Koleksi hand tools [Part 02]
Goldroom
Re: Koleksi hand tools [Part 02]
Post by Goldroom »
marmut wrote: Sun Oct 18, 2020 9:27
indeskey wrote: Sun Oct 18, 2020 8:55 Adakah mbah suhu yg sudah pake tambahan digital torque wrench dgn harga sekitar 600-650k?
yang kaya gini :
hampir saja beli model kaya gini saat lagi putus asa dan belum dapet wahyu dari mbah shifu....
Wah ini ane udah pake dari awal tahun, merknya sama MXITA juga beli di Lazada waktu itu harga 538 ribu udah sama ongkir.
Sekalian ane review aja yaa di sini:
Pas mau beli ada 4 pilihan tipe dengan range Nm yang berbeda 0.3-30Nm, 2-200Nm, 10-200Nm, dan 17-340Nm. Ane beli yang 2-200Nm karena yang butuh baut yang butuh torsi di atas 200Nm cuma baut driveshaft depan aja (270 Nm) di mobil ane sedangkan yang butuh <17 Nm lumayan banyak.
Waktu itu juga agak ragu gimana akurasinya, nemu artikel yang udah review torque adapter model ini ternyata akurat juga, bahkan bisa lebih reliable daripada torque wrench konvensional karena kalau torque wrench konvensional pas nyimpen ga diset ke torsi terendahnya bakal berkurang akurasinya lama-lama.
artikel wrote: We originally gathered a small collection of standard 12-inch drive clicker torque wrenches including a Snap-on, a Craftsman, and a Harbor Freight. Then we discovered a digital torque adapter sold by Harbor Freight. This small unit fits in between a standard 12-inch drive breaker bar and the socket, and using a digital strain gauge, it converts the torque applied through the adapter into a digital readout. At a typical Harbor Freight price of $39.99, we decided to include it in our test. We frankly didn't expect this little unit to be very accurate. But testing proved otherwise.
We ran the torque adapter through five consecutive applications of 70 lb-ft of torque to watch it hit within 0.10 of a lb-ft twice and actually hit exactly 70 lb-ft on one occasion. The average of the five tests was an amazing 70.1 lb-ft. The unit offers a digital readout and warning lights, and it even emits a progressive electronic beep when nearing the pre-selected torque.
Next, Chauvie suggested an even more interesting test. He offered to keep our Harbor Freight 12-inch clicker wrench and test it every 30 days for two months while keeping the wrench loaded at 70 lb-ft. He said the problem with clicker torque wrenches is, when the mechanic fails to return the preload to its lowest setting after each use, the tool begins to lose accuracy. Chauvie says the longer the wrench is loaded, the less accurate it will become. He has since reported on the torque wrench's performance at 30 days and 60 days, and we've included a graph to show the results (page 30). This inaccuracy occurs because the internal spring loses its tension, allowing the wrench to break away (click) at a lower torque value. Chauvie says this is a common problem for all types of clicker torque wrenches. The point here is that you should always return your clicker torque wrench to the base setting before storing the wrench. This simple step will maintain the wrench's accuracy for years instead of mere months.
Walau merknya yang ditest di artikel beda, PITTSBURGH Pro dari Harbor Freight vs yang dari Lazada merknya MXITA, model serta kelengkapannya sama persis, kemungkinan sih 1 pabrikan.
Dapet carrying casenya juga yang include converter 1/2" ke 3/8" dan 1/2" ke 1/4"
Dapet sertifikat kalibrasi juga yang nampilin % deviasinya pas ditest di pabrik
Sejauh ini udah dipake buat ganti engine mounting, shock, bongkar pasang jok (pas bersihin interior), ganti kampas rem depan belakang, ganti arm, ganti belt masih aman. Minusnya katanya kalau ditaro di casenya suka kepencet tombol powernya jadi batrenya cepet abis, jadi tiap abis pake ane lepas aja batrenya biar ga abis.
Sekian review singkatnya dari nubi, dengan harga 500ribuan dapet torque wrench yang rangenya lumayan lebar jadi lumayan kere hore sih menurut ane :big_grin:
Tapi mungkin kurang cocok buat suhu-suhu di sini yang prefer torque wrench dengan harga juta jutaan hehe :big_peace:
indeskey wrote: Mon Oct 19, 2020 8:17 Mbah suhu semua. Lg pengen maintenes dongkrak buaya kere hore usia 10thn. Cuma pingin nge bleed atau memungkinkan ganti oil nya.
Pertinyiinyi, oli yg cocok buat dongkrak apa yak. Lihat di online jarang juga yg spesifik buat dongkrak buaya. Lihat di toped oli shock merk jumbo nulisnya bisa buat dongkrak buaya. Mohon pencerahannya.
selama ini saya pake atf.
di halaman sebelum ini pernah saya pajang kok foto abis serpis dongkrak.
ini serpis dongkrak dalam arti sebenarnya ya.... bukan "serpis dongkrak" kaya di alas roban sama jalur pantura.
omnyanaira wrote: Mon Oct 19, 2020 11:49 Om2 semua... Mau izin bertanya. Utk kunci ring pas merk multipro gimana ya kualitasnya?? Apakah setara tekiro atau dibawah nya ya?
Lagi tertarik mau beli kunci ring pas ratchet merk multipro... Tertarik beli kunci ring pas ratchetnya di toko ijo sekaligus utk melengkapi kolesksi kunci set saya... Sebelumnya sdh pnya kunci sok tekiro, kunci sok deepwall king tony, dan kunci set stanley yg 100rb an.
Semuanya saya beli di toko ijo
Mohon sarannya. Terima kasih
yang ratchet ring-nya saja apa yang open end-nya juga?
mau beli satuan atau set?
kalau beli satuan, anggaran berapa?
mungkin om sudah pernah liat, tapi gapapa saya pajang lagi sapa tau berminat....
bisa belok sampai 90°. merk sata. harga untuk yang 10mm kalo nggak salah inget 120ribuan.
nggak nyesel beli ini, malah lebih sering kepake ketimbang open end-ring yang biasa.....
Goldroom wrote: Mon Oct 19, 2020 12:06
kelemahan torq wrench yang pakai per spiral memang begitu pak, harus di set ke nol lagi setelah selesai bertugas hari itu.
dan itu pun saya lihat sebagai kelebihan juga. apakah kita yang pakai cukup perhatian atau sekedar pakai tanpa perduli?
kalau saya, pilih yang split beam tanpa per spiral. jadi, aman tidak perlu di set ke nol lagi.
masalah mahal murah, pakai merk apa, itu bebas terserah dengan selera dan kantong masing-masing.
tapi buat saya pribadi, saya butuh yang ergonomis, presisi, kuat, dan tahan lama.
masalah harga, saya selalu cari yang diskonan.
:beer:
mantafftt review nya ...
om, alat ini bisa dipakai utk mengukur torque baut/mur yg sdh terpasang ngga ya? kl bisa boleh jg nih, cape kl hrs selalu liat torque spec dr fsm atau online.
yanuarra
Post by yanuarra »
yang kaya gini :
Waah sayang ga muncul gambarnya...
yanuarra wrote: Mon Oct 19, 2020 12:56
hp blesak.
:big_bored:
diburak bae.
kalo di hp kita sih.....
pada bae beli ana gambare...........
Goldroom
Post by Goldroom »
marmut wrote: Mon Oct 19, 2020 12:38
:beer:
Nah setuju om, tapi sayangnya yang ane liat di beberapa bengkel itu torque wrench setelah dipake dibiarin aja tanpa diset ke nol lagi. (walaupun udah better sih minimal pake torque wrench daripada yang ga pake sama sekali) :mky_01:
Wah ada rekomendasi merk dan tipenya kah om yang model split beam?
Omnibus wrote: Mon Oct 19, 2020 12:50
Bisa om jadi ada 2 mode, Peak dan Trace.
Untuk Trace itu dia akan ngedisplay torque valuenya secara real time ketika sedang dioperasikan sedangkan Peak itu dia akan ngedisplay maximum torque valuenya.
Jadi kalo misal kita pake mode Peak kita bisa tau max torque yang dibutuhkan untuk melonggarkan suatu baut/mur yang sudah terpasang itu berapa.
Tapi menurut nubi agak bias juga karena baut/mur yang sudah terpasang itu juga bisa berubah torque valuenya misal karena karat, kotoran, efek threadlocker, dll sehingga max torque yang dibutuhkan untuk buka baut/mur nya bisa beda dengan torque spec pabrikan.
Wah maaf om sepertinya imgur.com diblock yaa, sudah ane upload ulang lewat attachment hehe.
Goldroom wrote: Mon Oct 19, 2020 13:23
nah, miris juga kalau kasusnya begitu.
ada torq wrench dan dipakai, itu sudah benar.
masalahnya, torq wrench-nya terawat apa enggak? dan angkanya tepat apa enggak saat digunakan?
rekomendasi? walah.... saya mah gaada seujung kuku ilmunya, ga berani kasih rekomendasi.
tapi untuk saat ini, split beam saya pakai stahlwille pak. seri 730/12 quick dan seri 730Na/5.
kalau yang per spiral ada britool evt600 dan 1 lagi unbrand buatan china.
idenya boljug ini suhu mbah shifu (gelar resmi per hari ini).
blloewy
Post by blloewy »
yang kaya gini :
reviewnya mantabs...
masuk list to buy nunggu promo aja dech ntar :big_grin:
betul juga ya ... mur roda aja yg udah lama ga dibuka sama yg baru dipasang udah beda.
jadi om pakai alat itu tetap torque spec nya lihat dr service manual dong ya?
sebetulnya bisa dipakai juga sbg torque wrench calibrator ya. pake TW manual mengencangkan baut trus pakai digital TW tsb utk check Peak nya tadi. jd tau TW manualnya akurat atau tidak dan sebaliknya TW digital tsb akurat atau tidak. artinya kl menyimpang berarti ada salah satu yg ga akurat.
yanuarra
Post by yanuarra »
marmut wrote: Mon Oct 19, 2020 13:01
hp blesak.
:big_bored:
diburak bae.
Wakakak :big_biglaugh:
:snipersmile:
marmut wrote: Mon Oct 19, 2020 13:40
halahh gelar apa lagi ini ... bukan suhu shifu apalagi plopesol :big_weee:
yanuarra
Post by yanuarra »
Omnibus wrote: Mon Oct 19, 2020 14:39
Iyaa begitu om... Untuk alasan itu ane hampir beli yg model ini... Tp nggk jadi... :big_biglaugh:
yanuarra
Post by yanuarra »
Enak jg yah...bisa dipasangkan ke ratchet... Jadilah TW digital tanpa bletak :big_grin:
Goldroom
Post by Goldroom »
marmut wrote: Mon Oct 19, 2020 13:35
Nah iya malah serem juga kalau udah bener-bener out of spec torque wrenchnya baut roda belum kenceng udah ceklek duluan.
Mantap makasih om referensi buat split beamnya. :beer:
Iya om tetep harus refer ke FSM, biasanya sih ane print dulu page-page yang dibutuhin biar gampang liatnya, kalo cek lewat hp atau laptop ribet tangan lagi kotor :big_biglaugh:
Nah untuk torque wrench calibrator bisa juga om bahkan bisa lebih praktis, tinggal colok torque wrench yang mau dikalibrasiin ke alatnya terus set mode peak. Misal di torque wrench diset 70 Nm, colok ke adapternya dan cobain ke baut roda misal sampe ceklek, nanti bisa diliat deviasinya dari display alatnya.
Lebih jelasnya bisa liat video tutorial ini om:
yanuarra wrote: Mon Oct 19, 2020 14:47 Enak jg yah...bisa dipasangkan ke ratchet... Jadilah TW digital tanpa bletak :big_grin:
Iya om mau pasang ke breaker bar juga bisa kalo butuh leverage lebih :big_grin:
Goldroom wrote: Mon Oct 19, 2020 15:20
oh iya bisa langsung dipasangin sama TW nya ya.
om, posting foto2 ya kl lagi bongkar. disini pada doyan liat foto2 seru...
sama foto tools lainnya mana nih he he he :big_grin:
indeskey
Post by indeskey »
Waduh kok klewatan postingannya mbah suhu ini. Nanti saya ublek2 lagi page belakang.
indeskey
Post by indeskey »
yang kaya gini :
Cakep reviewnya suhu...
Kayaknya jadi pingin lagi ini barang, apalagi kalau baca ke bawah bisa buat check angka untuk buka ya.
indeskey wrote: Mon Oct 19, 2020 16:11
wah, kena SP1 manggil saya mbah suhu. karena saya masih pemula.
yang sudah diresmikan itu yang inisial O domisili di timbuktu, gelar per hari ini adalah : suhu mbah shifu.
eh, apa mbah suhu shifu ya? ah, pokoknya begitu lah.....
btw mbah DOHC jangan-jangan lagi mentungin kepala pake roti tawar karena liat ada yang pajang torq dijital.....
yanuarra wrote: Mon Oct 19, 2020 14:45
justru sekarang saatnya yg tepat mbah dekan. utk ngecek .... apakah 730D msh akurat ga setelah agak terjatuh. :big_biglaugh:
tanya juga dong om ... kl "serpis dongkrak" sekalian paket sama "cuci kolong gardan" ngga?
wah.... suhu mbah shifu ini kalo urusan dongkrak, gardan, as kopel, kolong, nyamber aja......
bentar lagi kayanya ekspansi ke wilayah airbag.
marmut wrote: Mon Oct 19, 2020 17:18 wah.... suhu mbah shifu ini kalo urusan dongkrak, gardan, as kopel, kolong, nyamber aja......
mendingan saya .... drpd tangan chef diomongin sampe 3x dlm tempo 1x24jam
doyan tangannya apa doyan makanan hasil buatannya. :big_biglaugh:
