you are right, time to goHouseOfDetailing wrote:Hansen wrote:Ngeriik mapia medan
I must go...
is no longer conducive...
getting wet here...errrrrr...........i mean getting hot.....................~~~~
I must go...
I must follow the wetness... errr... hotness too...papa3r wrote:you are right, time to goHouseOfDetailing wrote:Hansen wrote:Ngeriik mapia medan
I must go...
wah ternyata ada yg sama jugaartoodetoo wrote:Memang hot naik mobilio. AC nya kurang dingin.
*eh
Yg ane dingin2 aje lho...artoodetoo wrote:Memang hot naik mobilio. AC nya kurang dingin.
*eh
Nubie no comment mengenai kung fu dan sulap di pabrikan Monyong...papa3r wrote:Yg ane dingin2 aje lho...artoodetoo wrote:Memang hot naik mobilio. AC nya kurang dingin.
*eh
Emang sich tempo hari ane chek discharge preassure AC dari awal emang kurang...ane tambahin sndiri tuch freon...ane set pas panas terik masih di bawah press max operatingnye biar aman.....sekarang nyusss....
soal idle pas compressor ac on di lio ane anteng aje, tak bergeming di rpm +- 800 tanpa bounching sama sekali...
yg bikin risih di kuping ane malah pas Compressor Clutch engaged / on...ccthakk!!!...kaya kaca di lempar kerikil sekepel....wkwkwkkk
jangan2 dari fabrikan tekanan kerja AC emang sengaja di kurangi untuk naikin FC......![]()
Om...emang dedy C ikut ngrakit monyong...?madcat015 wrote:Nubie no comment mengenai kung fu dan sulap di pabrikan Monyong...papa3r wrote:Yg ane dingin2 aje lho...artoodetoo wrote:Memang hot naik mobilio. AC nya kurang dingin.
*eh
menyedihkan... even monyong aja ada....merkapa wrote: yg menarik emang dr mobil ini adalah one touch untuk melipat kursi belakang untyuk masuk baris ketiga
ChZ wrote:menyedihkan... even monyong aja ada....merkapa wrote: yg menarik emang dr mobil ini adalah one touch untuk melipat kursi belakang untyuk masuk baris ketiga![]()
sementara saudaranya yang bisa dapet 4 biji monyong ga bisa.....
lepas joknye......ke beres pesen jok monyong.....pasang...nambah tuch fitur lipat 1 touch.....ChZ wrote:menyedihkan... even monyong aja ada....merkapa wrote: yg menarik emang dr mobil ini adalah one touch untuk melipat kursi belakang untyuk masuk baris ketiga![]()
Wekekekeke...papa3r wrote:lepas joknye......ke beres pesen jok monyong.....pasang...nambah tuch fitur lipat 1 touch.....ChZ wrote:menyedihkan... even monyong aja ada....merkapa wrote: yg menarik emang dr mobil ini adalah one touch untuk melipat kursi belakang untyuk masuk baris ketiga![]()
Ngga pernah punya njes pitek dan monyong cuma test drive sekali di ahond pondok indahBodem wrote:Kalau ada yang pernah pakai jess-pitak-cvt atau inyong... apakah mengalami hal yang sama? ataukah ini hanya perasaan sy aja?
Monyong RS ada paddlepop nya kan?madcat015 wrote:Update...
Monyong RS akan delivery bulan July ini. Sudah ada kabar dari MD ttg hal ini...
Harga belum tahu...
jason28 wrote:Monyong RS ada paddlepop nya kan?madcat015 wrote:Update...
Harga belum tahu...![]()
