Moderators: r12qiSonH4ji , avantgardebronze , akbarfit , Ryan Steele , sh00t
yanuarra
Posts: 4052 Joined: Sat Dec 28, 2019 9:55
Post
by yanuarra » Sun Jun 06, 2021 12:21
Omnibus wrote: Sun Jun 06, 2021 12:05
yanuarra wrote: Sun Jun 06, 2021 11:46
Magnetic pick up tool... yaah sekedar punya2an aja
kepake bgt ini mah
beli 1 lagi yg batangnya fleksibel, stahlwille di fmm ada mbah.
beda fungsinya, kadang perlu dibengkokin. yg teleskopik ini kan ga bisa.
*ratjoen
Iyaa tdnya mau yg bisa dibengkokin... Tp dipikir2 yaudah deh yg lurus dlu aja
Posts: 11851 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Sun Jun 06, 2021 12:48
yanuarra wrote: Sun Jun 06, 2021 12:21
bentar lg mbah marmut beli juga nih .....
kl mbah delko kayanya nunggu kesempatan ...... dalam kesempitan. ngerti kan maksudnya.
yanuarra
Post
by yanuarra » Sun Jun 06, 2021 13:01
Omnibus wrote: Sun Jun 06, 2021 12:48
Beli yg bengkok mbah marmut?
Ngerti
Posts: 11955 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Sun Jun 06, 2021 13:50
pada ngegosip apa ini......
Posts: 27678 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Sun Jun 06, 2021 17:39
marmut wrote: Sun Jun 06, 2021 13:50
Batang yg bisa panjang pendek trus bengkok2an
Post
by Omnibus » Sun Jun 06, 2021 17:47
DOHC wrote: Sun Jun 06, 2021 17:39
terutama kl ada rang-rang ..... alias rangsangan
teleskopik langsung aktif
Post
by marmut » Sun Jun 06, 2021 18:16
ngapain beli?
saya punya banyak magnet bekas dinamo fan radiator. tinggal nyerut bambu sesuai kebutuhan, magnet dilem pake jb weld ke batang bambu.
mbah delko? dia paling pake sapu lidi....
Post
by Omnibus » Sun Jun 06, 2021 18:40
marmut wrote: Sun Jun 06, 2021 18:16
ngapain beli?
ebuset ..... udah ga jaman pake bambu runcing. itu mah baheula.
Post
by marmut » Sun Jun 06, 2021 18:57
Omnibus wrote: Sun Jun 06, 2021 18:40
neruga.
kalo gitu pakai voice command saja...
"oi, tu baut jatoh ambil dikolong...."
*helper langsung beraksi.
**saya duduk nyeruput kopi.
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 6:55
Kampret bener blm rejeki..udah hampir dpt barang murah udah sold dluan
Pdhl semalem udah WA-nan dianya jual ke org
Pdhl hampir mo COD-an
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 7:02
Biji memang..kesel ane
Pdhl kan socket set 3/8 blm punya
Post
by Omnibus » Mon Jun 07, 2021 7:08
yanuarra wrote: Mon Jun 07, 2021 6:55
anjrit gopek. what a bargain itu.
msh ada barang apalagi tuh seller mbah? banyak ga?
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 7:19
Omnibus wrote: Mon Jun 07, 2021 7:08
Dia bilang cm ada 3 set buat socket set 3/8 ini... Ga ngerti mbah ada apa lagi..blm nanya2 lagi..
Itu jualan dipost baru semalem loh.. dan 3-3nya disikat orang..
Pagi ini ane lupa kaga follow up.. siang ini baru follow up eh udah keduluan sama orang lain
Nampaknya cod juga
lokasi ane udah deket, yg beli lebih deket lagi rupanya ane tanya2
Bijiiiii
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 7:33
Mbah shifu, kalo facom ogv(double ring 75degree set isi 12 pcs) dijual 350rb murah enggak yah?
Tp ada satu yg karatan...sisanya mulus.. Dan ane ada penggantinya di nomor yg karat itu ane ada KTC..atau ya cari satuan lg juga bisa..
Dibeli nggk yah?
Yg socket set td barang baru, yg jual toko...
Kl kunci ring ini second hand.. kayaknya org mau lepas kolpri..
blloewy
Posts: 1930 Joined: Mon Nov 18, 2019 1:54
Post
by blloewy » Mon Jun 07, 2021 7:46
Nama tokomya dung mbah....
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 7:53
blloewy wrote: Mon Jun 07, 2021 7:46
Di depok itu mbah.. sold ke org kelapa dua sama pitara..
Nama tokonya blm tanya ane mbah
yanuarra
Post
by yanuarra » Mon Jun 07, 2021 7:56
Nih kaya begini mbah shifu
Murah ya
Kebetulan jg blm punya yg 75 degree
Post
by Omnibus » Mon Jun 07, 2021 9:42
yanuarra wrote: Mon Jun 07, 2021 7:56
Murah ya
waduh sayang ya 1
direndem rust remover bisa kali ya. 350rb sih murah 1 set.
blloewy
Post
by blloewy » Mon Jun 07, 2021 11:44
yanuarra wrote: Mon Jun 07, 2021 7:53
Wah deket rumah ini.
Ini nemu di OLX ya Om?
Lilrocket
Posts: 3 Joined: Mon Jun 07, 2021 13:14
Daily Vehicle: Toyota Innova Diesel MT 2008
Post
by Lilrocket » Mon Jun 07, 2021 13:36
Malam empu2 dan suhu2 semua. Maap kalo salah lapak. Baru join Seraya hehe. Minta rekomendasi dong kalaubada kenalan atau rekomendasi yg bisa remap 2kd di kaltim (balikpapan atau samarinda). Makasihh suhu2 smeuab
Post
by Omnibus » Mon Jun 07, 2021 14:38
walah salah lapak banget. disini kl mau nyari palu, cangkul, arit dkk nya om ......
Profith83
Posts: 4635 Joined: Mon Jul 14, 2008 2:54
Post
by Profith83 » Mon Jun 07, 2021 15:21
Om @Omnibus.
Perlu tool apa saja untuk ganti shock breaker Honda Mobilio, rencana beli 1 set utuh sama Per nya.
Harusnya mirip sama Jazz/HRV konstruksinya, om kan punya Jazz/HRV yah
Di rumah sudah punya kunci shock set 3/8 dan 1/2 Flag
KTC ring pass 10-2 buah. 12-2 buah. 17- 1 buah.
Kunci L
Yang belum punya ring pass yang 14, ada sih Tekiro sudah 10 thn yg lalu 2 buah.
Sebenarnya kunci 14 itu sering kepakai yah? peru beli 2 atau 1 biji yah?
Butuh apa saja yah kunci2xnya?
Post
by DOHC » Mon Jun 07, 2021 15:28
Omnibus wrote: Mon Jun 07, 2021 14:38
Kurang lengkap mbah
Dsini sedia :
Trelek, sok, ceklek2, tang, obeng, martil, pahat, celurit, busi, delko, motor starter, spion, lampu, regulator power window, sentral lok, sambel, ketoprak, roti sumbu, kopi tubruk, cerutu, masas spots, filter2,...............
Post
by DOHC » Mon Jun 07, 2021 15:31
Mbah
Kl coil power gede
Cocoknya pake busi nikel, apa iridium / platinum ya ?
Tujuan Ga penting awet busi, yg penting justru si power coil tersalurkan, agar jgn ampe si busi jd bottleneck mbah
Post
by Omnibus » Mon Jun 07, 2021 16:51
Profith83 wrote: Mon Jun 07, 2021 15:21
Om @Omnibus.
Kunci L
perlunya itu:
buat tower atas
- kunci L long ukuran 8mm utk nahan As shock atas ketika dibuka pakai kunci ring offset 90°
- kunci ring offset 90° nomor 17mm (atau 19mm ya sy lupa)
buat knuckle bawah
- kunci ringpas 19mm (2 biji) atau 1 pakai ratchetsocket 1 pakai ringpas.
saran: utk nomor 14mm, 17mm, 19mm usahakan punya 2 biji krn biasanya perlu utk counter stay.
