAE 80w-90 bagus ga ya?
Dan oli matic Shell Spirax Dexron 3 bagus ga?
Dibanding ATF dan Oli gardan Toyot*
Mohon pencerahan nya suhu
maastricht889
Buat mobil apa om kl boleh tau? Dan budget per liternya berapa masing2?Sonzz wrote: Tue Feb 16, 2021 8:45 Permisi suhu2, maaf kalau salah kamar.
Mohon pencerahan nya suhu![]()
farraaaassss
- Daily Vehicle: Toyota Kijang Innova
ini PTT yg botol abu apa botol emas om?Turboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
saya baru tuang 5lt yg botol abu pagi td..
penikmat triple elips warna hitam
fajarrian
abu abu kayanya,yang botol emas masih api snfarraaaassss wrote: Tue Feb 16, 2021 8:49ini PTT yg botol abu apa botol emas om?Turboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
rendr
emmmmmmm additivenya diumpetin om wkwkwkkwTurboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
canggih jg jalan 7,5k km masih segitu TBN nya yaaa.....
gaspol resing tim
ini yg 300rb an 4 liter itu kan?Turboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
Sonzz
Buat Avanza Veloz 1.5 matic tahun 2014 omerwinign wrote: Tue Feb 16, 2021 8:48Buat mobil apa om kl boleh tau? Dan budget per liternya berapa masing2?Sonzz wrote: Tue Feb 16, 2021 8:45 Permisi suhu2, maaf kalau salah kamar.
maastricht889
Shell spirax S3 saya pernah pake di yaris bakpao om, dan br tau akhir2 kl salah spek (yaris ATF WS, nih atf complynya ke ATF T-4). Tp kl buat avansa sih bisa scr spek krn udh dex 3. Jujur selain salah spek di yaris sy wkt itu juga nih oli so so aja. Sy wkt itu nekat nggak ganti yg di karter pas di 20rb km, trs jalan sktr 25rb km udah mulai merah pudar di dipstick. Selain itu juga pas 20rb an km itu oper2 gigi dah gak enak banget, kl medan jalannya stop and go atau turunan lepas gas terus injek gas lagi pun gearbox jd bingungan (mikir dulu) terus malah gak enak jd masuk gigi 1 agak nyentak.Sonzz wrote: Tue Feb 16, 2021 12:12Buat Avanza Veloz 1.5 matic tahun 2014 omerwinign wrote: Tue Feb 16, 2021 8:48Buat mobil apa om kl boleh tau? Dan budget per liternya berapa masing2?Sonzz wrote: Tue Feb 16, 2021 8:45 Permisi suhu2, maaf kalau salah kamar.
Kl ATF di avansa velos vvti biasa sih saya rekomen ttp PTT automat 1A aja om kl budget masuk, saya pake di mazda 2 lama. Dr yg saya rasain saya sangat rekomen ke matic avansa sebelum dual vvti ini krn karakteristik ATF 1A ini jadi responsif tp malah minim hentakan di mazda 2 saya. Kl pake ATF aslinya di mazda2 seringkali tiap mo oper gigi yg upshift ada nahannya dulu, begitu kuras ke 1A gejala itu ilang. Saya tau oper2annya matic avansa vvti biasa cukup nyentak apalagi dr gigi 1 ke 2, jadi dr experience saya setidaknya kl pake ptt 1A bs ngurangin gejala nyentak itu. Kl mau budget mirip spirax ya aisin AFW+ walaupun saya belum pernah coba, setidaknya dr harga yg mirip spirax sama experience disini saya bs rekomen AFW+.
Oli gardan hmmm saya belum pernah pake mobil lube di avansa 1.3 lama saya. Sy di avansa sama innova lama pake oli gardan wuling botol abu2 75W90 GL5 oke sih, gelindingnya lebih enak setidaknya. Di avansa udah pake 2x dan puas sama nih oli gardan wuling.
rendr
izin sumbang saran...Sonzz wrote: Tue Feb 16, 2021 12:12Buat Avanza Veloz 1.5 matic tahun 2014 omerwinign wrote: Tue Feb 16, 2021 8:48Buat mobil apa om kl boleh tau? Dan budget per liternya berapa masing2?Sonzz wrote: Tue Feb 16, 2021 8:45 Permisi suhu2, maaf kalau salah kamar.
sedikit mengulang ramuan subes2 diatas buat papanja..
ATF bisa pake PTT 1A/Aisin AFW+ sesuaiin budget aja, PTT 1A lebih enteng dari Aisin AFW+
oli gardan pake Eneos 75w90 GL-5 aja paling sip price over performancenya...
gaspol resing tim
Eneos 75-90 ud ga ad omrendr wrote: Tue Feb 16, 2021 13:25izin sumbang saran...
Adanya skrg 80-90
- Daily Vehicle: [cencored]
Eneos atau Idemitsu 80W-90 aja.
Kalau ga ya pake Shell 80W90 jg murmer.
rendr
eiyaaaa om klep?? yg di tokped berarti sisaan stok aja dong yak....DOHC wrote: Tue Feb 16, 2021 15:28Eneos 75-90 ud ga ad omrendr wrote: Tue Feb 16, 2021 13:25izin sumbang saran...
Adanya skrg 80-90
gaspol resing tim
farraaaassss
idemitsu ini API GL-4 atau GL-5 ya?sintoni wrote: Tue Feb 16, 2021 23:54 Eneos atau Idemitsu 80W-90 aja.
Itu semua yang ane sebutin GL5 80W-90 om.farraaaassss wrote: Wed Feb 17, 2021 2:38idemitsu ini API GL-4 atau GL-5 ya?sintoni wrote: Tue Feb 16, 2021 23:54 Eneos atau Idemitsu 80W-90 aja.
aldittodi
- Daily Vehicle: Honda Jazz GE8
Jarak = 7500 km
Durasi = 3 bulan
Penasaran juga sama ini oli pas kemarin lihat di TODA. Harganya juga cukup terjangkau
MemberBaru2020
Om, oli ini kalo dipush sampe 10k masih oke ga ya?Turboman wrote: Tue Feb 16, 2021 4:03 Hasil Test lab UOA PTT 5W30 API SP Evotec Syntec Plus
Jarak = 7500 km
Durasi = 3 bulan
aldittodi wrote: Wed Feb 17, 2021 2:49
Penasaran juga sama ini oli pas kemarin lihat di TODA. Harganya juga cukup terjangkau. Itu selama dipakai rentang 7500km apakah ada degradasi jauh di performanya? Lagi mau nyoba nyari yang murmer dikit buat mobil satunya.
Bukan om Turbo, tapi harusnya bisa sampe 10K.
woopers
- Daily Vehicle: ge8
permisi om, nubi mau bertanya..
apakah ada yang pernah pakai oli eneos sustina 5w30 sebelumnya? dalemnya bukan eneos eco 5w30 kan ya?
ni baru banget nyoba sustina 5w30 (ditambah liqui moly ceratec) di jazz ge8..
kalo perbandingan dengan ptt performa synthetic 5w30 gimana ya olinya?
