Yg udah dapet Livina absen disiniii.........
http://www.direct.gov.uk/en/Environment ... /DG_064428
Greener driving
The way you drive your car will affect how much fuel you use and the amount of emissions your car produces. By following the tips below you can save money and reduce emissions:
* driving smoothly can reduce fuel consumption - check the road ahead, anticipate traffic and avoid harsh acceleration and breaking
* shift to a higher gear at the right time - shift up at 2500rpm for petrol cars and 2000rpm for diesel cars - a vehicle travelling at 37mph in third gear uses 25 per cent more fuel than it would at the same speed in fifth gear
(ini yg saya maksudkan pak)
* get in and go - modern engines are designed to be most efficient when you just get in and go. Keeping the engine running or pumping the accelerator wastes fuel, increases engine wear and increases emissions
* switch your engine off if you know you won't be moving for a while
* check your tyre pressures regularly - under-inflated tyres can increase your fuel consumption by up to three per cent
* stick to the speed limits - at 70mph you could be using up to 30 per cent more fuel than at 50mph
* remove unnecessary weight and roof racks - they increase the weight and air resistance so they increase the amount of fuel you use
* air conditioning and other on-board electrical devices (like mobile phone chargers) increase fuel consumption, so only use them when necessary
Greener driving
Re: PULANG !!
bokapnya_maxx wrote:Maxx, ngapain sih loe bekoar2 disini? Emangnya loe udah gak ada kerjaan lagi maen2 internet terus?
Sadar dong, pengetahuan soal tekhnis otomotif loe masih dangkal, karena belum semua ilmu gue turunin. Gak perlu loe asal bunyi atau maen forward dari sumber2 lain yg loe sendiri masih belum tau pasti soal kebenarannya.
Lagian, ngapain juga loe tanggepin orang yg kelakuannya kaya pahlawan kesiangan? Masalah di mobil orang lain, kenapa mesti dia yg kebakaran jenggot tereak2 minta jawaban? Padahal masalah tsb khan enggak ditemuin di mobilnya dia. Malah dia sampe angkat2 topi segala buat tuh atpm, tapi dibelakangnya balik lagi jelek2in tuh mobil. Gue juga heran sama orang model kaya gini. Pengetahuan tekhnis gak punya, malah mau ngebacot sok jadi pahlawan membela org yg punya masalah. Lha orangnya sendiri aja udah diem, mungkin karena dia sadar kalo dirinya yg salah (baru belajar nyetirlah, salah antisipasi lah, salah perhitunganlah, salah pilihlah, dll). Atau dia merasa kalo cuma mobil dia doang yg bermasalah, 1 dari ribuan unit. Eh, 2 dari ribuan unit deng, krn ditambah ocehan sang pahlawan meskipun dimobilnya enggak ada masalah.
Sekarang mendingan loe pulang aja deh, jaga toko & urusin bisnis gue yg satunya. Drpd ntar mobil loe gue ambil semua, naek bajaj deh loe pergi kemana2.
AHAHAHAHA..!!! SUMPAHHH!!! SUMPAHH BUKAN GW!!!! AWAS LO MAXX NYANGKAIN GW!! INI BENERAN BUKAN GW LOHH!! AHAHAHAHA..!!! (tp kupret jg nih orang bahasany nyindir gw jg.. awas lu abis lebaran)
utk bokap si maxx !!
ck...ck....ck.....sekarang udah bawa2 bokap segala neh?
kl gt, gw jg boleh ikut campur tangan dong
kenalin neh, gw nyokapnya ichsan.
jgn sembarangan lo bilang anak gw pahlawan kesiangan, gak ngerti teknis segala
emangnya anak lo ngerti?? cuma hasil denger2 & copy paste doang khan, blm nyoba sendiri
tapi lo ada benernya juga, meskipun anak gw ud cobain sendiri & gak nemuin masalah seperti yg diributin, sampe angkat topi segala buat nissan, kenapa anak gw ikut teriak2 juga ya?
au ah, gw jd ikutan pusink mikirin. hal ky ginian aja sampe ribut2 segala.
mana lg bln puasa
tp lo jgn ngomong lg anak gw pahlawan kesiangan, yg bener dia pahlawan pembela yg gak jelas
hai anakku, pulang jg deh lo, cuci kaki cuci tangan bantuin nyak nyiapin makanan buat buka ntar sore
mana lg bln puasa
oom jhon, dulu saya mengira karet pintu belakang sebelah kanan lepas jadi bikin bunyi tersebut, tapi ternyata ada yang lain,
sy juga mengalami hala yg sama tapi belum sempat ke beres lagi km mobil dari 500 udah kedengaran, sekarang sudah km 2500,
ada kejadian yg mungkin sama dgn saya dan oom jhon, dan solved nya adalah sbb dari milis sebelah :
PROBLEM SOLVED!... Akhirnya setelah dibawa ke beres
Halim, selesai bunyi2 itu. Ada semacam flange (katanya) di bawah
engsel (dan di atas plafon) pintu belakang yang gak terlihat dari
luar yang berbenturan. Solusinya dikasih ganjel sebagai peredam. So
far sih, gak ada bunyi2. Biaya gratis... tis...
johnlegend wrote:ngga ngerti saya bos.. kyk nya bukan buckle seatbelt deh.. kan saya pake seatbelt kl nyetirhunter wrote:bunyinya kayak apa? apakah bunyi buckle seatbelt yg nyenggol2 body mobil di dalam?johnlegend wrote:mobil sy uda jalan 2400.. di pilar B sebelah kanan kok ada bunyi klutak klutuk yah.. kl lewat jalan yg rada2 bumpy gitu.. ada yg mengalami problem sama ngga?safety first.. hehehe..
mungkin buckle seatbelt baris kdua yah.. tar saya cari lagi.. moga2 ketemu..
B2279JM
om Maxx, sudah dapet mobilnya belum? saya udah dapet cuman salah warna. Udah complain ke dealer, kayanya mesti nunggu lagi nihh:(. email ke P Teddy belum ada jawabannya juga... binggungg, lg cari yg senasib ngga ada theadnya he he he he ... sorry deh buat yang lain numpang numpang nih di thread ini
Om Maxx indent di Kelapa gading juga?
bos Gun, ini beneran apa mitos sih kalo jarang dibawa ngebut, mobil bisa lemot?gunawan98 wrote: wah kayak nya njlimet yah cara nyetirnya gitu.. kalo rpm sih saya cuman sanggup dibawah 3000rpm deh
saya sering main-main diantara 2500-3000.. bawah dari itu saya pasti tidak akan oper gigi. takut mesinnya jadi lemot lama-lama..
seperti halnya mitos bahwa pada masa inreyen mobil gak boleh digeber, kata bbrp SMers disinikan cuma mitos karena mobil jaman sekarang pembuatan mesinnya udah halus, gak perlu masa inreyen2 lagi.
Logic-nya bukan krn jarang dibawa kebut jadi lemot,.. tp krn mobil dibawa dg RPM rendah terus menerus menahun maka karbon dalam ruang bakar menumpuk yg menyebabkan performa mobil turun. Bila sesekali di geber sampai redline maka bisa membuang/mengikis karbon2 tersebut,.. maka nya kalo lo perhatikan saat mobil di tune-up pasti digeber2 mesinnya, itu salah satu tujuan u/ buang kerak karbon diruang bakar dan biasanya setelah selesai tune-up terasa performa mobil lebih baik.Risol1 wrote:bos Gun, ini beneran apa mitos sih kalo jarang dibawa ngebut, mobil bisa lemot?gunawan98 wrote: wah kayak nya njlimet yah cara nyetirnya gitu.. kalo rpm sih saya cuman sanggup dibawah 3000rpm deh
Tapi kalo sudah parah penumpukan karbonnya ga bisa cuma dg digeber2 aja, perlu namanya tune up carbon cleaner, jadi bener2 bersih tuh piston dan ruang bakar.
- SM Affiliate
Salah warna?.. dari dan ke warna apa?dhukun wrote:om Maxx, sudah dapet mobilnya belum? saya udah dapet cuman salah warna. Udah complain ke dealer, kayanya mesti nunggu lagi nihh:(. email ke P Teddy belum ada jawabannya juga... binggungg, lg cari yg senasib ngga ada theadnya he he he he ... sorry deh buat yang lain numpang numpang nih di thread ini
Indent di Nissan Sunter .. GL 1.8XV MT 6Speed .. Coming Soon di bln ini.
Btw, Om dhukun pesan type apa?
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
salah warna??? kaya beli pulpen aja bos?dhukun wrote:om Maxx, sudah dapet mobilnya belum? saya udah dapet cuman salah warna. Udah complain ke dealer, kayanya mesti nunggu lagi nihh:(. email ke P Teddy belum ada jawabannya juga... binggungg, lg cari yg senasib ngga ada theadnya he he he he ... sorry deh buat yang lain numpang numpang nih di thread ini
- SM Affiliate
johnlegend wrote:wooo.. 6 speed..
eh, jgn kebut2an.. tar bokap elo marah2 lagi lho.. huehuehue.. canda bos..
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
BUSET ya! Nih thread dah ampe 75 page... Baru sadar gw... Wekekeke...
Bisnis? Sini donk..
Bisnis? Sini donk..
Masa ga ada duanya?
Tarikannya jelek donk... Pantes ga kuat nanjak abis 1 lngsng 3.. Wakakakakaka... O.O.T B.G.T...
Bisnis? Sini donk..
Bisnis? Sini donk..
Minggu lalu diberitahu GL xv 1.5 mt dateng, pas dicek kok dapet warna hitam, untung belum bayar 30 %, mereka bilang sy pernah ganti warna??? memang waktu dp belum tentukan warna, karena mesti ngajak istri (buat dia sih). nah di spk sy ditulis warna grey (kertas pink) yg asli katanya nanti mereka yang update. Kayanya sales ku salah comot warnanyamaxx wrote: Salah warna?.. dari dan ke warna apa?
@Risol1
iya kaya salah pesan nasi bungkus!!!isi nya beda ha ha ha HAREGENEBISASALAHINPUT!
Wahh.. harusnya yg item diambil aja tuh Om ... item termasuk warna favorite .. dan lagi ngetrend VIP gitudhukun wrote:Minggu lalu diberitahu GL xv 1.5 mt dateng, pas dicek kok dapet warna hitam, untung belum bayar 30 %, mereka bilang sy pernah ganti warna??? memang waktu dp belum tentukan warna, karena mesti ngajak istri (buat dia sih). nah di spk sy ditulis warna grey (kertas pink) yg asli katanya nanti mereka yang update. Kayanya sales ku salah comot warnanyamaxx wrote: Salah warna?.. dari dan ke warna apa?
Btw, Om dhukun pesan type apa?! Sy tanya jika tetep grey kapan datang, mereka bilang minggu ke 2 , ya oke lah sehingga sy tolak yg item. eh taunya sampai sekarang ngga jelas juntrungannya. Tau gitu sy ambil tuh!
Pokoknya saluutt deh...gunawan98 wrote:OK Guys... Ini FC review gw yang paling akhir:
1.5 XV Manual, bensin PREMIUM biasa: total km 444.9, 38.37 liter.. jadi FC nya adalah: 1:11.59km.
salut buat livina gw..
catatan: +/- 100 km dari 444.9 adalah perjalanan gw pulang pergi dari sby - ke trawas (luar kota)..
:D:D
catatan: kemungkinan yang luar kota sepanjang 100 km itu nyumbang FC? Kalo itu diabaikan pun saya yakin 1:11 masuk.
