koleksi hand tools........
Change
Post by Change »
Omnibus wrote: Thu May 14, 2020 14:02
DOHC wrote: Thu May 14, 2020 13:20 Buset, musti pake tool special, kl pake klem besi yg bsa d skrup kaya biasa buat selang aer bsa ga om ?
Tools justru jgn d beresin, biarin brantakan d garasi, jadinya tiap ari ad aj yg bsa d kerjain
ga bisa om kurang kuat, ntar gemuk bleber kemana2
cuma ada 2 tipe klem dan dua2nya pakai SST. Yg banyak dipakai OEM yg oetiker style.
tp kl mau coba2 pake cable ties atau sekrup ya boleh2 aja kan DIYer ..... gagal tinggal coba lagi aja
Bend & Cut Style
Oetiker Style
Om2 kalo ada butuh klem Oetiker...boleh pm saya..mana tahu stok ukuran yg dicari ready stok. Trims.
Change wrote: Thu May 14, 2020 16:02
noted om .... thx
adityabp
Post by adityabp »
marmut wrote: Thu May 14, 2020 5:29
adityabp wrote: Thu May 14, 2020 4:40
Om, kalo utk mobil FWD, apakah kopelnya juga bisa ditembak vet kayak gini?
Thx.
FWD nggak pake cross joint, pakenya constant velocity joint a.k.a CV joint.
itu kebungkus karet boot dan didalemnya sudah ada grease. kalo mau re-grease ya musti lepasin as roda, copot karet boot, dikeluarin grease yang lama dan dibersihin semaksimal mungkin yang ada di housing-nya, setelah itu diisi grease yang baru.
OK. Thx Om.
MSU
Daily Vehicle: Diesel
Post by MSU »
Bend & Cut Style
Oetiker Style
haha...klem begini terakhir liat di OE-nya Peugeot..abis diganti montirnya pake cable ties ukuran gede
bagus sih balik pake klem ini...tahan panas drpd cable ties
Profith83
Post by Profith83 »
DOHC wrote: Thu May 14, 2020 15:43
Omnibus wrote: Thu May 14, 2020 15:07
DOHC wrote: Thu May 14, 2020 14:52
tools ganti minyak rem ampe sgitu banyak ??
untung tools ganti minyak rem ane simple2 aj :upss: :upss:
engga, ane nyari2 aje om biar agak banyakan tools yg kepake :big_grin:
baut caliper carrier = pake impact gun, mentok link stabil, keluarin U-joint impact. kencengin pake TW large.
baut caliper pin = pake air ratchet. kencengin pake TW medium.
tromol karatan = keluarin air grinder. abis itu dioles copper paste permatex.
nepel bleeder = kencengin pake TW small. belom lg mata soket nya depan ma blkg beda. :mky_04:
majun wypall sm sarung tangan karet udah ga tau pake berapa biji. :mky_06:
udah gitu tadi test drive hampir kaga ada bedanya ama sebelumnya. begitu deh kl mobil ga ada keluhan diservice. :big_slap:
servis rem justru jgn ampe pas ad keluhan om
dl panther ane saking ga perna d urus soal rem, skali nya rusak melulu merembet sana sini, dr piston kaliper, pasak pin, rumah kaliper, master rem atas, booster, kaliper kit tromol.. itung2 malah ampir ganti smua parts rem, kcuali brake line doank, dan untung itu panther jadul, ga pake abs ebd dkk
semenjak rutin kuras, sejauh ini mobil2 ane paling banter cuman ganti seal kit, ama piston doank, ga seberapa mahal
Sering ganti minyak rem. Piston tetap rusak? bagian piston yang rusak berarti setelah seal piston rem yah? kalau sebelum seal kan kerendam minyak rem
Atau kampas lama kelamaan kan tipis jadi pistonnya keluar panjang dan teroksidasi. Atau bisa juga setelah seal kan ada karet penutup piston, mungkin karet rusak jadinya masuk pasir terus baret piston yah?
@profith :
Iya, rata2 d umur 5 taon, ane pasti bongkar kaliper, ganti seal kit, pas d bongkar pasti d body piston ad karat, terutama yg deket groove seal nya
Bisa d amplas cuman ane biasa ganti aj, ud tanggung bongkar kaliper, piston ga mahal
Profith83
Post by Profith83 »
Barusan beli KTC.
Semoga Ori dan awet
Lihat detail ada kode .... mungkin kode produksi.
10 mm kodenya 9A -> di website yg jualan kode 64
12 mm kodenya 8N -> di website yg jualan kode L4
14 mm kodenya 8U
Ada yang tahu kode apa? dan bagaimana cara membacanya?
KTC nya model baru ya? beda sm sy yg lama, model belasan tahun yg lalu
Profith83
Post by Profith83 »
Omnibus wrote: Fri May 15, 2020 7:53 KTC nya model baru ya? beda sm sy yg lama, model belasan tahun yg lalu
coba posting disini om.
Kunci ring pas 10 12 dan 14.
Yang saya beli persis/sama di website toko ijo.
Lihat di website Monotaro juga sama
https://cdn.monotaro.id/media/catalog/p ... 5747-1.jpg
Bedanya dimana?
Profith83 wrote: Fri May 15, 2020 8:27
Bedanya dimana?
Hehehe parno yaa :big_weee:
Profith83
Post by Profith83 »
Omnibus wrote: Fri May 15, 2020 9:08
Bedanya dimana?
hahaha :big_smile] :big_grin: pingin tahu saja om. Mungkin KTC om masih ori buatan japan. Punya saya sptnya dibuat di Taiwan atau China cuma tetap dipegang KTC principal Japan. :big_think:
Kl ktc asli mah kuat2 aj, dl aj dipake d toolset nya montir beres toyota gt
Profith83
Post by Profith83 »
DOHC wrote: Fri May 15, 2020 10:05 Kl ktc asli mah kuat2 aj, dl aj dipake d toolset nya montir beres toyota gt
Iya om. KTC asli sih saya yakin kuat.
Nah yang saya beli di toko ijo gak yakin nih 1 biji 50-70 rb (10 - 14 mm)
Ingin lihat punya om @Omnibus :big_grin:
Profith83
Post by Profith83 »
agak ada yg aneh ... cari di lazada bukalapak di semua toko keluar gambarnya sama :D
yanuarra
Post by yanuarra »
Duhh jd ga sabar nunggu 5 juni :ungg:
Profith83 wrote: Fri May 15, 2020 9:19
di page 25 trit ini sy pernah posting
yg pakai soft bag warna merah 1 set
yanuarra wrote: Fri May 15, 2020 12:33 Duhh jd ga sabar nunggu 5 juni :ungg:
ada apaan sih 5 juni (kepo) :mky_03:
Profith83
Post by Profith83 »
Omnibus wrote: Fri May 15, 2020 12:47
oh iya lupa om pernah posting, habis saya zoom persis seperti yang 5.5 mm masih seperti itu gambarnya.
Mungkin yang 5.5 barangnya puter kurang cepat jadi masih yg lama atau mungkin cuma gambarnya saja sama penjualnya belum diperbaharui
CRAFTSMAN Wrench bagus gak om? sama KTC? ingin tahu saja ... gak mungkin beli lagi
Profith83 wrote: Fri May 15, 2020 13:14
craftsman kl yg asli usa bagus tp skrg sdh di outsourced ke rrt. mekanik amrik di forum sering bahas dan mrk puas. kelasnya di atas harbour freight yg buat org sana sekelas tekiro wipro.
Profith83
Post by Profith83 »
Kalau Craftsman Facom Stahwille Bahco. bagaimana pengalaman om urutannya. Mana yang paling bagus
Profith83 wrote: Fri May 15, 2020 11:52
kl utk segi harga sehh, tools jepangan emg kisaran sgitu om..
konci soket merek tone, KTC aj jgn kaget sbiji bsa 20-30an rebu d glodok
ane dl banget perna punya konci ring pas set merek sandvik belzeer, itu sbiji nya kl skrg aj bsa 2-3 x lipet ktc
(dan kampret nya ud ilang smua tuh konci2 di pinjem sana sini, tinggal nyisa sbji doank ukuran 10)
Omnibus wrote: Fri May 15, 2020 13:36
nasib nya mirip2 sydchrome yah om, dl waktu masi aseli "aussie made" sehh ntuh tools banyak banget pemuja nya di aussie sana, dan mereka rata2 pd puas utk quality nya.. kl skrg sehh sama ama craftsman nasibnya, di outsourced ke cungkwo
DOHC wrote: Fri May 15, 2020 14:06
iya mirip sidchrome di oz ...... ah jadi inget dulu pertama2 koleksi tools dibilangin temen beli sidchrome trus ada yg mention bahco juga, ehh jadinya malah beli repco. hahaha keder sendiri .....
jd sy ceritanya ada temen di sydney om harsono, dia waktu itu mekanik mitsu. pas main ke rumahnya semua tools dia ada. tool trolley nya aja ada 2 full stack sampai ke atas dan mayoritas isinya snap-on termasuk tool trolley nya. Yah dialah org yg meracuni saya. :big_blushing:
stahlwille pertama yg kunci ring pas dan socket set ko-ken saya beli dr tool truck di bengkel tempat dia kerja. nitip ma dia.
DOHC wrote: Fri May 15, 2020 14:03 ............
makanya om resepnya beli satu set yg ada tray nya dan kaya saya setiap habis pake ditaruh balik. itu tray model sekarang diwarnain ngejreng dasarnya maksudnya spy kl salah satu tool ga ada ditempatnya bisa langsung detected dan dicari deh saat itu juga. lah kalo main tinggal di garasi ga ketauan ternyata ada yg hilang. pas ketauan udah ga tau kemana nyari nya udah kelamaan.
Omnibus wrote: Fri May 15, 2020 15:18
Repco sendiri skrg ud campur sari om, tp mostly skrg ud cungkwo punya jg, dan yahh dijual di repco store doank. Kl supercheapauto malah banyakan stanley skrg, dan stanley nya pun campur sari antara cungkwo ama yg EU punya
tp yah di aussie sendiri skrg ud mirip2 kaya dsini, tools2 branded macam stanley, sidchrome, repco, boxo smua ud outsourced ke cungkwo / taiwan banyakan
itu tool truck mxd nya kepunyaan snap on om ? waktu di syd ane sering banget ketemu tool truk snap on, kayanya smacam franchise gt
btw, seumur2 liat tools bahco di pajang banyak kaya jualan tools biasa justru waktu ane maen ke sydney tools yg di silverwater.. harganya pun jg masi reasonable, sayang waktu itu qantas bagasi nya pelit, kl ga sehh dah ane beli tuh satu set konci2 nya
