Koleksi hand tools [Part 02]
Re: Koleksi hand tools [Part 02]
yanuarra wrote: Mon Oct 12, 2020 17:12 Mbah rektor, ane dpt hembusan kabar itu njes dlm waktu dekat mau diganti disc rotor+padnya. Soalnya standar keausannya mbah shifu 0,05 mm
ane emang gitu orangnya ....
batere henpon baru 99% aja udah ane cas lagi
............ :ngacir:
yanuarra
Post by yanuarra »
Omnibus wrote: Mon Oct 12, 2020 17:19
Mbah rektor dohc. Confirm yah, mohon tambahin di list to do nya mbah shifu.
:big_chicken:
Oke
Kl gt d list down dl biar ga lupa
Trekstang
Oli cvt amsoil
Boot trekstang + oetikerclamp
Accessory belt
Vet steering rack + cv joint
Link stabilizer
Busi ampe 2 kali ganti
Vet steering collumn
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
Ganti dashboard
Ganti enjin head
Ganti seal klep
Ganti ring piston + honning liner
Ganti metal duduk ama jalan + seal kruk as
Ganti rante keteng
Ganti water pump
Ganti fuel pump
Ganti alternator
Eet dah, ini mobil baru belasan rebu km
yanuarra
Post by yanuarra »
Satu lagi mbah rektor dohc. Si njes mau ganti dashboard juga katanya
yanuarra
Post by yanuarra »
DOHC wrote: Mon Oct 12, 2020 17:23 Oke
Trekstang
Oli cvt amsoil
Accessory belt
Link stabilizer
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
Nah iya sip mbah rektor. Tinggal di follow up aja ini mah. Kedepan daftarnya bisa nambah panjang replacement parts ori to ori nya. Modifnya aliran original
Btw
Ngomongin pad rem
Antara advics ama bendix yg gct, bagusan mana yah ?
Anjayy..
19 halaman lg part 3
Trekstang
Oli cvt amsoil
Accessory belt
Link stabilizer
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
itu yg ane bold kaga mbahhh .... suwerrr :big_cry:
tapi yg belum kecatet:
velg baru gantiin yg peyang
aki delkor (aki std meragukan)
shock support depan
filter ac
filter udara
spooring 3x dlm 2 minggu. kaga lurus2 setirnya, jangan salahin ane. yg terakhir baru bener.
yanuarra
Post by yanuarra »
DOHC wrote: Mon Oct 12, 2020 17:29 Anjayy..
Setelah bangkit dari kubur ya mbah
yanuarra wrote: Mon Oct 12, 2020 17:34
btw TS nya kemana. udah ga pernah main ke SM lagi ya?
yanuarra
Post by yanuarra »
Omnibus wrote: Mon Oct 12, 2020 17:35
Kurang tau mbah rektor... Sprtinya iya...
gentongxz
Post by gentongxz »
Trekstang
Oli cvt amsoil
Accessory belt
Link stabilizer
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
Ganti dashboard
Ganti enjin head
Ganti seal klep
Ganti rante keteng
Ganti water pump
Ganti fuel pump
Ganti alternator
Banyak yg mau di ganti Pak DOHC..,kalo ori semua beli di beres ..,bisa terkenal tuh di sana :big_grin: ..,tiap datang di suguhin kwetiaw..,ama kopi cucu.. :big_smile]
yanuarra
Post by yanuarra »
DOHC wrote: Mon Oct 12, 2020 17:28 Btw
Ngomongin pad rem
Blm pernah pake keduanya mbah.... Tp klo si advics ini klo ga salah pernah jd oem toyota jg ya
blloewy
Post by blloewy »
Ngomongin pad rem
Mbah Rektor...bendics biasanya sich bagus.
Cuma mungkin disc nya duluan yg modyar dibanding brake pad nya...
Rekomen dipake di engine resing HR15 :big_exellent:
Ngomongin pad rem
22nya ngga jelek.
sienta bawaannya pake advics, sekarang saya kasih bendix gct.
ayla 1kr skyactiv bawaannya pake akebono yang harganya ngajak gelut, sekarang pake advics karena lebih murah dari bendix. sebelumnya pake aspira yang bikin sakit kuping karena bunyi ga ilang-ilang.
rasanya? sama aja dengan oem (bendix gct dan advics).
TS nya mbah sjam
Ahli klistrikan dan pegiat tools jg loh
Kl ga salag bengkel nya d jakbar sana
yanuarra wrote: Mon Oct 12, 2020 17:42
Ngomongin pad rem
marmut wrote: Tue Oct 13, 2020 0:55
Ngomongin pad rem
22nya ngga jelek.
Advics ok yah ? Emang seh kl liat harganya sopan ini
Kl oem toyota bukannya trw yah ?
blloewy wrote: Tue Oct 13, 2020 0:36
Ngomongin pad rem
Batu makam resing dl saya pake nya paraut.. enak pakem dan ga makan disc.. mirip2 OEM nya hitachi cungkwo
gentongxz wrote: Mon Oct 12, 2020 17:39
Trekstang
Oli cvt amsoil
Accessory belt
Link stabilizer
Vet bearing shock
Ban michelin
Soon
Harmonic damper
Disc rotor +pad
Ganti dashboard
Ganti enjin head
Ganti seal klep
Ganti rante keteng
Ganti water pump
Ganti fuel pump
Ganti alternator
Percaya lah om, nanti itu smua jg bakal beli nya di beres
Aneh si mbah mah, demen banget beli spare part beres
DOHC wrote: Tue Oct 13, 2020 1:24
oem toyota ada yang akebono, tdw, advics. trw setau saya buat aftermarketnya seperti brake master cylinder.
harga advics mayoritas dibawah bendix gct, tapi ada beberapa yang malah diatasnya.
marmut wrote: Tue Oct 13, 2020 1:40
Kadang yg pengen bkin tawuran tuh harga pad rem 1KR-UZ.. saya belom lama ganti pake bendix gct, beli d atrium kena 210 rebu + ongkos ojol kurir 36 rebu.. lah ini barusan iseng2 nyari bendix buat inofa lah koq 200an jg..
Padahal ntuh pad si 1KR ud kaya pad nya honda beat aj imut2 gt
DOHC wrote: Tue Oct 13, 2020 1:27
BeRes itu punya dia. kalopun ada faktur dipajang dimari, itu hanya formalitas.
*kabur sebelum disambit colenak.
bohlam jangan lupa diganti. yang halogen kalo ngga salah inget lifespan cuma 200an jam.
Profith83
Post by Profith83 »
DOHC wrote: Mon Oct 12, 2020 14:24
gentongxz wrote: Mon Oct 12, 2020 12:59 melenceng dikit lagi... :big_sorry: :big_sorry: ..,tadi mau tanya spare part ipah bensin 2005 (liat forumnya Feb 2020..,buset 8 bulan gak di kelonin :big_dunno: ,takut dah pada ngungsi orangnya..),mau beli pulley crankshaft..,toped ada toko yg rekom..? semalam ada tanya2 ada yg 525-750.., beres 930..,ada yang sudah pernah beli di online..
kl bedanya cuman beberapa ratus rebu ama toped, saran saya mending beli di beres om
pulley itu vital.. kl dapet yg abal2, bsa geter2 tuh
btw dl ipah saya 2006 ampe djual kmaren, blom perna ganti pulley damper nya sehh, karet nya emg ad bocel2 tp kayanya masi gapapa.. cuman kosmetik doank..
seal timing cover cuman tahan 2 taon ?? ahh klasik.. itu montir nya pasti ga sabar, abis di lem, lgs kencengin, trus tuang oli..
saya dl seal ulang timing cover taon 2012, ampe 2020 kmaren masi aman jaya sentosa
Ini bahas Innova bensin yah yang pakai timing chain. Kalau Innova diesel pakai timing belt.
DOHC wrote: Tue Oct 13, 2020 1:46
210 tu buat yang m/t?
kalo a/t, sori aja.... lebih mahal dari xv40 cuy....
kalo mau pake bendix jangan yang heavy duty kecuali kecepatan maksimal 60kmh.
