ha pantesan kok dadi shirrr repairing plisurrr ternyata setelan cooling e koplak ngene...b8099ok wrote: Sun Aug 16, 2020 2:09
Jepangan rata" khan dibawah 88 degree Celcius utk coolant tempnya. Sedangkan european pasti diatas 90 degree Celcius. Yg menurut gw ga ada gunanya diatas itu. Engine block do expand, but at 70-75 degree Celcius it will be more than enough. Beyond that point is useless, cenderung merusak. Maybe next gen car which will be fitted with fully electronic thermostat and ECU controlled can be altered to lower the temp to its "normal Asian" operating temperature. FYI, nissin biskuit pake thermo 87 degree C. Dengan kapasitas oli yang hanya 3ltr saja, mobil itu berhak mendapatkan predikat mesin terbodoh sepanjang jaman (Sludge King). Kemudian mpord kondom, thermo 105 degree C utk gen awal . Die madafaka,...
uwis cuaca panas kyk neraka bocor, mesin panas, girbok dualclutch panas. enjin bay rasa penggorengan...
awas mengko onok penboi nissin biskuit denial
nahh ini berasa bgt tiap pagi cold start L15B itu ane ud keluar komplek sekitar 500 meter baru naik itu temp... yg lain paling keluar gang 200 meter aja uda naik dikit...Omnibus wrote: Sun Aug 16, 2020 3:01 tp kl engine yg emang naturally cold in nature, spt buktinya L15B turbo ahond dulu sblm countermeasure remap di negara berwinter jd ada fuel dilution problem krn stage warming up (rich) kelamaan, engine nya ga cepet panas. n yg jelas keburu menggigil kedinginan penumpangnya heater kaga panas2 wkwkwk.
