Ranking Dan Pemilihan Oli Mesin - PART 02
Abu2
Daily Vehicle: just a bike
Re: Ranking Dan Pemilihan Oli Mesin - Part 02
Post by Abu2 »
sementara blm ada update ttg pertanyaan ane di atas, ane tanya lagi ya, dgn quote dari lapaknya datsu
Turboman wrote:
datsu wrote: @buatandi: bedanya antara GL-4 sama GL-5 apa sii oom? setau gw mobil2 standar GL-5 kaya mobil gw (di buku harus 75w-90) kalo dikasih GL-4 umur olinya lebih pendek yaa?
Beda kandungan EP additive-nya
Utk gardan mutlak pakai GL-5
Utk transmisi manual idealnya GL-4 walau ada bbrp trans yg mengijinkan penggunaan GL-5
om turbo, ane pake spek Motul hdx technosynthese SAE 80-90 GL5 mil.l2105D untuk gardan dan transmisi manual (suzuki GV 2007).
dulu awalnya pake SGO (oli bawaan beres), setelah ganti Motul ini, jauh lebih enak , dan masuknya ces pleng..
tapi kira2 aman gak ya Om? karena di buku manual spek untuk transmisi pake oli GL4 SAE 75-90
Abu2
Post by Abu2 »
sundul :roll:
imsus2c
Post by imsus2c »
Abu2 wrote:sementara blm ada update ttg pertanyaan ane di atas, ane tanya lagi ya, dgn quote dari lapaknya datsu
Dari API (American Petroleum Institute), silakan diterjemahkan sendiri ya.... :upss:
What does API GL mean?
API stands for American Petroleum Industry and GL stands for Gear Lubricant, see below for
their definitions:
API GL-1 Straight mineral oil
API GL-2 Mild EP for worm gears
API GL-3 Mild EP for spur and spiral bevel gears in axles and transmissions
API GL-4 Medium EP, MIL-L-2105 quality, moderate severity hypoid gears, manual transmissions
API GL-5 High EP, MIL-L-2105D quality, all hypoid axles, some manual transmissions
API GL-6 Extra high EP, now obsolete
Beberapa FAQ tentang gear oil, terjemahkan sendiri lagi.... :ungg:
Is it important to select the right API GL rating?
Yes. Selecting the correct gear oil performance level will provide the best protection to the components of the transmission.
What do the SAE grades mean?
SAE stands for the Society of Automotive Engineers. The SAE classification system is a way of
defining how thin or how thick an oil is. This is known as an oil’s viscosity. The classifications
are listed here in order of increasing thickness: SAE 75W, SAE 80W, SAE 85W, SAE 90, SAE
140, SAE 250.
What does EP mean?
EP means extreme pressure and refers to the additive used in gear oils. This additive is
designed to stop metal-to-metal contact taking place between transmission components. The
EP additives are usually based on sulphur and phosphorous. These elements bond to the
metal surfaces where there are points of extreme pressure and temperature, forming a
sacrificial chemical layer. The sulphur gives gear oils their characteristic smell.
Will synthetic gear oils and mineral gear oils mix together?
Yes, but beware that there two kinds of synthetic gear available: polyalphaolefin (PAO) based
and polyalkylene glycol (PAG) based. PAOs are basically a man made version of mineral oils
(although with greatly improved properties) and can therefore be mixed with mineral oils. In
fact, semi-synthetic products have mineral and synthetic base fluids in them, so obviously,
they must be able to mix. PAGs, on the other hand, will not mix with PAOs or mineral oil.
Utmost care must be taken when using this kind of product.
What is a hypoid axle?
Hypoid is an abbreviation for hypocycloidal and relates to the geometry of the crown wheel
and pinion arrangement usually on rear wheel drive cars. The pinion is usually highly offset to
reduce propshaft intrusion into the passenger compartment.
Do I need a special oil for limited slip differentials?
Yes. When the power distribution between two drive shafts is no longer equal (usually due to
the surface condition that the drive wheels are turning on, i.e. ice, mud), limited slip
differentials are able to effectively lock the two half shafts, ensuring equal power distribution
once again. When this limited slip differential mechanism ‘kicks in’ there is a high shock
loading on the clutch mechanism that requires protection from wear and slippage. Use of the
incorrect oil can lead to clutch degradation and vibration.
Why should I choose non-EP straight oils for my classic car?
Depending on the age, make and model non-EP gear oils may be required for use in
gearboxes and final drives. Certain designs contained a lot of phosphor-bronze (copper
containing) components that are sensitive particularly to the sulphur extreme pressure (EP)
additive. The sulphur attacks the copper and destroys the integrity of the meshing gear
surfaces.
Is it alright to use ATF in a manual gearbox?
Certain designs do specify the use of an ATF in manual gearboxes, but they should only be
used where it is clearly stated by the manufacturer.
Is there one gear oil that will meet all my requirements?
This will depend on makes and models, but very often the answer is no. Gearboxes, final
drives, transfer boxes, etc., all have their own specific lubrication requirements. The
specification of the oil required will be outlined by the design engineers, who will determine
which type of oil will provide the maximum protection to the transmission components. It may
certainly be possible to rationalise and reduce the number of lubricants used, but the magical
single product may not be achievable.
What is the difference between a gear oil, an atf and an mtf and why are they
sometimes interchangeable?
There is a fair amount of common ground, all do a basically similar job, an ATF could be
regarded as a low viscosity gear oil with more precisely controlled frictional properties.
What is an MTF and why is it used instead of a gear oil?
MTF ( manual transmission fluid ) is a term preferred by some OEMs, perhaps they think it's
more descriptive than "gear oil". It doesn't call up any particular performance or viscosity. For
example a Volvo MTF will not be the same as a Honda MTF.
How do gear oil, atf and mtf viscosities relate to engine oil viscosities?
Gear oils and engine oils are classified by 2 different viscosity grading systems. A 75W-90
gear oil, for example, is about the same viscosity as a 10W-40 engine oil. In theory ATFs and
MTFs can be any viscosity as required by the OEM. In practice ATFs are approx. the same
viscosity as a SAE 10 engine oil or a ISO 32 hydraulic oil. MTFs are about the same, possibly
slightly thicker.
What is a 75w gear oil as this is only a cold crank rating isn’t it?
The target here is 4.1 cSt minimum @ 100 deg. C + the low temp target. If the gear oil in
question is, for example, a 75W-80 it must meet both specs which is effectively the 75W low
temp + the high temp targets of both specs.; 4.1 cSt minimum for the SAE 75W and 7.0 -
11.0 cSt for the SAE 80. You can see that the SAE 80 target " overlays" the SAE 75W target so
expect the KV 100 of a 75W-80 to be about 9 cSt.
Can one gear oil cover a number of viscosities like 75w-90, 80w-90 and 90 and why?
Yes it can, the viscosity grades are not mutually exclusive, it is possible to blend a gear oil
with multigrade characteristics such that it falls within, for example, the SAE 75W and the SAE
90 viscosity bands. A mulitgrade oil ( gear or otherwise ) is simply an oil which falls into more
than one viscosity grade.
Why do some synthetic gear oils cause poor shifting in older or high mileage boxes?
If this really happens it can be that the generally lower viscosity of a synthetic gear oil may
not suit an older or worn box.
Can engine oils be used in gearboxes if they are the right viscosity and are there
advantages to using them?
Engine oils can be used in certain gearboxes, in the past it was the norm to do just that.
Modern engine oils can be expected to attain the baseline API GL4 performance required for
gear protection. Viscosity is not likely to be an issue, the viscosity of a 10W-40 engine oil, for
instance, approximates to a 75W-90 in gear oil terms. The gear oil viscosity grade system
uses bigger numbers than the engine oil system but that doesn't mean the oils are thicker.
The advantages? The detergency and antiwear systems in engine oils may cope with excessive
"competition" temperatures better. Engine oils are intended for a shorter service life than
gear oils so one point to be aware of is the viscosity modifiers used in multigrade engine oils
may not be as shear stable as true gear oil VM’s so a bigger viscosity drop in service is
possible. If you are considering this, use a top quality shear stable engine oil, or talk to us
first.
Are filled for life gear oils a gimmick and are they in the long term bad for your
gearbox?
I wouldn't say they are a gimmick but they do assume "normal" service conditions. Having a
modified engine putting more power through the box & competition conditions don't lend
themselves to gentle gear changes so you may see higher wear rates and more wear debris in
circulation. It's logical to change the oil periodically if only to flush out the wear debris.
Of course the discerning owner may wish to change the oil occcasionally even if the service
conditions are considered to be less severe.
This may raise more questions than it answers but hopefully it is of use to some of you.
Regards
Guy
imsus2c
Post by imsus2c »
tambahan dikit tentang gear lubricant (GL)
LUBRICANT SERVICE CLASSIFICATIONS AND SPECIFICATIONS
API SERVICE CLASSIFICATIONS (ENGINE CRANKCASE OILS)
The American Petroleum Institute (API) Engine Service Classification was developed as a result of a co-operative effort in the USA
between the API, the American Society for Testing and Materials (ASTM) and the Society of Automotive Engineers (SAE). The tripartite
was developed to form a means of communication between the engine manufacturers and lubricants suppliers.
The system defines classes of service for both petrol and diesel engine applications as well as stipulating the accepted engine
laboratory tests.
API Automotive Gear Lubricant Specifications
The most important internationally accepted system defining automotive gear oil performance characteristics is laid down by the
American petroleum institute (API).
API GL-1
Designates the type of service characteristics of automotive spiral-bevel and worm gear axles and some manually operated
transmissions operating under such mild conditions of low unit pressures and sliding velocities that a non-additive mineral oil can be
used satisfactorily. Oxidation and rust inhibitors, anti-foam additives and pour point depressants may be utilized to improve the
characteristics of lubricant for this service. Does not contain friction modifiers and extreme-pressure agents.
API GL-2
Designates the type of service characteristics of automotive-type worm gear axles operating under such conditions of load,
temperature and sliding velocities that lubricants satisfying API GL-1 service will not suffice. Products suited for this type of service
contain anti-wear or very mild extreme-pressure agents that provide protection for worm gears.
API GL-3
Designates the type of service characteristics of manual transmissions and spiral-bevel axles operating under moderately sever
conditions of speed and load. These service conditions require a lubricant having load carrying capacity greater than that which will
satisfy API GL-1 service, but below the requirements of lubricants satisfying API GL-4 service. Lubricants designated for this service
typically contain additives that are active at the tooth surface at the temperatures resulting from high-speed or load.
API GL-4
Designates the type of service characteristics of gears in manual transmissions operating under sever conditions of sliding speed,
particularly spiral bevel and hypoid gears in moderate service, in passenger cars and other automotive-type equipment operated under
high speed/low torque and low speed/high torque conditions.
API GL-5
Designates the type of service characteristics of gears particularly hypoid, in passenger cars and other automotive equipment operated
under high-speed/shock load, high-speed/low-torque, and low-speed/high-torque conditions. Equivalent to MIL-L-2105D, this category
is mainly applicable to axles but may also be used for certain manual transmissions.
API GL-6 (Obsolete)
They type of service designated by API GL-6 is characteristic of gears, specifically high offset hypoid gears in passenger cars and
other automotive equipment operated under high-speed high-performance conditions. This classification is obsolete. The equipment
required for the test procedure to verify lubricant performance is no longer available.
API MT-1
This category defines a gear lubricant for heavy-duty manual transmissions that has thermal stability, high temperature cyclic durability
and copper compatibility level exceeding API GL-1 through GL-5. Gear lubricants in this category typically meet the service
requirements of non-synchronized manual transmissions in heavy-duty trucks and in buses.
Abu2
Post by Abu2 »
kamsia, sie sie, makasih, tengkyu, mercy, thanks....
muuuuahhhh :cupss: , makasih banyak meneerr :frm_tumbright: :frm_tumbright:
semoga english ane yg sotoy ini gak salah mengartikan...
gak salah dan gakk masalah spek oli transmisi GL4, diisi GL5
dan gpp juga spek oli transmisi 75w-90 diganti dgn 80w-90..
imsus2c
Post by imsus2c »
Abu2 wrote:kamsia, sie sie, makasih, tengkyu, mercy, thanks....
meneer abu2 : dank u well, broer...
meneer imsus2c : graag gedaan, meneer...
.... :ngacir:
Abu2
Post by Abu2 »
tadi ngeliat lagi oli MOTUL H-tech100 plus 5w-30 API SM/CF ILSAC GF-4, 100%synthetic
harganya 120rb/liter
sembari nyari di gugel, ane lempar disini jg pertanyaaannya..
ILSAC GF-4 itu apa ya?
di oli2 lain (mobil, repsol, shell) gak ngeliat ada tulisian ILSAC GF-4...
m4rio
Post by m4rio »
masalah ini pernah dibahas di link berikut ini broo...
http://www.serayamotor.com/diskusi/view ... =4&t=12498
nanti setelah masukke threadnya di situ ada 2 link dari broo herbid, nah klik link yang ke dua. setelah itu broo baru ngarti dah apa ILSAC itu.
moga2 ane gk salah.. ane cuman nerusin informasi aja. jangan dimarahin ya bro semua.... :big_peace:
Abu2
Post by Abu2 »
thanks mario..... :cupss:
spartanwarrior
Post by spartanwarrior »
bro kalo untuk kijang disel 2000 caltex delo gold bagus ga ya? biasa gua ganti tu oli doang 200rb 1 galon gede..
asli ga tuh oli?
spartanwarrior wrote:bro kalo untuk kijang disel 2000 caltex delo gold bagus ga ya? biasa gua ganti tu oli doang 200rb 1 galon gede..
asli ga tuh oli?
caltex delo gold sehh ane perna pake dan lumayan koq bro... justru yg musti diliat bukan harga nya tapi keaslian nya.... soalnya oli palsu jg pasang harga bisa sama ama oli asli...
bro2 skalian, kira2 ada yg perna ngecek ga yah oli2 yg dipakai nya... koq yg ane rasain, walaupun tingkatan oli nya sama tapi scara fisik agak beda yah kekentelan nya...
misalnya tingkatan 10W-40 kategori semi syn... shell yg botol ijo tua, idemitsu ext touring, castrol magnatec, total quartz 7000, mobil super... nah smua oli tsb tingkatan nya sama, dan sama2 semi synthetic... tapi aneh nya, si castrol magnatec itu ane rasain kalo pake jari koq agak kentel yahh, diikuti shell yg kira2 mirip2 kentel nya ama si total... nahh kalo idemitsu ama mobil super S, itu ane pegang pake jari koq encer yahh... malah yg idemitsu itu agak mirip2 oli nya nissan (NGO) yg 10W-30 yg notabene emang oli "encer"....
kira2 ada yg bisa memberikan penjelasan teknis nya... :e-think: :e-think: :e-think: :e-think:
spartanwarrior
asli ga tuh oli?
caltex delo gold ini oli nya jenis apa sih? mineral atau sintetik ya? terus daya tahan max nya berapa km?
mineral bro... dan kalo utk oli diesel sehh mendingan per 5000 atau 4000 km uda bole diganti dahh... scara kondisi solar indo yg jelek... lagian oli itu bagi mesin diesel ibarat nyawa nya... kalo rajin ganti oli dijamin tuh diesel bakal awetttt.... lagian oli diesel mahh masi murah jauh ketimbang oli bensin...
spartanwarrior
waduh bro bukannya setau saya oli mineral itu kelasnya plg jelek ya? yang paling bagus itu sintetik?
bukannya begitu? terus oli sintetik diesel apa ya?
spartanwarrior wrote:waduh bro bukannya setau saya oli mineral itu kelasnya plg jelek ya? yang paling bagus itu sintetik?
waduhh... kayanya kalo dibilang jelek koq kurang pas kali yahh... FYI, ntuh oli FK massimo aja ada yg mineral logh tapi harga dan kualitasnya sama ama oli semi syn... oli motul pun jg ada tuh yg mineral tp kualitas nya jauhhh diatas oli semi syn... ini ane perna baca soalnya di buku panduan kepunyaan milis mobil nya atpm sebelah...
oli syntetik diesel mahh ada dijual bro... kalo yg semi syn ada shell helix plus tuh yg btol biru, atau castrol magnatec jg bisa... kalo yg oli full syn ada yg kluaran mobil 1 cuman harga2 nya ane ndak tau...
spartanwarrior
oo gitu ya bro jadi ga selalu mineral jelek dan sintetik itu bagus?
menutur bro DOHC oli buat mesin diesel yang paling bagus tipe apa ya?
oli diesel paling bagus mah tergantung budget bro... mau yg kelas full synthetic sperti mobil 1 atau aral jg ada.... tapi kalo yg kelas menengah ambil yg semi syn jg boleh, sperti salah satu rekan dsini yg PS nya pake shell helix diesel plus ( botol biru) itu kan jenis semi syn....
nah kalo kelas rendah (dan tentu nya utk mobil yg tidak menuntut spesifikasi oli tinggi alias diesel jadul) yah pake kelas mineral sperti meditran SX, rimula botol itam, caltex delo jg uda bagus koq...
ane pribadi sehh pake nya skrg kalo ga rimula yah meditran SX, tuh di panther kotak ane uda jalan 320 rebu km masi tetep ok blom ada tanda2 perlu turun mesin atau bocor kompresi... yg penting rutin ganti oli aja...
m4rio
Post by m4rio »
broo klo oli GULF ada pernah yang make gk????
kmrn liat GULF super diesel plus ( klo gk salah ) harganya masih di bawah 200rbu nih per 5 liter atau 4 liter gitu deh..
m4rio
Post by m4rio »
kosong amat ya nihhh forum...
otot
Post by otot »
Abu2 wrote:agak OOT dikit
untuk bbrp mobil keluaran terbaru, di dahshboard ato MID ato OBC nya ada tertera reminder untuk melakukan servis rutin.
reminder ini biasanya dgn tulisan Tune up, ato ada gambar monkey wrench..
nah pertanyaannya, ini komputer mobil, ngukur nya apakah dari operation hour mobil, dari mileage, ato mungkin ada sensor di bak Oli, yg bisa mengukur langsung kualitas oli di mesin mobil tersebut...????
mohon pakar2 disini bisa mencerahkan diriku yg nubie ini... :thanks:
kalo gak salah setelanya berdasarkan kilo meter yang kita setel di tombol reset odo saja kok, soalnya pernah coba di navara caranya tekan agak lama tombol odo nanti muncul gambar kunci pas,kemudian di putar nanti tinggal pilih mau di km berapa kita mau di ingatkan servis ( semacam pengingat saja ) :big_peace: urutanya pastinya lupa2 ingat jadi mohon maaf kalo salah :ungg: .
Abu2
Post by Abu2 »
wah..om otot pasti pengguna navaraa neh.....
berarti di navarra hanya tergantung setelan di Odo aja ya........
kirain berdasarkan jumlah jam mesin beroperasi...
otot
Post by otot »
iya om Abu2, satu lagi kalo mau setel reminder nya itu posisi kunci kontak dalam keadaan on/acc (lampu indikator nyala) kemudian baru ditekan tombol odo agak lama dan pilih berapa km yang kita mau ( biasanya saya pilih 5000km sesuai jadwal ganti oli).
Abu2
Post by Abu2 »
navarra nya di kasi minum apa om bbmnya?
otot
Post by otot »
bbm isi solar biasa saja karena di pekanbaru belum ada dex, untuk perawatan tambahin stp diesel fuel treatment setiap is full tank dan jadwal bersihin filter solar setiap 2 minggu n kuras tangki tiap 40 ribu km., oli pakai oem nissan sae 10-30 api ci-4.
