Nightster Guy wrote:Cakep. Gagah. Walau jd bingung ama silsilah/timeline dr nameplate 'TERRANO' itu sendiri.
- Terrano gen 1 (85-95): seperti yg beredar di Indo, aka Pathfinder di luar sana.
- Terrano gen 2 (96-04): ngga masuk Indo, aka Pathfinder di luar.
- Masuk 2005, cerai/splitted out? Pathfinder ya Pathfinder (based on Navara truck), Terrano ya ceased out alias hiatus.
- Masuk 2013, Pathfinder ya tetep Pathfinder, kek gini:
(Platform sharing ama Murano, Altima dll)
Lah Terrano baru ini gimana ceritanya kok moro2 basis dr Duster?
Berarti memang udah gak da lg ya benang merah Pathfinder vs terrano? Maklum pecinta sejarah otomotif, jadinya selalu mengutak atik silsilah sebuah tipe mobil heeehehe..
Cmiiw..
Masih ada benang merahnya kok Om dgn Pathfinder. Kalo dulu beda nameplate aja, sekarang Terrano jadi Pahe (Pake Hemat)nya buat yg kagak mampu beli Pathfinder hehehe
1.5-litre K9K diesel is offered with two output options – 85PS/200Nm or 110PS/248Nm. We got to drive the top end 110PS XV variant. This engine displaces 1461cc and uses a variable geometry turbo to provide a very meaty power delivery. Peak power is developed at 3900rpm while torque peaks at 248Nm at 2250rpm.
the engines displays some lag upto about 1300rpm after which you get a strong surge of power all the way upto 4000rpm after which it starts to taper. Shifting at 3000rpm proves more than enough for brisk driving though. In gear drivability is strong and overtakes in 6th gear are possible at highway speeds.
0-100kmph time of 12.7 seconds. The top speed lies at a true 172kmph. Likewise the fuel efficiency figures tally as well and we got an impressive highway figure 21.6kmpl
max torque 2250rpm
max power 3900rpm
main 2000-4000 .. sptnya bakal nendang terus, seru juga nih mesin cc 1500 lumayan performanya.
Mesinnya kecil tapi tenaganya lumayan besar, sepertinya harus diberikan pasokan solar yang mumpuni yah..
pake VGT soalnya boss, tp blm tentu pas masuk indo spec. nya sama
mgkn pilihan mesin jg beda..
dieselkiki wrote:bisa jadi masuk sini lebih mahal dari juke bisa lewat dari ruster
klo lebih mahal dari juki ga akan laku .. krn interiornya dan teknologi biasa aja masih lebih bagus juki.
Juki aja susah laku dan skrg discount gede, .. temen blum lama ambil dpt disc 25jt.
Ini nissan Terano dijual di INDIA mulai dari 164jt
susah deh kalo buat masuk bareng sama Renault Duster .. ada perang kepentingan didalamnya, kalo smp masukpun bakal 1-2thn lagi .. nunggu penjualan Duster downslope dan Juki udah mulai uzur
mgkn pilihan mesin jg beda..[/quote]
Beritanya si Renault Duster masuk dg variant mesin yg sama, kalo Terano smp masukpun ga akan pakai yg beda mesin, apalagi Terano ini dianggap versi premiumnya Duster.
Nissan
SUV All-New Xtrail prediksinya akan rilis di Indonesia menemani "saudaranya" Renault Duster, menariknya ada pilihan tambah kursi baris ketiga, muat 7 penumpang. MPV Evalia cukup lama tidak "dijamah", dugaan yang beredar akan mendapat revisi dengan ubahan jok captain seat di baris kedua, seperti di India.
Nissan
Nissan
Sesuai perkiraan saya dari awal dimana Nissan baru akan all out mulai 2017 dimana mereka akan mengeluarkan banyak produk baru seperti Nissan Terrano ini. Semoga aja AC di row 2 gak seperti di India yang bentuk nya aneh. Juga ideal nya harus udah ada varian AT nya saat masuk Indonesia nanti.
