Koleksi hand tools [Part 10]
Profith83
Re: Koleksi hand tools [Part 10]
Post by Profith83 »
y_anjasrana wrote: Mon Apr 04, 2022 6:13 lg nyari rachet wrench set yg socket2nya disimpan dlm gagang rachetnya. dulu pernah beli di ace merk krisbow. tp sekarang udah ga keluar lagi. nyari2 di toko ijo ga nemu2. ada yg tau bisa beli dimana ga ya?
Maksudnya kunci shock yang mata shock nya disimpan di gagang racthet? ..... hmmm
Post by y_anjasrana »
Profith83 wrote: Mon Apr 04, 2022 6:19
yupp bener bgitu. jadi ringkas, bisa masuk tas alat. ga perlu bawa kotak segala.
marmut wrote: Mon Apr 04, 2022 3:35
Omnibus wrote: Sun Apr 03, 2022 22:37
mata tiihhh ..... :big_grin:
... :ngacir:
asli apa endak? ndak tau karena hanya hadiah... :big_grin:
yang penting punya, daripada butuh tapi ndak punya.... malah atyt gygy.
edan!
:big_exellent:
yanuarra
Post by yanuarra »
Biar kayak mbah marmut 69 :big_cat:
yanuarra wrote: Mon Apr 04, 2022 9:11 Biar kayak mbah marmut 69 :big_cat:
:frm_salut: :frm_salut: :frm_salut:
blloewy
Post by blloewy »
marmut wrote: Mon Apr 04, 2022 5:04
blloewy wrote: Mon Apr 04, 2022 4:39 ini khsusus dari yermany untuk ngambil cerutu itu yg kemaren ya mbah? :big_peace:
blloewy
Post by blloewy »
blloewy wrote: Mon Apr 04, 2022 10:04
:big_weee:
blloewy
Post by blloewy »
marmut wrote: Mon Apr 04, 2022 14:29
:big_weee:
:frm_tumbright: :frm_tumbleft: :frm_tumbright: :frm_tumbleft:
blloewy wrote: Mon Apr 04, 2022 14:33
sudah dapet insert head-nya mbah? pajang disini donk....
:big_weee:
diguling2 segala ...
blloewy
Post by blloewy »
marmut wrote: Mon Apr 04, 2022 14:39
Lum mbah...
Nunggu aja dulu sabar sikit.... :big_grin:
y_anjasrana wrote: Mon Apr 04, 2022 6:54
maksut nya kaya gini mbah yun ??
https://www.tokopedia.com/sataperkakas/ ... sata-tools
Taufiq6210
Post by Taufiq6210 »
Ngeramein dikit mbah...
Enak buat buka sekrup keras seperti bracket home button ini:
Puteran bagian atasnya enak, halus muternya. Gripnya pas ukuran dan posisinya. Tapi magnetnya ga kerasa (atau ga ada malah)...
Taufiq6210 wrote: Tue Apr 05, 2022 16:32 Ngeramein dikit mbah...
obeng hp mbah?
set di 4nm :
klik.
selesai sudah memasang aki baru.
marmut wrote: Wed Apr 06, 2022 5:09 set di 4nm :
klik.
kunci torsi sultan untuk sepeda sultan karena melebihi Park Tool... :big_biglaugh:
klik.
kabel min udah kepasang baru ngetork kabel plus begitu kl tw nyenggol body siap2 kembang api :big_weee: :big_grin:
Omnibus wrote: Wed Apr 06, 2022 6:47
tak mungkin mbah... :mky_03:
itu jauh dari ground. ujung belakang manoskop ada plastik item pengaman, kiri kanan depan manoskop aman dari ground.
ma'lum, ayla kan mesin V6 diskon 50% jadi enjin bay legaaa nda kaya gk5.
:big_grin: :big_grin: :big_grin:
yanuarra
Post by yanuarra »
Soeltan :big_exellent:
blloewy
Post by blloewy »
klik.
Ngeri bill nya ini mah :big_grin:
Profith83
Post by Profith83 »
Sekedar tampung info yang terpikir beli insert head toptul.
Cari cari spec nya dulu susah sekali.
Coba email ke pusat dan ini balasannya
Thank you for your e-mail.
Kindly note ANAL0116 is applied for TOPTUL #ANAH0108、ANAH0121、ANAJ0130.
You may find the torque handle's capacity from the above links.
I hope this information will be helpful for you.
Taufiq6210
marmut wrote: Wed Apr 06, 2022 5:07 obeng hp mbah?
Iya mbah
Profith83 wrote: Wed Apr 06, 2022 8:48 You may find the torque handle's capacity from the above links.
Link yang dimaksud itu link apa mbah?
Profith83
Post by Profith83 »
Taufiq6210 wrote: Wed Apr 06, 2022 9:18
ANAH0108
https://www.toptul.com/en/product-32569 ... andle.html
ANAH0121
ANAJ0130
https://www.toptul.com/en/product-32569 ... splay.html
Tapi rada aneh info dibawah ini
Range lebar 40-300Nm.
1. TW 40-210 Nm
ANAH0121 40-210Nm disuruh dia pakai ANAL0116 yang bisa 60-310 Nm. Bisa lihat di
https://www.toptul.com/en/product-52034 ... h-Set.html
2. TW 60-300 Nm
ANAJ0130 60-300Nm disuruh pakai yang sama di email yaitu ANAL0116 yang bisa 60-310Nm.
Range pendek 10-80Nm
Sedangkan yang ANAH0108 10-80Nm disuruh pakai ANAL0216
https://www.toptul.com/en/product-32569 ... h-Set.html
blloewy
Post by blloewy »
Profith83 wrote: Wed Apr 06, 2022 11:35
ANAH0108
ANAH0121
ANAJ0130
1. TW 40-210 Nm
2. TW 60-300 Nm
Cuma dijawab begini ama TOPTUL mbah :big_grin:
Jadi based on TW nya mana yg bisa make itu insert head.
Tp 0116 sama 0216 ukuran sama itu insert head tp beda peruntukan TW.
