Moderators: Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze , akbarfit
Posts: 26953 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Wed Mar 11, 2020 13:17
josomba wrote: ↑ Wed Mar 11, 2020 1:23
Saya lebih curiga rembes itu buat yg rutin pake engine flush (masih hipotesis ya ini), CMIIW.....
Ya pengalaman saya sampe 70ribuan KM itu ndak masalah sampe suatu ketika, saya iseng masukin LM engine flush, 3 bulan kemudian rembes... Secara bahan ya mungkin sudah kurang bagus, tapi tambah kena petroleum jadi ya begitu lah...
bukan hipotesis lg, tp fakta itu
dl ipah ane perna kemasukan enjin flush, lgs rembes dr seal kruk as depan, ama timing cover, ama seal busi
Posts: 11369 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Wed Mar 11, 2020 13:40
Profith83 wrote: ↑ Wed Mar 11, 2020 12:52
Cari shock busi yg ada magnet untuk mobilio yg sambungan 3/8 merek Tekiro susah cari di online gak dapat 2x
ada merk KTC di tokped
https://m.tokopedia.com/wl-mandri-shop/ ... an-b3a-16p
Post
by DOHC » Wed Mar 11, 2020 14:05
wuihh KTC
sala satu konci kelas keraton nehh, konon dipake jd toolset nya beres atoyot
btw tekiro konci busi nya ga pake magnet2 an, doi pake nya yg seal karet doank, murmer
Profith83
Posts: 4596 Joined: Mon Jul 14, 2008 2:54
Post
by Profith83 » Wed Mar 11, 2020 14:07
DOHC wrote: ↑ Wed Mar 11, 2020 14:05
wuihh KTC
Om pakai yg karet juga? Takut lepas susah ngambilnya saja
Profith83
Post
by Profith83 » Wed Mar 11, 2020 14:11
Merek GESTAR taiwan 71 rb
Mata Shock Busi Magnetic Dr Spark Plug 16 mm (3/8”)
https://tokopedia.link/Pp7ewGF6K4
Merek TOPTUL aiwan 51 rb
https://tokopedia.link/RO8JVp9IL4 di toko
Ada yg pengalaman? Bagus yg mana?
Post
by DOHC » Wed Mar 11, 2020 14:18
Profith83 wrote: ↑ Wed Mar 11, 2020 14:07
wuihh KTC
ane pake yg karet, aman2 aj sehh
Posts: 11053 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Wed Mar 11, 2020 14:19
beli mata sock yang deep wall aja murmer, nyabut businya bisa pakai coil ditancepin lagi.
jadi mekanik musti panjang akal, musti memanfaatkan apa yang ada.
Post
by DOHC » Wed Mar 11, 2020 14:46
marmut wrote: ↑ Wed Mar 11, 2020 14:19
mbah
kl nyopot pasang coil ama busi kadang ane suka random gt gapapa kan yah ? apa musti sesuai urutan pas ngebuka nya ?
Posts: 9756 Joined: Tue Apr 30, 2013 7:10
Post
by Suryaputra » Wed Mar 11, 2020 14:50
DOHC wrote: ↑ Wed Mar 11, 2020 13:17
mang bener2 haram itu cairan engine flush berarti
Profith83
Post
by Profith83 » Wed Mar 11, 2020 15:02
DOHC wrote: ↑ Wed Mar 11, 2020 14:18
wuihh KTC
Merek apa om? Ada penampakan? Mau nyontoh drpd pusig wakakak
Profith83
Post
by Profith83 » Wed Mar 11, 2020 15:04
Beli 1 dapat 5. Itu kalau gak buka bengkel dipakai pribadi doang. Sampai anak cucu....
Post
by DOHC » Wed Mar 11, 2020 15:12
Profith83 wrote: ↑ Wed Mar 11, 2020 15:02
tekiro om
Post
by marmut » Wed Mar 11, 2020 15:19
DOHC wrote: ↑ Wed Mar 11, 2020 14:46
mbah
sans.... ga masalah.
Suryaputra wrote: ↑ Wed Mar 11, 2020 14:50
haram kalo tiap hari dipake. dan wajib hukumnya pada saat olmes jadi sludge, itupun musti diliat kasusnya seperti apa.
Post
by Omnibus » Wed Mar 11, 2020 15:31
Profith83 wrote: ↑ Wed Mar 11, 2020 15:04
ada harga ada rupa
kl saya emang buat warisin ke anak .... ada 2 laki semua
indeskey
Posts: 887 Joined: Fri Nov 23, 2018 9:27
Post
by indeskey » Thu Mar 12, 2020 1:04
Profith83 wrote: DOHC wrote: ↑ Wed Mar 11, 2020 14:18
Saya pake yg biasa bgt gak pake karet masih bisa keambil om busi nya. Kan miring itu posisi businya. Jad kalau ada karetnya ya lebih bisa ke ambil. Jangan ragu om, gampang itu.
Malah buka kunci koilnya yg kanan yg agak ribet hehe.
Profith83
Post
by Profith83 » Thu Mar 12, 2020 3:13
Omnibus wrote: ↑ Wed Mar 11, 2020 15:31
ada harga ada rupa
Awas ilang om. Susah susah beli mahal mahal dihilangkan, kecewa banget
Profith83
Post
by Profith83 » Sun Mar 15, 2020 12:19
DOHC wrote: ↑ Wed Mar 11, 2020 2:40
Bunyi nya deg deg atau kaya rem basah karatan abis dicuci gt ?
Kl dg deg, most likely drive shaft, ane punya ud perna di ganti pas odo 70 rebu, skrg 116 rebu jg ud bunyi deg deg lg
Om ganti filter bensin di KM berapa? DIY?
Post
by DOHC » Sun Mar 15, 2020 16:28
Profith83 wrote: ↑ Sun Mar 15, 2020 12:19
filter bensin di dalem tangki om, maintenance free
kl kotor, tinggal buka dr dek bawah kursi tengah, buka dr tutup tangki bensin nya.. dibersihin trus dipasang lg
dulu lipindut jg gt
beda ama ipah, ad filter external yg musti ganti
htk
Posts: 79 Joined: Tue Jun 26, 2018 4:56
Post
by htk » Mon Mar 16, 2020 5:33
Mobilio bisa di pasangin cruise control gak ?
ada yang jual tombol nya di marketplace kan
trus di connect in ke ECU gitu yah ?
Profith83
Post
by Profith83 » Mon Mar 16, 2020 7:47
DOHC wrote: ↑ Sun Mar 15, 2020 16:28
dulu lipindut jg gt
Apakah sudah pernah bersihkan filter bensin di HRV om yg sekarang sampai KM 100 rb lebih?
Post
by DOHC » Mon Mar 16, 2020 13:40
Profith83 wrote: ↑ Mon Mar 16, 2020 7:47
dulu lipindut jg gt
ga perna sehh, di betot2 gas masi kontan
Profith83
Post
by Profith83 » Mon Mar 16, 2020 15:25
mantap om .... seringnya isi pertamax yah ? .....
Post
by DOHC » Tue Mar 17, 2020 1:07
Profith83 wrote: ↑ Mon Mar 16, 2020 15:25
Nga sehh om
Pertalite mostly
Pedal gas coba d betot2 om, kl mesin ga ad brebet2 atau rpm naek kontan mustinya sehh supply bensin lancar
Post
by Suryaputra » Tue Mar 17, 2020 3:56
DOHC wrote: ↑ Tue Mar 17, 2020 1:07
Nga sehh om
Pertalite mostly
coba dicek om
klo saya baca manual book, bilangnya Ganti tiap 4 tahun / 80rb KM
takut ajah filter bensinnya bolong
Posts: 2921 Joined: Sat Aug 05, 2017 12:00
Post
by josomba » Tue Mar 17, 2020 3:58
Suryaputra wrote: ↑ Tue Mar 17, 2020 3:56
coba dicek om
Kalau saya dulu ganti pas 77k skalian crankshaft ikut ganti karena meler....
Pas liat ntuh filter, banyak pasir2 gitu ya.... selama 40k pertama sih sering premium (2x isi premium, 1x isi pertamax). lewat 40k baru 1x pertalite 1x pertamax ganti2an.... Apa itu akibat penampungan di pom bensinnya aja yg kotor yak ampe kek gitu...
Ga kebayang ntuh pasir2 kalau masuk ke ruang bakar, dah kek amplas
