Ranking Dan Pemilihan Oli Mesin - PART 08
maastricht889
Re: Ranking Dan Pemilihan Oli Mesin - PART 08
Post by maastricht889 »
fernando_lim wrote: Sun Oct 07, 2018 12:46
Turboman wrote: Sun Oct 07, 2018 12:29
fernando_lim wrote:Om turbo ini keterangan kendall versa trans LV
VersaTrans LV ATF is recommended for use in many newer Ford, GM and Japanese vehicles where the manufacturer recommends MERCON LV, DEXRON- VI, AW-1, DW-1, SP-IV, Type T-IV or Type WS  uids. It is not recommended for use in dual clutch transmissions (DCTs), belt or chain-driven continuously variable transmissions (CVTs), or older transmissions that require a higher-viscosity uid. Please refer to the owner’s manual for correct  uid recommendation.
Berarti cocok utk ertiga dunk ?
Ertiga matic brp speed ?
kalo 4 AT sy sih prefer yg 7 sekian cSt spt Aisin AFW+
Kalo 5 AT / beyond oke pake yg 6 cSt
4 AT om turbo
Jadi better afw+ aja ?
Saya mau kuras sekali lagi ngetes afw+
Kalo jd pake afw+ sy tunggu reviewnya om hehehehe. Akhir th ini jg saya mau kuras pake q8 JK
yogi_bow
Post by yogi_bow »
Om turboman apakah ada rrkomendasi oli 0w-20 buat sienta cvt yg suka main high rpm? Baru nyari2 fkmassimo trinity 0w 20, royal.purple hps 0w 20. Ayau ada rekomendasi yg lain yg lbh ok? Thx
yogi_bow wrote:Om turboman apakah ada rrkomendasi oli 0w-20 buat sienta cvt yg suka main high rpm? Baru nyari2 fkmassimo trinity 0w 20, royal.purple hps 0w 20. Ayau ada rekomendasi yg lain yg lbh ok? Thx
FK Mass 0W20 full syn dengar2 boleh tuh, kalo ada boleh diborong sebab udah gak masuk lagi
Massimo ya bukan Elite.....
Boleh coba juga Q8 - 0W20 Formula Ultra
dimasapri
Post by dimasapri »
Turboman wrote: Mon Oct 08, 2018 2:12
Om Turbo, bagaimana dgn Kendall GT-1 Max 0W20?
Apakah kualitasnya setara Q8 - 0W20 Formula Ultra dan Amsoil SS 0W20?
udah pake 8600 km so far oke
mungkin nanti 10.000 km buang en test lab
dimasapri
Post by dimasapri »
Turboman wrote: Mon Oct 08, 2018 2:43
Siap Om Turbo.
Ditunggu hasilnya setelah mencapai 10rb km.
Terima kasih sebelumnya.
dimasapri
Post by dimasapri »
Soalnya saya sudah bandingkan, mesin yg mintanya 5W30 setelah diganti pakai oli 10W40 ternyata malah banyak gram2 besi nempel di baut pembuangan olinya.
Setelah kembali pakai 5W30 aman tidak ada gram2 oli lagi.
Saya penasaran bagaimana kalau dibalik, pakai oli yg lebih encer daripada rekomendasi.
Note:
Oli 10W40 dan 5W30 yang saya pakai sama merk dan tipenya.
Cuma beda kekentalan.
Saya sengaja untuk mencari pembuktian perlindungan mesin murni dari kekentalan, bukan beda kualitas dan merk
maastricht889
dimasapri wrote:
Turboman wrote: Mon Oct 08, 2018 2:12 FK Mass 0W20 full syn dengar2 boleh tuh, kalo ada boleh diborong sebab udah gak masuk lagi
Om kalo ambil sampel oli lama gitu biasanya seberapa om volum nya?
yogi_bow
Post by yogi_bow »
Mantaop.. siap. Twrimakasih infonya. Tdk perlu royal.ourple berarti ya. Harganya lumayan jauh soalnya.
rudyzanetti
Daily Vehicle: Xenia 2009 vvti
Post by rudyzanetti »
Om2 numpang tanya donk.
Ada yg tau kapasitas oli colt diesel ps100? Itu brp liter ya kl sekalian ganti filter olinya?
Soalnya gini kmrn ganti sekalian ama filter oli, kok 7,5 liter uda penuh ya? Ada yg tau kl di manual book nya brp liter?
Sekalian buat oli trans ama gardan nya masing2 brp liter ya? Sae nya butuh brp? Gl4 atau gl5?
Maaf kl nanya nya borongan hehe.
rudyzanetti wrote:Om2 numpang tanya donk.
biasa Mitsu bisa beli manual book & bahkan service manual nya di diler.....kalo dulu yaa
yogi_bow
Post by yogi_bow »
Ini bacanya bgmn ya? Yg plg ok yg mana? Vi fastron gold tinggi bener ya.
Vicvic
Post by Vicvic »
Kendall diesel s-dxa 10w-30 kok naik banyak banget yah dari harga 85 jadi 125 kaya harga full synthetic
rudyzanetti
Turboman wrote: Tue Oct 09, 2018 9:54
Ok ntr cb tanya2 dl di dealernya. Ini truk simpenan. Taun 99(model pertama kepala kuning, lampu bulet) tp kilometernya baru 50rban. Haha.
exflowly
Post by exflowly »
dimasapri wrote: Mon Oct 08, 2018 3:17 Soalnya saya sudah bandingkan, mesin yg mintanya 5W30 setelah diganti pakai oli 10W40 ternyata malah banyak gram2 besi nempel di baut pembuangan olinya.
Note:
Boleh minta info olinya?
Saya pakai kekentalan beda 0w20, 10w30 dan 15w40 di mesin saya tidak ada penambahan/pengurangan gram-graman di mesin M52 saya. Tarikan awal (pas jalan pagi) 15w40 paling lemot, tapi kalo dah jalan kenceng dan mesin panas rasanya gak jauh beda. 0w20 yang paling enteng tapi paling berisik, mungkin karena mobil saya masih flat tappet.
yogi_bow wrote:Image
0W20 mah prinsipnya "ada harga - ada rupa"
emang mau pake utk brp km si ?
yogi_bow
Post by yogi_bow »
Turboman wrote: Wed Oct 10, 2018 1:32
10rb aja om. Tp yg tahan digeber2 euiy. Sama yg enteng naik rpmnya.
0W20 mah paling enteng kalo soal enteng
Ya boleh coba Q8 - 0W20.......juga Amsoil ASM......Kendall juga boleh
Btw semua oli 0W20 full syn kalo sering maen high RPM ya ganti oli nya sebaiknya jangan 10.000 km, bikin aja jadi 7500 - 8500 km
Kalo push & glide ya boleh 9000 - 10.000 km
rudyzanetti
Kendall gt1 5w30 lg promo di bli2 . 12 rb seliter.
Sy br beli 9 liter. Buruan yg pengen. Hehe
snoepje
Post by snoepje »
rudyzanetti wrote: Wed Oct 10, 2018 4:27 Kendall gt1 5w30 lg promo di bli2 . 12 rb seliter.
Wah om untung banget,
sekarang stock sudah habis :big_cry:
G0g3Ta
Post by G0g3Ta »
Ada rekomen engine oil untuk MX-5 2016?
Bawaan Mazda sih idemitsu ya, tapi suaranya rada kasar. Pengen nyoba" oli lain :D
rudyzanetti
snoepje wrote: Wed Oct 10, 2018 4:39
Iya barusan ngecek uda abis..
saya lg hoki kyknya om.
Iseng buka bli2, kok ada kendall harga 12 rb. Lsg hajar beli. Hehe.
snoepje
Post by snoepje »
rudyzanetti wrote: Wed Oct 10, 2018 4:49
sekarang malah websitenya macet,
mau beli barang apapun juga nggak bisa :wkkk:
dimasapri
Post by dimasapri »
exflowly wrote: Tue Oct 09, 2018 18:53
Note:
Fastron, Om
dimasapri
Post by dimasapri »
Turboman wrote: Wed Oct 10, 2018 2:37 0W20 mah paling enteng kalo soal enteng
Nahh...yg dimaksud main high rpm ini seberapa tinggi, Om Turbo?
Selalu nyentuh redline?
Kalau kapasitas mesin 1500cc, 3000 - 4000 rpm termasuk high rpm juga?
