Kalo mo bahas sedan2 Honda disini aja...
Re: Kalo mo bahas sedan2 Honda disini aja...
Nimbrung nih yah ... hehehe ... hOnda asik, enak pake .. gampang dimodif ..
- Daily Vehicle: BRIO black elegant
Image gw ttg Honda scr faktual 'n Aktual sbb :
CRV matic'08 (punya Digitall), Jazz V-tec '07 AT, Civic VTEC Vti '02 AT
VS
..................Civic VTEC Vti '01 MT standard engine
Alhasil cuma Jazz Vtec azah yg rada2 melawan gara2 doski nahan pke tritonic-nya....
Di test @ Kota Baru Parahyangan Short Track....cuma gigi 1-3...100kph-an....
The Winner is ......CIVIC VTEC Vti'01 MT as punya si GW.....
tadinya gw deg2-an dgn CRV baru si Digital...
1st gear 60kph...2nd gear 100kph...koq sama yah ama CIVIC gw...sempat Ziper duluan...
tau2nya....jauh ach aklerasinya..ama Civic gw...not bad Laa buat AT..zaman sekarang..kenceng2 tp kalah ama CIVIC MT gw yg taon Zebot...TTK (tua2 keladi) sama ky Eterna lu dulu yak 'ga Digi..?? Keok lu sekarang ame ane...percuma CRV 300jeti-an kalah ama Civic yang 100jeti-an..Ha..ha..ha..ha...J/K....
yg hebat Jazz V-tec AT kuenceng abish Laa..sekelas AT pke Triptonic jadi bisa Nahan Gigi...
CIVIC gw bejek ampe 7000rpm(red Line) 1st gear 60Kph..lsg mati otomatis..minta pindah gigi 2
Yg penting maen bawah gw Menang...Cihuy....
Trus Civic gw irit bensin..premium pulaa.....tp Top speed kalah ama mantan gw CK4 bisa sampe 205kph ...Civic gw rasa bisa Laa ampe 200kph tp kaki ringking 170kph cukup Laa...
Iya nech Kaki..ball joint, Tie Rod, KOHEL Sayap2 'dach ancur lebur pertanda Kaki Honda emang tdk se-Durable kaki2 sedan Toyota....as RINGKIH abish....Parah...Katro...'ndeso Buat Kaki2 HONDA....
Alhasil maenan si MIKE ga lama ini 'mo gw Jokul..gw mau ganti FEROZA azah..soalnya gw Jadi Ka.reps TANGGEUNG..yg off-road ...'klo CIVIC dipertahanin..bakalan hancur minah Tuch Kaki2nye
Masalah over heat rada lumayan tdk ada ...atawa barangkali barang 2001 entah 'klo dach 10taon nech boil apa bakal kayak Grand CIVIV LX'91 gw Meleduk..cylender head peang....
secara over all Honda menang di irit & tarikan...Kaki2 once again..RINGKIH.....
VS
mobilnya pernah pakai velg aftermarket yah? kalo mau awet spt rata2 mobil, prefer standar.
karena honda termasuk mobil yg paling banyak diganti velg(upgrade ukuran) & suspensinya, daripada mobil lain.
tapi emang bener lho... kaki-kaki honda ringkih... namun handling mantap
sayangnya... tidak se-durable toyota
bahkan Honda Civic & CRV last gen.. juga konon ringkih..
Susah juga karena honda tahun 86 di indo sudah 4wheel Double-Wishbone, udah gitu mobil2 honda paling banyak diupgrade yah velg nya oleh user. juga civic nya tahun 88 sudah 4Wheel D-W.
Masa2 ini tentu improvement terhadap durability (juga flexibility) nya masih jauh utk suspensi D-W, Tp mereka cukup 'berani' mengaplikasikan ini utk dinikmati pada entry2 product (bukan kelas yg most pakai ini : premium).
Apalagi jaman dulu honda yg pertama sukses memasarkan tech FWD(Life 1967 = Tata nano 2008) & independent(civic exellent) di indo tahun 70-80an yg notabene masih banyak user awam; makanya jaman itu banyak "bengkel ketok as roda" yg entah bagaimana menyihir CV-joint rusak diperbaiki dgn diketok hanya menambah kerusakan, user tentu mengklaim ini ulah produk sampai tercipta mitos. (krn pernah, pengalaman pribadi juga).
Secara sudut pandang itu, handling, compare kasus kerusakan, & terutama volume produk tsb, tentu ini tidak terlalu parah.
Tp yg belakangan jazz dan CRV 2gen bukannya durability kaki2nya (ukuran standar) Rata2 saja dgn mobil lain (spec&performa kaki sama) yah?
@GTR ...oooO..getchu yak...Valid nech britaSusah juga karena honda tahun 86 di indo sudah 4wheel Double-Wishbone, udah gitu mobil2 honda paling banyak diupgrade yah velg nya oleh user. juga civic nya tahun 88 sudah 4Wheel D-W.
@ bram:
Keliatannya loe seneng banget kalo pd akhirnya bisa ngasepin gw sedikit, setelah berkali2 gw asepin akhirnya dendam yg dulu terbayar ya bram?
Jadi inget waktu gw masih pake Eterna GTi selalu ngasepin loe... mulai loe bawa Soluna, Lancer mungkin Civic juga bisa gw asepin kaleee hahaha...
Itu baru namanya TTK (Tua2 Keladi), Eterna GTi '91 loe lawan juga hehe...
Tp bram, loe harus thanks ke gw karena di tol gw selalu jadi pembuka jalan... TOT! TOT! NGUINGGGG! NGUUUUING! (si BMW hitam pun memberi jalan). Eh pas gw liat spion tengah, si Bram koq ga ada ya. Terpaksa deh gw tungguin di bahu jalan yang ada rambu dilarang berhenti-nya hahaha...
Ayo kita coba lagi! Kemaren masih belum puas nih, cuma sekali balap langsung kaboer gara2 ada satpam haha
ayo, mana sekuel nya
masa si bro kaki2 honda ringkih?lonelyguy wrote:tapi emang bener lho... kaki-kaki honda ringkih... namun handling mantap![]()
sayangnya... tidak se-durable toyota![]()
berbagi pengalaman aj ya, boil gw ada dua xtrail n CRV, tinggal dilampung sering bolak-balik jakarta lampung. hampir setiap minggu. jalanan lampung ke pelabuan hancur abis coz gw tinggal di lampung timur jd lewat jalanan rusak, sehari2 pun jalanan banyk yang hancur. pemakaian mbl bergantian, keduanya kilometer hampir sama 60.000an, pada kilometer 50.000an kaki2 x-trail bunyi ga karuan ternyata pas di cek ke beres nissan klaher(sori kl salah nulis) jebol, terpaksa ganti 1 set, untuk msh garansi
NB : CRV 2nd gen
mulai jazz dan crv 2gen sudah cukup kuat /~rata2 saja dibanding mobil sekelas umumnya.
mobil merk lain sampai ganti sektor2 umum shockabsorber, bearing, balljoint, tie-rod, tetap maybe fine2 saja tidak dibilang ringkih bagi sebagian orang.
bro-bro review dong buat sedan2 yg dah tua juga, civic "setrika" wonder kayanya masih enak dilihat, tiba2 aja pengen balik nyari lagi, dulu kaga dapet, yg gw tau sih belum power steering yah?
other info please! ketersediaan sparepartnya gimana, dll?
Ride/Drive with the pride,respect and satisfucktion
belum power steering, tapi sudah 5speed, rpm, fwd, torsion beam rear suspension.
sudah terlalu tua, mungkin rata2 sudah parah kondisi nya, di jakarta ada beberapa bengkel modifikasi menjejalkan dgn mesin Bseries.
sparepart original sektor2 mesin seharusnya masih mudah dicari, khususnya di jakarta.
Kemaren, Gue coba civic 07... 1.8 i-vtec... pny temen
baru km 11rb-an.. koq lakher depan ud bunyi yah... masih halus sih bunyinya, tapi cukup mengganggu... gruuung gruuung gruuung gitu...
cacat produk kali yah...??
NB: tinggal dijakarta.. jarang dipake...
apa bearing nya pernah kena banjir ya.
bearing roda mobil jepang kan rata2 sama merk sekitar : NTN / KOYO / NSK
daripada nabung buat ninja 250 mending ini, atau yg prototype tapi sampe kapan nabungnya................
keqnya buat kaki2 honda skg cukup bagus koq..jazz mungil aza jarang masalah..kalo ganti komponen yah pantas lhar oom..jalanan disini gimana dulu....
Haha...GTR wrote:ayo, mana sekuel nya...
Harusnya masih garansi ya, coba di cek aja ke bengkel Honda-nya.lonelyguy wrote:Kemaren, Gue coba civic 07... 1.8 i-vtec... pny temen
Berdasarkan pengalaman test drive Civic 1.8L A/T memang suara ban sedikit terdengar ke kabin kalau lagi lari di tol.
teman2 sm...
accord 2003-2004 penyakit yg paling sering ap yah?
bokap ngambil tuw mobil second g tw yg brapa cc
thx...
thx...
mugen R-R tadi, tambahan;
Wah, mas Bram mainnya pindah ke sini nih...
Hayoo dong dijajal Civic-nya, as you did to your Soluna and CK4....
liat2 di iklan, civic setrika sudah jarang
, kalo nuova masih ada sekitar 35jt-an buat tahun '89, kira2 buat wonder wort it-nya dikisaran berapa yah?
nouva aja sekalian, sudah 4wheel double wishbone & power steering, walaupun model ini belum sekuat konbinasi simple strut - torsion beam.
melihat umurnya, mesin sepertinya sudah soak, harus bangun ulang or swap.
bro GTR, punya referansi/link/literatur ga buat swap engine wonder
, pengennya sih emang nouva tapi kurang berasa 80's.
-lagi berhayal kalo dapet setrika--->langsung bongkar2, modif minimalis, pasang rollbar, swap enggine(kalo ada duit lebihnya), dll
ga punya, rajin2 cari di internet harusnya banyak nih.
tapi dulu ada bbrp bengkel di jakarta yg paham & pasang Bseries ke wonder;
Autodyne = pasar baru.
Firna Protechnic = tanjung duren.
