Mengapa Avanza sulit di geser oleh kompetitornya
Re: Mengapa Avanza sulit di geser oleh kompetitornya
Satu basis sama rush terios...alias sama aja dr RAV4 jadoel juga. Bikin platform monokok itu mahal, apalagi buat si kecil Daihatsu...makanya share sana sini.
http://www.sun2surf.com/article.cfm?id=21424
Kalo sepengetahuan om ak4ng, avanza-xenia top speed nya brp?
Live as if you'll die today
chasis avanza agak semi semi monocoque.. karena besi chasisnya tipis.. ngga kayak mobil2 ladder on frame yang lebih mahal, besi chasisnya tebal jadi kaku ngga kayak avanza
kalo udah gitu ngalah aja deh ama apansa chiong... daripada malu kalahDOHC wrote:you will think you can sehhh siong.... kalo uda gt mahh jangankan ipah, pajero sport jg kalah siong...![]()
bukan semi om gmx...emang monokok - cuman ya besinya ya gak yg mahal2 lah..sesuai hargagmx wrote:chasis avanza agak semi semi monocoque.. karena besi chasisnya tipis.. ngga kayak mobil2 ladder on frame yang lebih mahal, besi chasisnya tebal jadi kaku ngga kayak avanza
Lho AvXen itu satu platform sama RAV4 jadoel ?
baru tau ni
kalo RusTer sih ane percaya.
Dulu ane denger platform AvXen itu dari Daihatsu Taruna secara kalo dilihat bentuk kan emang mirip, ga tau nya RAV4 jadul.
PEUGEOT 207 (1 STAR)asudarsono wrote:Kayak besi Fortuner
Adult occupant: The rating for the vehicle was limited to 1 star due to the unacceptably high risk of life threatening injury to the driver's head presented by the steering wheel. The protection offered to the driver's lower legs was weak due to high rearward clutch and break pedal displacement. There were hazardous structures in the area of the fascia that could be impacted by an occupants knees. The body shell was not capable of withstanding further loading. The ruptures to the footwell threatened the driver's feet. The car has an airbag control tell-tale (light) in the instrument panel which will be illuminated after turning the ignition key and making contact. Unfortunately there were NO AIRBAGS in this car. The tell-tale may mislead consumers.
Sumber: http://www.latinncap.com/_en/?pg=results_list
bwahahahahahaha
Ane kasih dua jempol wat panther kalo soal iritan solar! Ane pernah sewa panther temen, plat BK. hanyaaaa,... pas di tol dalem kota arah serpong, kalo udah 110 kpj, kok lamaaaa bangeth ya nyampe ke 120? Harus di urut lagi ngegasnya, baru deh nyampe 125 kpj...Hasilnya, Mr "Octopus" beraksi.. Wah, ni mesin belom pernah dikalibrasi kalee? Tapi, emang uiriiit....!!BADAK wrote:@VanzMatic: Untuk saat ini mmg banyak yg mengatakan hrg new panther kurang worthed, krn dgn teknologi jadul tp hrg jual nya mendekati diesel modern macam D4D. Tapi sebenernya kesederhanaan panther itu lah yg saat ini susah dicari. Panther hingga saat ini hrg seken nya msh ckp kuat walopun umur nya udah belasan taon. Hal ini bisa jd krn mmg mesin nya yg tergolong badak, mudah servis nya, dan bisa diservis di bengkel2 pinggiran. Hal yg berbeda bila dibandingkan innova D4D yg lbh canggih & tidak sembarang bengkel mampu menservis. Aku rasa kl innova sudah berumur setua panther blm tentu hrg nya bisa ttp kuat. Karena untuk biaya restorasi nya tentu jg butuh dana yg lbh besar drpd panther.
Udah BTT jg ah...
- Daily Vehicle: Unimog
apanja g'05 160 kmh belum mentok,, keburu pintu tolBADAK wrote:Kalo sepengetahuan om ak4ng, avanza-xenia top speed nya brp?
wah... pantatnya emang ga goyang dangdut ya?ak4ng wrote:apanja g'05 160 kmh belum mentok,, keburu pintu tolBADAK wrote:Kalo sepengetahuan om ak4ng, avanza-xenia top speed nya brp?
pernah sesekali ngebut pake avanza sendirian, diatas 120kmh langsung dah kaya kapal mo take off, ban kerasa kaya ga ada gripnya dan goyang kiri kanan
yg saya rasain, avanza yang lama yang belum VVT-i 160 belum goyang om, tapi kalo yang VVT-i 120 udah mulai goyang, serem.. ini subyektif yang saya rasakan lho ya, dan didukung oleh driver2 dan teman2 kantor.. saya pernah punya avanza lama non VVT-i dan pernah dapat avanza dinas VVT-i, dan kantor saya pakai puluhan avanza sebagai armada sejak 2004 sampai sekarang, jadi yang testi tersebut bukan hanya dari 1 unit saja.. sekali lagi ini subyektif yg saya rasakan..
panther mahh emang bukan buat ngejar top speed... 120an aja uda cukup nyiksa mesin nya tuh walaupun kalo bener2 dibejeg bisa ampe mentok di 140... apalagi itu panther yg non turbo yahh... kalo panther kotak mungkin masi lebi enteng ngejar putaran atas nya tapi tetep aja mentok di kisaran speed sgitu jg...VanzMatic wrote:Ane kasih dua jempol wat panther kalo soal iritan solar! Ane pernah sewa panther temen, plat BK. hanyaaaa,... pas di tol dalem kota arah serpong, kalo udah 110 kpj, kok lamaaaa bangeth ya nyampe ke 120? Harus di urut lagi ngegasnya, baru deh nyampe 125 kpj...Hasilnya, Mr "Octopus" beraksi.. Wah, ni mesin belom pernah dikalibrasi kalee? Tapi, emang uiriiit....!!BADAK wrote:@VanzMatic: Untuk saat ini mmg banyak yg mengatakan hrg new panther kurang worthed, krn dgn teknologi jadul tp hrg jual nya mendekati diesel modern macam D4D. Tapi sebenernya kesederhanaan panther itu lah yg saat ini susah dicari. Panther hingga saat ini hrg seken nya msh ckp kuat walopun umur nya udah belasan taon. Hal ini bisa jd krn mmg mesin nya yg tergolong badak, mudah servis nya, dan bisa diservis di bengkel2 pinggiran. Hal yg berbeda bila dibandingkan innova D4D yg lbh canggih & tidak sembarang bengkel mampu menservis. Aku rasa kl innova sudah berumur setua panther blm tentu hrg nya bisa ttp kuat. Karena untuk biaya restorasi nya tentu jg butuh dana yg lbh besar drpd panther.
Udah BTT jg ah...![]()
gilee.. yg perna ane cobain yg non vvt-i ampe eneg ane duduk di row ke 2... yg vvt-i blom perna coba kenceng2 rute tol... bearti kalo yg vvt-i di bejeg kenceng mungkin ane ampe pingsan kali yah d dalem nya... dah bukan eneg lagi..gmx wrote:yg saya rasain, avanza yang lama yang belum VVT-i 160 belum goyang om, tapi kalo yang VVT-i 120 udah mulai goyang, serem.. ini subyektif yang saya rasakan lho ya, dan didukung oleh driver2 dan teman2 kantor.. saya pernah punya avanza lama non VVT-i dan pernah dapat avanza dinas VVT-i, dan kantor saya pakai puluhan avanza sebagai armada sejak 2004 sampai sekarang, jadi yang testi tersebut bukan hanya dari 1 unit saja.. sekali lagi ini subyektif yg saya rasakan..
he eh siong.... mending kalo ktemu apansa minggir aja dehhh.... sayang nyawa ama sayang mobil jg.... maklum masi muda sehh, masi blom ngerasain yg macem2....Hansen wrote:kalo udah gitu ngalah aja deh ama apansa chiong... daripada malu kalahDOHC wrote:you will think you can sehhh siong.... kalo uda gt mahh jangankan ipah, pajero sport jg kalah siong...![]()
@ak4ng: Wah avanza nya koq mengerikan om, jgm2 dipasangi double turbocharger neh
@DOHC: setuju ma dohc, panther bukan buat ngejar kenceng. kl mo adu irit & adu badak bolehlah
Mesin Daihatsu emang kenceng2, bro. Sejak jaman Charade dkk.
Beda ama mesin Toyota tulen ..... cuma kenceng bensinnya
Ready to Race
asu darsono asu darsono...pagi2 udah nyampah aja. Sana minum obat dulu biar pinteran...ntar tak lanjut kasi les nyaasudarsono wrote:Mesin Daihatsu emang kenceng2, bro. Sejak jaman Charade dkk.
Makek apanja diatas 120 atau 140...? Duh sayang amat.... Kalo wat aku siiyy, perilaku speed segitu udah masa lalu gue... Jadi yang ngerasa hebring bisa ngebuuuut, ... sorry, no offense ya, masa depan loe, masa lalu gue...DOHC wrote:gilee.. yg perna ane cobain yg non vvt-i ampe eneg ane duduk di row ke 2... yg vvt-i blom perna coba kenceng2 rute tol... bearti kalo yg vvt-i di bejeg kenceng mungkin ane ampe pingsan kali yah d dalem nya... dah bukan eneg lagi..gmx wrote:yg saya rasain, avanza yang lama yang belum VVT-i 160 belum goyang om, tapi kalo yang VVT-i 120 udah mulai goyang, serem.. ini subyektif yang saya rasakan lho ya, dan didukung oleh driver2 dan teman2 kantor.. saya pernah punya avanza lama non VVT-i dan pernah dapat avanza dinas VVT-i, dan kantor saya pakai puluhan avanza sebagai armada sejak 2004 sampai sekarang, jadi yang testi tersebut bukan hanya dari 1 unit saja.. sekali lagi ini subyektif yg saya rasakan..![]()
Kalo adu ngebut mah ana bukan di tol, sorry, bukan apa2, terlalu gampang wat ngebut, palagi kalo jam jam satu an pagi.
Bagaimana kalau Surabaya(Waru) - Jogja (Kotagede) 4 jam aja lewat Caruban, Ngawi Karangjati?
Aku, sayang banget bawa apanja speed segitu... pengin nyoba miara ini mobil ampe 10 thn... jadi ya disayang-sayang lah... Wekekek...
Hehehe.. Itu bbrapa tahun lalu om, sekarang sih kalo bawa mobil ga bisa kenceng, pake ban lumpur soalnya..
ya jangan di goyang2 donk!!!! lurus aja!!scorpio wrote:wah... pantatnya emang ga goyang dangdut ya?ak4ng wrote:apanja g'05 160 kmh belum mentok,, keburu pintu tolBADAK wrote:Kalo sepengetahuan om ak4ng, avanza-xenia top speed nya brp?
makanya pake apanja!!!gmx wrote:Hehehe.. Itu bbrapa tahun lalu om, sekarang sih kalo bawa mobil ga bisa kenceng, pake ban lumpur soalnya..
Saya msh ada mobil dinas avanza tuh, ga pernah saya pake, nongkrong aja terus di basement kantor. Kalo perlu mobil untuk jalan keluar, mending saya pake mobil sendiri, dulu waktu mobil dinas saya masih kijang diesel sih saya pake terus malah saya bawa pulang.. Sory ya om, saran anda tidak saya terima..ak4ng wrote:makanya pake apanja!!!gmx wrote:Hehehe.. Itu bbrapa tahun lalu om, sekarang sih kalo bawa mobil ga bisa kenceng, pake ban lumpur soalnya..
cobain dulu!!!! ntar ktagihan lho!!gmx wrote:Saya msh ada mobil dinas avanza tuh, ga pernah saya pake, nongkrong aja terus di basement kantor. Kalo perlu mobil untuk jalan keluar, mending saya pake mobil sendiri, dulu waktu mobil dinas saya masih kijang diesel sih saya pake terus malah saya bawa pulang.. Sory ya om, saran anda tidak saya terima..ak4ng wrote:makanya pake apanja!!!gmx wrote:Hehehe.. Itu bbrapa tahun lalu om, sekarang sih kalo bawa mobil ga bisa kenceng, pake ban lumpur soalnya..
avanja bisa kenceng pake ban lumpur...??ak4ng wrote:makanya pake apanja!!!gmx wrote:Hehehe.. Itu bbrapa tahun lalu om, sekarang sih kalo bawa mobil ga bisa kenceng, pake ban lumpur soalnya..
