The new Honda Accord 2008
boilers
Re: The new Honda Accord 2008
Post by boilers »
Another Test run by Motor Trend America:
Link:
http://www.motortrend.com/roadtests/sed ... _data.html
Different magazine, different result: :D
Di sini posisi rankingnya :
1ST PLACE: TOYOTA CAMRY SE V-6
Finest all-around mix of power, handling, room, and bells and whistles-no wonder it was our 2007 Car of the Year.
2ND PLACE: CHEVROLET MALIBU LTZ
Great combination of sport and luxury bettered only by Camry. America's best and segment's best-looking.
3RD PLACE: HONDA ACCORD EX-L V-6
Vast room, attention to detail, and advanced technology can't overcome a few obvious faults.
4TH PLACE: NISSAN ALTIMA 3.5 SE
Winner on track and twisties comes up short for lack of polish and refinement.
Di tes ini Toyota Camry mencatat waktu akselerasi paling cepat juga, sepertinya mesin 3.5L Camry ini memang paling unggul. Sebab selain tercepat, tapi konsumsi BBM-nya juga paling hemat, cuma 20.2 mpg vs Honda Accord 18.5 mpg. (data dr tes mereka, bukan dr data mfg).
IMO sih accord dan Camry masing2 mobil bagus, you can't go wrong with either one of these. Sayang yah New Malibu dan Altima tidak masuk Indo :(
GTR
Post by GTR »
makin seru, ada tambahan hasil tes dari source lain lagi...
GTR
Post by GTR »
konsumsi bbm keduanya sama dari motortrend.
interesting; kalo dipersempit lagi accord vs camry; masih menang accord:
http://www.motortrend.com/roadtests/sed ... rdict.html
Risol1
Post by Risol1 »
uch wrote:Kalo liat2 sih agak2 kurang fair juga sih. Accord dan Nissan yg ditest yg udah lengkap feature option nya. Chevy dan Camry datang dari kasta yg standard2 aja.
"LTZ" di chevy dan "XLE" di camry itu udah kasta paling tinggi dan biasanya udah dilengkapi dengan jok kulit, sunroof, MID, dual zone climate control, dll :D
Midi_Amp
Post by Midi_Amp »
Setau gw sih mesin i-VTEC V6 Honda itu teknologi jaman jebot. Honda sedikit bingung dan cenderung membabi buta untuk pengimbuhan "intelligent" di mesin VTEC-nya. Contoh; mesin seri K itu i-VTEC, karena memperkenalkan fungsi Variable Timing Control (VTC) yang membuat pengaktifan "cam panas" merentang di setiap putaran mesin, berbeda dengan VTEC tradisional putaran rendah "cam hangat", putaran tinggi "cam panas". Oh ya hampir lupa, di seri K i-VTEC = VTEC + DOHC + VTC.
Tapi, di i-VTEC seri R terbaru (CR-V, Civic, Stream), i-VTEC = VTEC + SOHC + profil cam baru. Profil cam baru ini berbeda dengan VTEC tradisional hangat/panas, karena profil cam sekarang adalah dingin/hangat. Terdapat juga semacam mekanisme menyerupai VTC jadi pengubahan profil cam lebih cepat dibanding VTEC tradisional.
Kemudian, di i-VTEC V6... Sebenernya adalah VTEC V6 + SOHC + Variable Cylinder Management. Mesin VTEC V6 itu sendiri cuma penyempurnaan mesin dari jaman Accord generasi ke-enam, nama serinya adalah J. Tapi meskipun mesin jebot, seri J adalah salah satu bukti kehebatan tukang insinyur Honda, dengan penyempurnaan, mesin yang sama bisa diadopsi untuk menghasilkan tenaga lebih besar dari tahun ke tahun. Accord V6 EX (Amrik), mesinnya J30 (3000cc) namun menghasilkan tenaga 240hp. Dari mesin yang sama dibuatlah J32 (3200cc) yang nyempil di Acura TL menghasilkan 260hp, dan sekarang menjadi 3500 cc menghasilkan tenaga 290hp (Acura TL), semuanya tanpa mengorbankan konsumsi bensin secara signifikan.
Untuk masalah getaran... Setau gw sih Odyssey Lagreat gak punya VCM, VCM baru diperkenalkan tahun 2005 sementara Odyssey Lagreat udah gak diproduksi semenjak 2004 (Lagreat itu Odyssey versi Amrik yang dijual di Jepang). Tapi gw mungkin salah, sapa tau ada produksi spesial. VCM itu menonaktifkan beberapa silinder ketika jalan santai, otomatis mesin bergetar karena ada ketidakseimbangan daya torsi yang memutar crankshaft. Tapi, Honda menyertakan dua teknologi untuk meredam (dan mengklaim menghilangkan) getaran tersebut. Yaitu mounting mesin aktif yang dikontrol komputer dan Active Noise Control. ANC merekam suara gaduh mesin dan memutar balik suara itu secara insinkron melalui sistem audio mobil. Untuk Accord baru, VCM masuk generasi kedua, jadi gak cuma mematikan silinder 3 aja tapi juga bisa matiin hanya 2 silinder. Untuk kasus mobil pake VCM mesinnya bergetar, ada kemungkinan mounting mesin aktifnya rusak.
Tambahan lagi dikit...
VTEC = Variable Valve Timing Lift Electronic Control
VVT-i = Variable Valve Timing Intelligent
VVTL-i = Variable Valve Timing and Lift Intelligent.
Urutan keruwetan teknis (bukan yang terbaik ya...) VVT-i - VTEC - VVTL-i
Ada lagi yang lebih ruwet teknisnya, VVT-Ie, i-VTEC, i-VTEC Turbo, Bi-Vanos, VarioCam, dll, cape ngetiknya.
Untuk masalah penerbitan mana yang memenangkan mobil terbaik, terserah masing-masing penerbitan. Mereka pasti punya cara pengujian masing-masing. Yang pasti sih... Honda Accord udah memenangkan kategori family sedan of the year selama 21 tahun berturut-turut menurut majalah Car and Driver. Accord generasi ke-8 menggenapi angka tersebut menjadi 22 tahun.
Caranddriver
Risol1
Post by Risol1 »
Midi_Amp wrote:Untuk masalah getaran... Setau gw sih Odyssey Lagreat gak punya VCM, VCM baru diperkenalkan tahun 2005 sementara Odyssey Lagreat udah gak diproduksi semenjak 2004 (Lagreat itu Odyssey versi Amrik yang dijual di Jepang). Tapi gw mungkin salah, sapa tau ada produksi spesial. VCM itu menonaktifkan beberapa silinder ketika jalan santai, otomatis mesin bergetar karena ada ketidakseimbangan daya torsi yang memutar crankshaft. Tapi, Honda menyertakan dua teknologi untuk meredam (dan mengklaim menghilangkan) getaran tersebut. Yaitu mounting mesin aktif yang dikontrol komputer dan Active Noise Control. ANC merekam suara gaduh mesin dan memutar balik suara itu secara insinkron melalui sistem audio mobil. Untuk Accord baru, VCM masuk generasi kedua, jadi gak cuma mematikan silinder 3 aja tapi juga bisa matiin hanya 2 silinder. Untuk kasus mobil pake VCM mesinnya bergetar, ada kemungkinan mounting mesin aktifnya rusak.
yup ini memang odyssey versi US yang dulu kalo gak salah di JDM namanya odyssey lagreat. Kalo yang versi US sini mesinnya V6 3.5 VCM dan masih diprod sampe sekarang malahan laku kaya kacang goreng :D . Mesin yang sama dengan new accord, mungkin cuma hp dan torsi gak sebesar accord.
GTR
Post by GTR »
Elysion 3.5ltr versi indo udah VCM deh.
VTC pd i-vtec bukan mengaktifkan cam panas di setiap putaran mesin, tapi mengubah "timing" cam continuously pd setiap range rpm;
Profil intake cam-lobe 'panas' engage pd range putaran middle-high tertentu.
Justru sohc i-vtec (R series) itu bukan prioritas di profil cam baru, tapi "cara kerja" baru yg berbeda sama sekali dgn sohc-vtec sebelumnya baik itu "eco"sohc-vtec or "power"sohc-vtec sebelumnya;
"Mild/ecomony" Camlobe hanya engage pd range low-to-middle rpm (sekitar up to 3500rpm) dgn syarat load mesin tertentu yg relatif ringan / cruising bukan hard-acceleration.
Pendekatan Camry terlihat habis2an disini Pushing FC sekaligus performa dgn :
aplikasi Variable-Valve juga pd exhaust (dual vvti) + Close-Ratio-Gearing (6speed a/t + Tiptronic) ==> menghasilkan akselerasi dan FC excellent.
Poor Accord adalah :
Less Close-Ratio-Gearing (5speed a/t tanpa Tiptronic pula) ==> unlike Honda tradition in advance transmission application;
& aplikasi Variable-Valve hanya pada Intake-Valve saja (since itu SOHC i-vtec) = blm utilize mesin secara maksimum dlm menekan FC & performance ==> walaupun hasil FC nya sama dgn camry tapi sedikit kalah dlm akselerasi.
cmiiw
handling
Post by handling »
boilers wrote:
GTR wrote:accord = ivtec + vcm
camry = dual vvti
Accord = ivtec + vcm + 5 speed auto
Camry = dual vvti + 6 speed auto
Pilih mana ? hehehe :D
Mirip2 aja sih sebenernya imo
Accord = ivtec + vcm + 5 speed auto = cenderung geter.......:D
pernah baca di review Elyssion...cmiiw
kutkuy
Post by kutkuy »
kalo terjun lagi yg ini lebih kuat ga yah?
SALE SALE SALE!! BROQUET cuma 70rb!!! BARU! SEGEL!!
broquet.bandung et yahoo dot com
GTR
Post by GTR »
tp review v6 dari bbrp source tdk ada yg blg getar utk accord.
since tipe kunci utk di indo adalah yg 4cyl, maka yg penting disini adalah bgm performance tipe yg 4cyl nya, kebetulan sama2 2400cc.
boilers
Post by boilers »
Wah, thanks untuk infonya yg detail nih Bung Midi.
Iya, yg volume leader di Indo annti pasti versi 4 cyl. Kalo untuk versi 4 cyl sih saya pilih mesin Accord deh dibanding camry hehe :)
kutkuy
Post by kutkuy »
saya sih masih pegang camry hehhehehe :D
Jose
Post by Jose »
Saya sih masih pilih Accord, tp khusus yg 2.4 ya!! secara saya pakai Accord VTI-L 2006 utk harian, jadi bisa merasakan langsung.
Saya jg sudah Compare Accord saya dengan Camry 2.4 terbaru (2007) punya teman, yg kebetulan “prilaku”nya rada2 “setan jalanan” spt saya. :evil:
Hasilnya :
1.Handling :
Start dr Rindu Alam II cipanas, kearah jakarta sampai pintu tol ciawi, jam 4 pagi. Accord saya finish sekitar 6 detik didepan new camry.
Jadi : Handling = Accord Win :e-clap:
2. Performa :
Rute : start di pintu tol ciawi, masuk tol simatupang & finish di Gerbang tol Pondok Labu (Citos).
Sekedar perbandingan Accord saya powernya 160 hp, new Camry teman saya 165 hp. Start di pintu Tol dilakukan dengan cara biasa, layaknya pengemudi lain bukan "Drag style". hal tersebut membuat Camry teman saya langsung ngacir meninggalkan saya. Tapi ketika saya mulai main RPM tinggi, Accord saya mulai mengejar Camry teman saya. Walaupun kalah power, akhirnya saya bisa menyusul camry teman saya di kecepatan 205 kpj dan makin jauh meninggalkan camry teman saya. Akhirnya saya sampai di pintu tol Pondok labu hampir ½ menit didepan camry teman saya. Saya baru tahu klo Camry teman saya topspeednya sekitar 215 kpj lebih dikit, sedangkan Accord saya bisa sampai 230 kpj(5800 RPM, Gear 5).
Jadi : Performa = Accord Win :e-clap:
Note :
1. Saya hanya Compare mengenai kesan mengemudi (Performa & Handling). Klo di compare scr keseluruhan (Fitur dll) Camry yg menang krn fiturnya lbh byk.
2. Kedua mobil kondisinya standar. Hanya servis rutin dan sering diajak “Olah Raga” setiap minggu pagi di jalan Tol.
3. Bantingan Camry lebih empuk, tapi kabin & suara mesin Accord lebih senyap (Hening)
4. Klo mau merasakan enaknya tarikan Accord, mesinnya harus dipacu diatas 4000 RPM. Karena klo dibawah itu tarikannya biasa2 saja & suara mesinnya ga kedengaran.
Ini hanya pendapat saya & teman saya, Saya tidak bilang Accord lebih bagus. Karena semua masalah “Selera”. :e-naughty:
Thanks. :beer:
HilmanZ
Post by HilmanZ »
kutkuy wrote:saya sih masih pegang camry hehhehehe :D
sama..model accord 2008 ini rasanya aneh d y..lebih elegan liad camry.. :beer:
satyr
Post by satyr »
tetep vote 4 camry
mantep bgt exterior nya
tp mesti liat dulu fitur accord dan mesinnya
4A-FE, 7A-FE, 1ZZ-FE, 2ZR-FE
HilmanZ
Post by HilmanZ »
mau nya c eksterior camry,mesin accord,handling accord..hehehe khayal mode on...
Risol1
Post by Risol1 »
HPM akan mengeluarkan accord sedan dan coupe (2 pintu).....berikut cuplikan beritanya dari Kompas edisi hari ini:
Selasa, 5 Februari 2008 | 09:13 WIB
UNTUK memperkuat cengkramannya di pasar otomotif Tanah Air, Honda segera meluncurkan Accord seri baru di awal Maret 2008 mendatang. Varian legendaris Honda ini akan dipasarkan dalam tipe sedan dan coupe. Accord sedan dan coupe mengusung mesin 2.4 liter dan 3.5 liter, dengan transmisi 5MT (standar di mesin 2.4 liter), 5-speed AT (standar di 3.5 liter dan tersedia pula untuk 2.4 liter), serta 6-speed MT (khusus Accord Coupe V6 6MT). Power mesin 4 silinder 177-hp dan 190-hp.
Pada varian Accord terbaru bermesin 3.5 liter i-VTEC V6 yang menghasilkan 268-hp, atau paling besar dalam sejarah Accord ditanamkan fitur andalan terbaru. Fitur itu adalah generasi baru Variable Cylinder Management (VCM), teknologi penghemat bensin. VCM mengoperasikan enam silinder bila membutuhkan power maksimal, tapi juga dapat mengoperasikan hanya 4 atau 3 silinder, bila ingin menggunakan bahan bakar dengan efisien.
Selain itu kadar emisi Accord pun sudah medapat pengakuan Partial Zero Emissions Vehicle (PZEV). Mobil ini juga dilengkapi struktur body Advanced Compatibility Engineeringâ„¢ (ACEâ„¢) yang membuatnya lebih tahan tabrakan frontal dari kendaraan yang berbeda ukuran dan ketinggian bumper.
Fitur safety lainnya adalah Vehicle Stability Assist™ (VSA®), side-curtain airbags, dual-chamber front side airbags di mana untuk posisi pengemudi dilengkapi Occupant Position Detection System (OPDS), active front seat head restraint, ABS dan lainnya.
satyr
Post by satyr »
coupe?? ga salah??
di indo keluarin coupe = bunuh diri
tau sendiri di sini maunya muat banyak
HilmanZ
Post by HilmanZ »
mm coupe..kaya nya ga bakal laku d di sini..orang mau bli coupe pst maunya yg mewah and made in Germany punya kaya BMW or Mercy..Accord Coupe?? no hope...
satyr
Post by satyr »
mobil2 coupe di indo:
hyundai coupe: dibeli cuma kalangan tertentu, harga jual 2nd ancur lebur
nissan silvia: nyaris ga pernah ketemu di jalan
BMW Coupe: jarang bgt liat
ya itu di indo.. demennya muat banyakkkkkkkkkkk
GTR
Post by GTR »
coupe ckd ATPM yg mandek :
Mazda MX6 & Nissan Sentra Coupe (twincam 120ps)
Risol1
Post by Risol1 »
kalo honda belom tentu jeblok bos!...kalo gw bilang banyak juga eksekutif2 muda atau anak2 muda yg bokapnya berduit yang pengen nyobain naik coupe dengan harga "merakyat" (walaupun yang tipe V6 bisa nembus 500jeti juga)......
dan bagusnya accord coupe juga muat 4-5 orang dewasa dengan cukup nyaman (legroom masih OK, cuma headroom dan access naik turun yang agak rumit)...dan juga modelnya yang cuantik nian :D
honda pasti juga menargetkan penjualan accord coupe ini gak setinggi versi sedannya (setidaknya spt estilo dan genio lah pada jamannya) :D ....makin banyak varian kan makin bagus......jadinya pilihan jadi makin banyak
kalo accord coupe cukup direspon sama pasar indonesia, pasti gak lama lagi TAM bakal luncurin camry solara (2 pintu) buat nandingin accord :D
GTR
Post by GTR »
maybe nanti setelah harganya jatuh, kalo produknya ekslusif bisa menguat lagi kalo tidak ada penerusnya spt kasus hrg estilo.
GTR
Post by GTR »
apa versi indo spt ini:
[attachment=2]Honda-Accord_EX-L_V6_Coupe_2008_800x600_wallpaper_19.jpg[/attachment]
[attachment=1]Honda-Accord_EX-L_V6_Coupe_2008_800x600_wallpaper_11.jpg[/attachment]
[attachment=0]Honda-Accord_EX-L_V6_Coupe_2008_800x600_wallpaper_1b.jpg[/attachment]
satyr
Post by satyr »
ugly..................
malah lebi bagus hyundai coupe kalo dari modelnya -_-
