The White Legend Charade CS'85
Re: The White Legend Charade CS'85
fotonya ada di http://www.serayamotor.com/diskusi/view ... =5&t=14305 om bram
salam hormat buat sesepuh cs ers
best regards for all
http://www.nugrohography.com
- Daily Vehicle: BRIO black elegant
In Memoriam ..DAIHATSU CHARADE CS'85 top Speed 160kph
ini berapa CC sih?
ini bisa jadi reverensi gak ya?
http://www.carfolio.com/specifications/ ... /?car=6347
1987 Daihatsu Charade CS engine
- Bore × stroke 76.00 mm × 73.00 mm(2.99 in × 2.87 in)
- Cylinders Inline 3
- Displacement 1 litre/993 cc(60.597 cu in)
- Type SOHC, 2 valves per cylinder 6 valves in total
- Maximum power 51.7 PS (51 bhp) (38 kW) @ 5600 rpm
- Specific output 51.4 bhp/litre 0.84 bhp/cu in
- Maximum torque 76.0 Nm (56 ft·lb) (7.8 kgm) @ 3200 rpm
- bmep 961.8 kPa (139.5 psi)
- Specific torque 76.54 Nm/litre
In memoriam ? maksud gimana om....udah dikandangin or dijokul ?Bram wrote:In Memoriam ..DAIHATSU CHARADE CS'85 top Speed 160kph
* dulu waktu masih kuliah ane juga pernah pake charade generasi awal ( th 1979 -1983 ), sebelum si Cs. Mobil irit, lincah dan murmer sparepartnya.
@Welly2008...yup Ter-Jokul...si legend 160kph mentok-tok...
kga sempat mampir ke Garage om Poetic...
Wach 79-mah lampu bulat dunks....
@fr34kclown.....koq ngilang
@fr34kclown......Totally Damn VANISH
CHARADE TURBO
Si Jagurs 'nie Pasaran Now Berkisar 20-30jeti Euy....Ruarr Biaso... tp pas di Check brg rongsokan.....pd abish.......dgn penawaran harganye......
jd Nyesel berat Lepas My White Legend Charade CS'85 mentok 160kph
gue respek banget sama nih mobil platnya tebel bro pernah gue pegang kok keras betul tutup bagasinya
ehm charade nya kenceng bgt y om bisa mpe 160Km/jam
btw spare parts charade mudah ga di dapet n klo subtitusi ma mobil apa y???
utk yg versi kapsul ada brp tipe seh???
solar_kerosen wrote:gue respek banget sama nih mobil platnya tebel bro pernah gue pegang kok keras betul tutup bagasinya
@solar_kerosen ......wah dpt-nye..dempulan rekondisi...yg Ngaleng ORI dunks....
sesama ex.user Charade CS ToP bgt boz irit serasa motor kga keujanan kepanasan..kuenceng..apalagi yg TURBO.....
Dhysolid wrote:ehm charade nya kenceng bgt y om bisa mpe 160Km/jam
@Dhysolid....ya Om...gw beli dr bokap.....Ori mulus kga ade lagi...dach...nyesel gw jokul utk nutup utangs ke BOKAP...pdhl kt bokap santai aze bayarnyeee....Luckly dach yg beli dr gw..si White Legend CHARADE CS'85...doi aze bilang gw paksain dananya pak 'tuk beli CS bapak...soale nyari2 kga nemu species langka ky geneee..160 mentok Coy ......
subtitusi...pke apa yak...kga pernah selalu beli part ORI @ ASCO....yg capsule CX boz...pilih yg Winner
Kalo cuman masalah tebel-tebelan plat, nggada yang ngalahin plat karoserian Adiputro!. Kokoh, tebel, meredam suara soundsystem dari dalem keluar walaupun tanpa peredam. Keunggulan sekaligus kelemahan. Dihajar motor dari belakang, engga ngefek, hajar tiang beton reklame waktu atret, yang kalah malah catnya. Ketimpa runtuhan kuda-kuda garasi waktu gempa jogja, atapnya hanya penyok dikiit banget, bodi samping yang kena runtuhan kuda-kuda dan beton, hanya meninggalkan beset-beset cacat cat.
Tapi kalo dihajar truk dari belakang, tipikal plat kaku gitu, malah akan bikin penumpangnya semakin terlempar, karena platnya engga mudah penyok karena engga menyerap benturan, alias energi benturan dirambatkan melalui sasis dan disalurkan ke penumpangnya dalam bentuk energi inersia.
cmiiw...
VanzMatic wrote:solar_kerosen wrote:gue respek banget sama nih mobil platnya tebel bro pernah gue pegang kok keras betul tutup bagasinya
cmiiw...
@All perasaan my ex.White legend CHARADE CS Plat-nye kga tebel2 bgts...
kalo blom dempulan, rasanya sihh emang engga tebel2 gitu kok om... cmiiw...Bram wrote:VanzMatic wrote:solar_kerosen wrote:gue respek banget sama nih mobil platnya tebel bro pernah gue pegang kok keras betul tutup bagasinya
cmiiw...
(pernah punya tetangga yg miara CS juga..)
[/quote][/quote]
(pernah punya tetangga yg miara CS juga..)[/quote]
@ VanzMatic....U damn rite 'bro...My Ex. White Legend Charade CS'85 Ngaleng ky kaleng krupux...Full Ori.....Hve a Luck D...org LEMBANG yg beli my White Legend
[/quote][/quote]
Miss my ex. White Legend Daihatsu Charade CS'85
om mw tanya dongBram wrote:Dhysolid wrote:ehm charade nya kenceng bgt y om bisa mpe 160Km/jam
klo charade cx 1.3 kapsul kisaran 30 tuh kira2 bagus ga y?? biasanya klo dlm kondisi normal atau pr dkit ga berat itu pasaran brp y???
utk spare part mudah di dapat ga y???
ane lagi mw nyari charade cx ney, gara c jagur punya om bisa lari 160 km/jam jadi ngiler
tadi liat2 juga ada yg turbo kog hargana malah murah y jadi curiga
Dhysolid wrote:om mw tanya dongBram wrote:Dhysolid wrote:ehm charade nya kenceng bgt y om bisa mpe 160Km/jam
@Dhysolid....Hmmmm CX pasaran gelap juga depend on brg....>30jeti baru brg bagus.....
C Jagur CS....tp brani adu ama CX..'klo yg sehat yak
CS TURBO...kga ade Turbo-nya lagi rata2....dach Vanish ...pasaran gelap..>25jeti org banyak pasang harge...tau brg-nye.... soale banyak yg aji mumpung....brg Rongsokan harga selangit...'met Hunting...b patient...rata2 CX ancur Lebur....
Luckly dpt CS TURBO Ori
subtitusi...pke apa yak...kga pernah selalu beli part ORI @ ASCO....yg capsule CX boz...pilih yg Winner [/quote]
om mw tanya dong
tadi liat2 juga ada yg turbo kog hargana malah murah y jadi curiga [/quote]
Luckly dpt CS TURBO Ori [/quote]
@Dhysolid Koq Ngilang Vanish...
om mw tanya dong
- Daily Vehicle: Charade
sumpah om mau liat fotonya? tapi gak ane tes sampe 150 takut hihihi ane cuma nyoba ampe 120
nih photonya om:
