VIDEO Berita kasus HEBOH TOYOTA !
asudarsono
Re: VIDEO Berita kasus HEBOH TOYOTA !
Karena itu takhayul. Masa laporan dibuat 2010 dibilang 2011.
Ready to Race
Majalahnya edisi 2011...laporan kerusakan2 di sebelum 2011. Coba belajar berpikir dan membacaasudarsono wrote:Karena itu takhayul. Masa laporan dibuat 2010 dibilang 2011.
http://www.theautoindustrieblog.com/201 ... -cars.html
MOST RELIABLE CARSToyota and Mazda are the most reliable cars - TUV Report 2011
TÜVs (Technischer Überwachungs-Verein), short for Technical Inspection Association in English, is a German quality and safety approval body. For ease of typing on a standard UK keyboard, I am ignoring the umlaut German vowels. In Germany, all registered vehicles must go through regular vehicle inspection to assess their road worthiness. Else the vehicle cannot be insured. It is not exactly similar to UK's MOT, or Singapore's LTA inspection, and certainly not like our Puspakom, in a sense that it is a lot more strict. It shares more similarity to Japan's Shaken inspection, which is probably among the most strict AND costly compulsory vehicle inspection. Depending on the vehicle age, German vehicle inspection intervals vary between 2 to 3 years. TUV, along with DEKRA are among the main bodies authorised by the German goverment to carry out vehicle inspections. It is so strict that minor rust spots are sufficient grounds to fail an inspection.
Each year, in partnership with Autobild, Germany's most influential automotive publication, TUV releases an annual TUV Report which shows results of average number of problems detected in any particular vehicle model of cars inspected by the body. It is by far one of the most reliable vehicle dependability data and is used as a main reference for German used car buyers.
MOST UNRELIABLE CARS
asudarsono
Oooo, mana majalahnya?
Itu khan cuma blog. Judulnya aja "Rants and commentaries on all things automotive."
FM kenal ama yg bikin ini blog?
Ready to Race
asudarsono
Makanya, berkali2 saya bilang, kalau copas agar dari sumber resmi saja. Nanti FM salah lagi.
Ready to Race
Belajar membaca lagi yaasudarsono wrote:Makanya, berkali2 saya bilang, kalau copas agar dari sumber resmi saja. Nanti FM salah lagi.
http://www.toyota.co.id/company/mediare ... le_id=4684
Jerman – Toyota kembali meraih penghargaan dari Auto Bild pada akhir 2010 lalu. Bila sebelumnya award yang diraih dari Auto Bild Indonesia, kini giliran dari Auto Bild Jerman yang bekerja sama dengan TUV (Technischer Überwachungs-Verein – Asosiasi Pengawas Mutu Jerman).
Penghargaan itu berupa pengakuan kualitas produk-produk dari Toyota. Selama 12 bulan Auto Bild dan TUV melakukan survei dan penelitian, menyebutkan bahwa Toyota adalah merek yang paling handal di 2010.
Penelitian yang terbagi dalam lima kategori itu diantaranya adalah untuk mobil usia 2-3 tahun, 4-5 tahun, 6-7 tahun, 8-9 tahun, serta 10-11 tahun di tangan konsumen. Mobil yang telah dipakai selama tahunan oleh konsumen tersebut kemudian didata sampai sejauh mana tingkat kepuasan dan permasalahan yang ditemui oleh para konsumen.
asudarsono
HAHAHAHA, sumbernya dari TOYOTA? Oh, my oh my.
Semua orang bisa lihat yg paling gede gambar VW Golf, hahahahaha.
Itu edisi keberapa sih? Aku jadi kepingin baca majalahnya.
Ready to Race
asudarsono
Udah ah, aku dikirimi pesan suruh cooling down dulu.
Ini saya kepingin menikmati gambar nenek moyang Camry aja.... mobil yang indah, bukan?
Ready to Race
Kalo dari Toyota ya resmi - terserah situ mau percaya atau nggak. Yg penting yg lain bisa baca. Ini juga resmi
http://www.topgear.com/content/carsurve ... /04/1.html
ini juga resmi
PEUGEOT 207 (1 STAR)
GEELY CK (NOL BESAR)
'Which cars are fighting a losing battle against reliability? You guessed it: they're French'
Which cars are fighting a losing battle against reliability? You guessed it: they're French. Eight out of the ten least reliable cars come from across the Channel, with the Peugeot 807 propping up the table.
The dismal people-ferrier is joined by two further Peugeots (the 307 and 407), a pair of Citroens (C3 and C8) and a trio of Renaults (the Megane, Espace and Scenic), with only the Range Rover and Ford S-MAX preventing a Gallic whitewash of the bottom ten.
In fact, the highest place Peugeot can manage is a miserable 134th for the now-defunct 206, while the highest-placing French car is the Renault Modus in, erm, 88th spot. As unreliable as une voiture Française? Malheureusement, oui.
ini juga resmi
Cuman beda satu bintang samaAdult occupant: The rating for the vehicle was limited to 1 star due to the unacceptably high risk of life threatening injury to the driver's head presented by the steering wheel. The protection offered to the driver's lower legs was weak due to high rearward clutch and break pedal displacement. There were hazardous structures in the area of the fascia that could be impacted by an occupants knees. The body shell was not capable of withstanding further loading. The ruptures to the footwell threatened the driver's feet. The car has an airbag control tell-tale (light) in the instrument panel which will be illuminated after turning the ignition key and making contact. Unfortunately there were NO AIRBAGS in this car. The tell-tale may mislead consumers.
Sumber RESMI: http://www.latinncap.com/_en/?pg=results_listAdult occupant: The protection offered to the driver was poor for most body regions, the chest protection was weak. High loads were placed on all areas of the driver dummy. A significant amount of body shell collapse results in high displacement of the A-pillar, steering column and pedals. The body shell was not capable of withstanding any further loading. Installing an airbag in this car would not improve occupant protection as the body shell integrity is not good. Probably an airbags in this car would not improve the week body shell integrity. This car has a passenger airbag switch but it DOES NOT have an airbag. This device may mislead consumers to think that they have an airbag equipped car while it is not the case.
asudarsono
Inilah persembahan Toyota untuk rakyat Indonesia
TOYOTA INNOVA : NCAP >>>> FAIL
TOYOTA VIOS : NCAP >>>> FAIL
TOYOTA RUSH : NCAP >>>> FAIL
TOYOTA AVANZA : NCAP >>>> FAIL
Silahkan mana suka boleh dibeli .....
Ready to Race
toyotaman
MONEY TALKS. toyota sering melakukan settlement di mana mana. Di US, di Jepang, di Thailand, apalagi Indonesia yang hukumnya ambu radul, bisa di bayangkan. Konsumen di bayar biar tutup mulut. Mobil jelek yang kasusnya sulit di tuntaskan seperti accelerasi mendadak di beli kembali dari konsumen supaya ngak ketahuan masyarakat.
toyota terbukti sering suap di mana mana, emang majalah ngak bisa di suap supaya kasih ranking tinggi ?
Bukti nyatanya ? Mobil Korea yang dulu aja sejelek jeleknya ngak ada kasus seperti toyota yang sludge, pintu ngak benar, accelerasi mendadak, steering bermasalah, banyak masalah lain, dan paling edan, recallnya di mainin, di tunda lama, akhirnya muncul korban .
Mobil Perancis seperti Peugeot yang di bilang jelek ama majalah, di bilang bobrok terus ama fortunerman, kok ngak ada kasus aneh aneh seperti toyota ? Coba ada ngak contoh ? Buktinya di Eropa mobil Perancis, mobil Eropa jauh lebih laku banding toyota. Majalah mau bilang apa terserah, tapi konsumen situ ngak bodoh. Mereka tau majalah bisa di suap, mending pakai pengalaman pribadi dan toh mereka mayoritas tetap beli mobil Eropa.
Paling bego kalau beli barang baca hasil rating majalah. Siapa iklannya paling gede, paling sering, siapa suapnya paling gede, pasti dapat ranking tinggi. Apalagi toyota, jago suap.
Saya mending lihat bukti nyata, dari pada majalah yang bisa di suap.
Turboman wrote:Neh ada lagi yg oweh nggak ngarti
Katanya 42ner di India dimaki maki pembeli krn kasus rem ??
Tapi di majalah dr India di bawah ini coba lihat rating si 42ner....
P.S.: Kalo mau protes jgn ke oweh, ke majalah Overdrive aja yah
TOYOTA : The One You Ought To Avoid
smgandi
Yg gambar ke-3 bukan Rush tapi Terios. Keliatan dari peleknya.
Vorsprung durch Technik
The Pursuit of Perfection
From Zero to Hero
Air Tenang Menghanyutkan
Ilmu Padi
From Zero to Hero
Ilmu Padi
sumbernya mana?asudarsono wrote:Inilah persembahan Toyota untuk rakyat Indonesia
Jadi....org Indonesia bodoh dong...Toyota laku kerassssssstoyotaman wrote:Majalah mau bilang apa terserah, tapi konsumen situ ngak bodoh. Mereka tau majalah bisa di suap, mending pakai pengalaman pribadi dan toh mereka mayoritas tetap beli mobil Eropa.
Auto2000 Pasarkan Land Cruiser Pikap dan Wagon
http://otomotif.kompas.com/read/2011/01 ... .dan.Wagon
JAKARTA, KOMPAS.com  Melalui Auto2000, Toyota memperlihatkan ujud Land Cruiser (TLC) pikap atau bak terbuka VJ79 yang diimpor utuh (CBU) dari Australia untuk dipasarkan di Indonesia. Kendaraan 4x4 ini menggunakan mesin diesel 6-silinder segaris, 4,2 liter, 96kW yang diperoleh pada 3.800 rpm dan torsi 285 Nm @2.200 rpm.
TLC menggunakan suspensi per keong (depan) dan daun (belakang) dan diklaim mampu berjalan baik di kemiringan 41 derajat. Tambahan snorkle di sisi kanan mencegah air menyelinap ke saluran isap (intake manifold). Karena itu, Land Cruiser ini mampu menerjang genangan air atau sungai dengan ketinggian air 700 mm.
Untuk keamanan, mobil ini dilengkapi airbag pada lingkar kemudi, sabuk pengaman (seat bealt), dan rem cakram pada dua roda depan.
Jodjana Jody, Chief Executive Officer PT Astra International Tbk-Toyota Sales Operation, mengatakan, TLC pikap diimpor untuk memperkuat pasar niaga Toyota sekaligus memenuhi permintaan perusahaan pertambangan dan perkebunan di Indonesia. "Kami tidak menyetok unit. Siapa yang mau, pesan, kita sediakan unitnya," ujar Jody.
Selain model pikap, Toyota juga berniat memasarkan TLC wagon dengan label Troop Carrier atau disebut juga hardtop. Varian ini dasarnya sama dengan pikap, hanya berbeda bodi karena kabin dilengkapi tiga deret jok dan bisa menampung 10 penumpang.
Kedua varian dibandrol masing-masing Rp 680 juta dan Rp 730 juta per unit on the road Jakarta. Diperkirakan harga tersebut bisa berubah bila Toyota langsung secara resmi memasarkannya.
Penulis: Agung Kurniawan
Editor: Zulkifli BJ
asudarsono
[quote="FortunerMan"]
weleh weleh weleh.
weleh weleh weleh.
Ready to Race
Hauahahahahaha...emang Mod gampang ketipu. kasian deh loooo...banyak yg di sensor mod ya?asudarsono wrote:FortunerMan wrote: Jadi....org Indonesia bodoh
weleh weleh weleh.
asudarsono
Ah aku gak main gituan
Ready to Race
toyotaman
1. daihatsu hengkang dari China, ngak laku soalnya. avanza di jadiin mocin di sono. Malah rakyat China masih mending beli mobcin dari pada avanza. Pakai merek daihatsu aja ngak laku, apalagi merek FAW mocin ? Lebih ngak laku lagi.
http://www.theautoindustrieblog.com/201 ... china.html
2. Lagi, daihatsu hengkang lagi dari Eropa. Sama, ngak laku.
http://vibizlife.com/detail/drive/daiha ... dari-eropa
3. Lagi, daihatsu hengkang dari Vietnam. Sama, ngak laku juga
http://www.rmexpose.com/detail.php?id=1 ... %20Vietnam
4. Kapan daihatsu hengkang dari Amrik ? Udah di depak dulu sejak tahun 1992 !
Jadi di pasar mobil yang besar besar di dunia, yaitu, China, Amrik, Eropa daihatsu semua ngak laku, udah hengkang. Tapi daihatsu paling gede di Indonesia. Kenapa ? Apakah orang China, Amrik, Eropa bego semua ? Siapa yang bego ?
Ada apa dengan daihatsu ? Setidaknya Peugeot di Eropa dan China masih hidup, dan volume penjualannya masih besar.
Siapa yang bobrok ? Terserah, mau percaya majalah yang bisa di suap, atau pikir sendiri kenapa daihatsu di mana mana di TENDANG keluar ! Apakah mutunya demikian jelek sampai orang Amrik, Eropa, China, bahkan Vietnam pun semua udah kapok ?
Jangan lupa, avanza itu daihatsu. Meskipun milik toyota, tetap daihatsu. Mau bilang toyota sahamnya banyak, tetap dah di depak di mana mana.
Tanpa avanza dan rush yang semua bikinan daihatsu, toyota urutan no berapa di Indonesia ?
FortunerMan wrote:Jadi....org Indonesia bodoh dong...Toyota laku kerassssssstoyotaman wrote:Majalah mau bilang apa terserah, tapi konsumen situ ngak bodoh. Mereka tau majalah bisa di suap, mending pakai pengalaman pribadi dan toh mereka mayoritas tetap beli mobil Eropa.
Editor: Zulkifli BJ
datsu
gambar 1 dan 2 super gak valid... gw jujur gak mau komen di thread gak berguna ini, tp gambar2nya pak asudarsono menyesatkan...
1. Kijang kapsul, bukan innova. Terserah ente mau bilang toyota, tapi ente nulis innova untuk gambar itu yang artinya itu gak bener
2. Vios? really? ban serep dibawah body (bukan bagasi) dan knalpot kiri? Bos, mbok ya kalo emang mau nyela2 mobil diperhatikan dulu....
I'm flying with my Siti
Powered by L15Z1 N/A
Kok balik nanya...saya nanya...jadi menurut anda orang Indonesia bego? Orang Jepang gimana...Daihatsu laku, Toyota no.1toyotaman wrote:Jadi di pasar mobil yang besar besar di dunia, yaitu, China, Amrik, Eropa daihatsu semua ngak laku, udah hengkang. Tapi daihatsu paling gede di Indonesia. Kenapa ? Apakah orang China, Amrik, Eropa bego semua ? Siapa yang bego ?
Ya begitulahdatsu wrote:gambar 1 dan 2 super gak valid... gw jujur gak mau komen di thread gak berguna ini, tp gambar2nya pak asudarsono menyesatkan...
asudarsono
Ya ya, noted om gandi dan datsu. Why so serious?
Kalau Land Cruiser wagon cocok buat begini kali
Ready to Race
Ha ha...mau menyesatkan...ketangkap basah. Good job datsu
