L200 Strada second cari dimana yah?
Segala mobil tipe pickup (L-300, T-120, Kijang Pickup, dll).
babibu
Post by babibu »
Hallo bro, kyknya gw uda mulai jatuh cinta mah dcab.
Tapi kyknya susah banget cari mbl 2nd nya di jakarta khususnya strada, ada yg punya info?
thanks
fort088
Re: L200 Strada second cari dimana yah?
Post by fort088 »
Di kaltim & riau buanyak tuh....
Cuma aja ex. pekerja tambang..
Tapi kalo ngerti & hobby modif, bisa dipertimbangkan bro... :off_good_job:
babibu
Post by babibu »
Gw dengar sana memang banyak tapi kalo ex tambang apa gak riskan?
kalo harga kisaran brapa tuh mulai dari 04 s/d 07?
basing
Post by basing »
babibu wrote:Gw dengar sana memang banyak tapi kalo ex tambang apa gak riskan?
up up :big_peace:
biar rame threadnya
gmx
Post by gmx »
jadi L200 ya om, recommended deh.. yg jual hampir tiap hari ada aja di koran
basing
Post by basing »
gmx wrote:jadi L200 ya om, recommended deh.. yg jual hampir tiap hari ada aja di koran
L200 jadi salah satu pertimbangan dah, kan sudah di recommended. kan gagah juga buat oprut ringan. jadi tar bisa gabung ma oom2 semua di sentul ma di cibubur ma di purwakarta. itu kalu ga dapet pajero yang
pajero V6 3.0 pake engine 6G72 SOHC, "this V6 was a SOHC 12-valve developing 141 hp (105 kW) at 5000 rpm and 172 ft·lbf (233 N·m) of torque at 3600 rpm"
oom gmx tau ga pasaran yang th 04-07, trus yang recommended yang mesinnya apa? mode OOT: on
basing
Post by basing »
yang kaya gini:
basing
Post by basing »
biar paling up
:angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel:
basing
Post by basing »
Double or G-Cab
Power comes as standard in an L200 with the 2.5 litre turbo charged 113 bhp diesel engine, delivering a massive 177lbs. Ft. at just 2000 rpm and will happily pull a mighty 2700kg. The Mitsubishi L200 Double Cab will deal with whatever you throw at it!!
Kuncir72
Post by Kuncir72 »
babibu wrote:Hallo bro, kyknya gw uda mulai jatuh cinta mah dcab.
thanks
Di Aceh ada tuh dilelang punyanya NGO Cardi
Archapada
Post by Archapada »
coba dateng ke palembang banyak tuh di jalan veteran dipinggir jalan ada yang mulus ada juga eks pakean perusahaan asing.. kemarin ga sengaja nuker L200 gwa dengan triton kekekee...
Junjunglah langit dimana tempat engkau berpijak..
kael
Post by kael »
emang harga ginian brp duit sih?
TiongBahru_Ahbeng
Post by TiongBahru_Ahbeng »
L200 ini basis mesinnya kalo ga salah diambil dr mesin yg sama dgn L300, demikian jg dgn Triton double cab, bedanya di Triton udah dipasangi common rail, tp basis mesinnya sama.
billyd1773dz
Post by billyd1773dz »
engine L200 tu sampai sekarang ada 3
4D56T non DiD , basisnya sma dgn L300 dan mitsu Kuda tpi sudah di lengkapi turbo dan intercooler
4M40 2.8ltr mesin baru d indonesia d pke d strada kingcab dan Triton GLX
4D56T - DiD pengembangn dri generasi sebelumnya dgn sistem injeksi commonrail.
cmiiw
thx
:beer:
Image Billyd1773dz
hydro
Post by hydro »
Kalo serius cari kebetulan neh saya mw lepas L200 Strada Tahun 2006, Nego. Tapi ga pake lama...
hydro
Post by hydro »
Kalo serius cari kebetulan neh saya mw lepas L200 Strada Tahun 2006, Nego. Tapi ga pake lama... http://www.serayamotor.com/diskusi/view ... na+ya+cari#
