All about new Kijang Innova (ANKI) & Permasalahannya (Part 2)
Moderators: ginting, b8099ok, FRD, F 272, artoodetoo, ChZ
Post Reply
nflfrs705
Re: All about new Kijang Innova (ANKI) & Permasalahannya (Part 2)
Post by nflfrs705 » 10 Jan 2017, 19:26
saya dapet ini dari temen... barangkali om2 ada yg masih penasaran sama mobil ini?
daily user of a japanese..
Re: RE: Re: All about new Kijang Innova (ANKI) & Permasalahannya (Part 2)
Post by Turboman » 10 Jan 2017, 19:53
nflfrs705 wrote:Image
Hoaaeemmmmm
mending liat pameran akuarium ikan aja
nugroho bagor
Post by nugroho bagor » 11 Jan 2017, 12:44
Hoaaeemmmmm
:upss: sakit perut saya :wkkk:
andyez86
Daily Vehicle: Innova
Post by andyez86 » 11 Jan 2017, 13:21
eliezere1709 wrote:
Turboman wrote:Di US matic AC 60 E ternyata udah 3X re-map TCU
di sini baru 1X
Begitu cepatnya Bandar di US ambil tindakan
selengkapnya ada di Fb grup sharing ANKI ANF
mau tanya om, oli gardan 32gd seharusnya klo ganti oli berapa liter ya? bagaimana taunya olinya cukup atau kurang?
bantu jawab ya..kmrn abis ganti oli gardan pake idemitsu 75W90 pake 3liter..cek nya manual sih kmrn...dikobel gt lw lobang pengisian nya.... :mky_01:
andyez86
Hoaaeemmmmm
hmmm...akuarium yg mana dl nih...ikan jenis apa yg diliat...hahahahaaa
eliezere1709
Post by eliezere1709 » 11 Jan 2017, 18:11
andyez86 wrote:
di sini baru 1X
OOO 3 liter ya? kemarin gak sampai segitu di bengkel.. coba deh besok balik ke bengkel nya lagi.. trims ya infonya :big_smile]
Post by Turboman » 11 Jan 2017, 23:02
kalo udah meluap / luber ya wes
andyez86
Post by andyez86 » 11 Jan 2017, 23:25
kmren ga smpe luber om...mekanik nya yg cek...dia blg cukup ya wes...hahahahaha
andyez86
Post by andyez86 » 19 Jan 2017, 09:59
mau report aja nih..2hr lalu abis pasang ground cable di ANKI diesel matic sesuai petunjuk rekan2 di group FB...saya pake kabel NYAF dan skun tembaga,efeknya lgs berasa,stater lebih ringan,matic lebih respon,ga ada bengong kelamaan dl pas shifting,dan pas shifting 1-2-3 ga nyundul2, kalo soal iritnya blm tau krn 2hr ini kaki jadi lebih berat krn enak bgt dibejek2 mblnya...hahahaaa mau liat dl bbrp hr ke dpn...tar kasi report lg deh...
Post by Turboman » 19 Jan 2017, 10:04
andyez86 wrote:mau report aja nih..2hr lalu abis pasang ground cable di ANKI diesel matic sesuai petunjuk rekan2 di group FB...saya pake kabel NYAF dan skun tembaga,efeknya lgs berasa,stater lebih ringan,matic lebih respon,ga ada bengong kelamaan dl pas shifting,dan pas shifting 1-2-3 ga nyundul2, kalo soal iritnya blm tau krn 2hr ini kaki jadi lebih berat krn enak bgt dibejek2 mblnya...hahahaaa mau liat dl bbrp hr ke dpn...tar kasi report lg deh...
ini mungkin efek reset ECU juga krn kan kepala aki ada dilepas saat pasang GC
ya tapi tetap dgn GC pasti ada beda, apalagi kabel2 di ANKI kecil2
yg akan lebih kerasa bedanya ya mestinya Super Ground
andyez86
Post by andyez86 » 19 Jan 2017, 10:48
Turboman wrote:
19 Jan 2017, 10:04
kmrn ga ada nglepas kepala aki nya om...hrsnya ecu ga ke reset..cm buka baut di kepala aki - buat pasang skun nya...mnrt temen yg belajar fisika klo kebanyakan ground malah ga bagus...ga tau deh bener ngga,ktnya ada tmn dia yg pasang ground banyak d mblnya pas dipake keluar kota malah mual2...pusing gt d jalan...setelah dikurangi ground nya mendingan....hahahh....ato cm sugesti dia aja ya.... :mky_01:
Re: RE: Re: RE: Re: All about new Kijang Innova (ANKI) & Permasalahannya (Part 2)
Post by Turboman » 19 Jan 2017, 11:21
andyez86 wrote:
Turboman wrote:
19 Jan 2017, 10:04
hanya gak bagus utk kantong saja
kebanyakan ground ya useless aja, tapi sama sekali gak ada efek negative
andyez86
Post by andyez86 » 19 Jan 2017, 11:42
Turboman wrote:
19 Jan 2017, 11:21
andyez86 wrote:
Turboman wrote:
19 Jan 2017, 10:04
betul...hhahahaa...next psg fuel cooler sm atf cooler dl deh...ini mbl keliling trs tiap hr soalnya....pasang kecil2an dl aja...ada info soal anki 2017 ngga om??kira2 ud bener apa blm tu maticnya...blm ada yg kasi report ya?ini saya ditawarin sm beres diesel matic unit 2017 klo mau dicoba nih...
ginting
SM Moderator
SM Moderator
Post by ginting » 19 Jan 2017, 13:53
Ground cables or su[er ground cables gitu apakah memang butuh untuk mobil baru ?
apakah ground ke body atau chasis mobil belum cukup juga ?
Kalau kijang buaya/doyok untuk ngangkut pasir, saya maklum kalau ground cable perlu krn bodinya sdh tak bisa diharapkan jd konduktor lagi
Post by Turboman » 19 Jan 2017, 14:49
ginting wrote:Ground cables or su[er ground cables gitu apakah memang butuh untuk mobil baru ?
Ground system di Ipah / ANKI / ANF bawaan pabrik jelek
ini mah coba dan hasilnya riil
Kalo mobil jadoel tanpa ECU / TCU ya GC guna nya utk mobil yg udah uzur
Post by Turboman » 19 Jan 2017, 17:07
Update mengenai matic AC 60 E
Konon skg di BeRes Toyota mulai dilakukan penggantian komponen "brake plate" di sektor B3 dr matic AC 60 E yg mengalami jedug2
bentuknya spt ring tipis dr metal dgn gigi2 di sisi luarnya, jumlahnya ada sekitar 5 - 6 buah
Di Sby konon sudah ada 4 mobil yg diganti
Menurut report hasilnya :
Shift Flare hilang
Saya masih monitor perkembangan dlm bbrp minggu ke depan
Demikian report
andyez86
Post by andyez86 » 24 Jan 2017, 11:04
report ringan aja nih kmrn udah TD si jedug 2017 kebetulan ada unit G A/T diesel yg bs dicoba...dan hasilnyaa....
1. mulai dr mesin dinyalakan uda ga ada suara putu..
2. P ke R uda ngga keras lg...bener2 enak dan berasa improvement dr toyotak
uda dicoba berulang2 brenti di tanjakan dan turunan,brenti, dari D oper lgs ke P (kaki masi injak rem dalem2) lalu tarik rem tangan ( mbl ditahan pake rem tangan),oper ke R ngga ada hentakan dan ngga keras sm sekali..kedua coba dgn metode yg sama dr D oper lgs ke P lalu lepas rem kaki+rem tangan (transmisi yg nahan mbl) pas coba oper ke R hentakan nya minim bgt,jauhhh berkurang drpd NIK 2016 pnya saya d rmh...
3. ABS berfungsi dengan baik ( cuma iseng2 aja sih coba abs nya ) wkkwkww
4.shifting 1-2-3 jauhh lebih halus...masi ada nyundul2 nya tp dikittt...ini kondisi pake mode normal ya..
5.Karena mbl ga bs dibawa keluar showroom dan ga bs di test jarka agk jauh jd ga bs coba bejek2 buat liat shifting di RPM atas nya masih bengong ato uda lebih pinter.... :mky_01:
Post by Turboman » 24 Jan 2017, 11:26
andyez86 wrote:
24 Jan 2017, 11:04
Ya kondisi baru kan
Nggak tahu kalo udah 5000 km or 10 rb km gimana
Kalo saya mah udah nggak respek dengan seller yang pernah menginfokan sesuatu yg gak bener
Cengli-nya kalo produk cacat ya seller boleh jual dgn dikasih "pesan" kayak rokok
"Produk ini masih dalam proses pengembangan, silakan ajukan klaim di bengkel Resmi jika ada masalah"
andyez86
Post by andyez86 » 24 Jan 2017, 11:33
Turboman wrote:
24 Jan 2017, 11:26
andyez86 wrote:
24 Jan 2017, 11:04
Ya kondisi baru kan
baru om...plat nya aja blm ada...ini bukan mbl TD hrsnya...tp kmrn boleh dipake muter2 di area dealer...hahhaaa....dan diisi solar biasa... :big_bored:
3mul
Post by 3mul » 24 Jan 2017, 12:18
Turboman wrote:
24 Jan 2017, 11:26
andyez86 wrote:
24 Jan 2017, 11:04
Ya kondisi baru kan
punya saya nyundul dan jedug sejak baru dan tambah penyakit lemot dan geter setelah remap :big_slap: :big_slap:
baru agak nyaman setelah ganti lendir metik dengan bantuan teman-teman di SM. gejala jedug, nyundul dan geter2 masih kerasa tapi gak separah dulu.
Makasih buat Om TM dan Om T atas bantuannya, makasih SM dan Om mafia bogor yang sudah mempertemukan kita
:big_deal: :big_deal: :big_deal: :big_deal: :big_deal: :big_deal: :big_deal: :big_deal:
Post by Turboman » 24 Jan 2017, 14:03
KROMMMMMM all da waaaayyyyyy
Tinggal kasih pelek krom yg bisa muter2 itu
trus puter lagu rap kenceng2 pake sub 12" DVC
yg nyetir pake kalung & gelang kilau2 + kaca mata hitam
Kaca film Sparta yg bisa buat ngaca
Sempurna
andyez86
Post by andyez86 » 24 Jan 2017, 14:09
dan katanya di sini ( kota saya ) inden nya banyak...sales2 yg saya tanya pd rebutan...krom berjalan seharga 450jt...
Post by Turboman » 24 Jan 2017, 14:33
andyez86 wrote:
24 Jan 2017, 14:09
Coba kita lihat dlm 6 bulan
Jika beneran banyak di jalan......saya hanya bisa komen.....oo Indonesia oooooo......M G
Post by Turboman » 24 Jan 2017, 19:47
halo om uhuk2
diskusi di sini yok
uhuk2
Post by uhuk2 » 24 Jan 2017, 19:49
Turboman wrote:
24 Jan 2017, 19:47
halo om uhuk2
diskusi di sini yok
Ayuk om siap dah. :big_peace:
Post Reply
Return to “Minibus / Station Types”
